Suspension M7 Under Strut System
Old Apr 21, 2006 | 09:16 AM
  #176
MINICHEF's Avatar
MINICHEF
Yeh!
It Fianlly Arrived Thursday Afternoon (4/20). I Heard It Needed A Vacation First. Up To Seattle Back To Lakewood And Thed Up To Central Ca. Can't Wait To Install.
Old Apr 21, 2006 | 01:24 PM
  #177
maxmini's Avatar
maxmini
You got to love creative UPS Good luck with the install and have a great weekend.
Randy
M7 Tuning
Old Apr 21, 2006 | 05:34 PM
  #178
MSFITOY's Avatar
MSFITOY
Sweeet Mother of MINIs I like this setup I just finished a trouble free install of M7's USS and took Msfitoy out for a spin. I must say that the difference to me was very noticable...especially over the heavily grooved pavements across asphalt intersections (from Michigan's overweight semis:impatient). Turn in response feels quicker too...another keeper mod
Now it's a race against the clock...DFIC, DFIC, YEEEEAH BABY
Old Apr 22, 2006 | 12:28 AM
  #179
MINICHEF's Avatar
MINICHEF
INSTALLED TODAY. HAD TO SLIGHTLY MODIFY ALUM. SKID PLATE FOR FRONT MOUNT TO SIT FLUSH AND ALLOW CLEARANCE TO ALLEN BOLTS. NO BIG DEAL. DROVE UP TO CLUB MEETING TONIGHT, EVERYTHING JUST SEEMS TIGHTER. BIG TEST IS ON SAT. DRIVING TO MONTEREY, HWY 198 TO G-16(CARMEL VALLEY ROAD)THAT WILL REALLY LET ME FEEL THE DIFFERENCE.
Old Apr 22, 2006 | 01:22 AM
  #180
MINIotaple's Avatar
MINIotaple
Is an air impact gun really needed for the install? If so, where can I get one cheap?
Old Apr 22, 2006 | 06:35 AM
  #181
MSFITOY's Avatar
MSFITOY
Both Chad and I didn't use one...I pretightened the allen bolt/expansion nut assembly before wrenching. The one thing I did differently (because I didn't read the instructions) was to insert the expansion nut into the hole without the large washer. By doing so, the nut expanded right up against the sheet metal, preventing it from any movement during assembly. I then placed the large washer between the expansion nut and the USS assembly. Seemed to have worked out nicely for me. Don't forget to locktite every bolt/nut and torque down tight (not 300ft/lbs).
Do not do it this way unless you ask Peter for his approval or it may not be covered under warranty
Old Apr 22, 2006 | 07:00 AM
  #182
SpiderX's Avatar
SpiderX
in the "for what it's worth dept"..... I just emailed Peter to include this kit with my order for the DFIC and the strut bar .... now if it would stop raining/drizzling so I could go ride my bike (pedal)
Old Apr 22, 2006 | 05:31 PM
  #183
MINIotaple's Avatar
MINIotaple
Thanks.
Old Apr 25, 2006 | 11:47 AM
  #184
RED FURY's Avatar
RED FURY
Man ... that system works ... BUT Rattles !!!!!
Old Apr 25, 2006 | 11:52 AM
  #185
MSFITOY's Avatar
MSFITOY
Did you tighten everything with locktite?
Old Apr 25, 2006 | 12:15 PM
  #186
RED FURY's Avatar
RED FURY
Sure did, my mechanic.... Chad .... did ...the main bar contacts the CAT at times
Old Apr 25, 2006 | 12:17 PM
  #187
MSFITOY's Avatar
MSFITOY
Right...he mentioned using locktite...maybe it's loosened up? I can't imagine that it normally rattle
Old Apr 25, 2006 | 12:38 PM
  #188
maxmini's Avatar
maxmini
What exhaust systems are you using? So far we have not had ANY trouble with stock systems but we have seen issues with both Miltek and the Alta cat backs. We have simple fixes for both but you need to contact us.
Randy
M7 Tuning
Old Apr 25, 2006 | 01:24 PM
  #189
SRTech's Avatar
SRTech
Randy
M7 Tuning
My M7-USS clears the Milltek resonator by about 1/8" and doesn't contact it when hot. I have installed three M7-USSs and none have rattled.
Steve
Old Apr 25, 2006 | 02:03 PM
  #190
SpiderX's Avatar
SpiderX
Randy
M7 Tuning
I have a system coming and I have a Milltek with the header....what is the fix please?
Old Apr 25, 2006 | 02:09 PM
  #191
ATCQL's Avatar
ATCQL
Red Fury,i had the USS installed on my Mini with a Miltek header and catback.The rattle on my car was due to the long brace on the front brace rubbing the header. Easy fix no noise at this time.Q
Old Apr 25, 2006 | 02:10 PM
  #192
ATCQL's Avatar
ATCQL
SpiderX just noticed your post,the fix was to notch out the area that was rubbing.Q
Old Apr 25, 2006 | 02:33 PM
  #193
goaljnky's Avatar
goaljnky
Is that the M7 solution?
Old Apr 25, 2006 | 02:39 PM
  #194
SpiderX's Avatar
SpiderX
Good question?
Old Apr 25, 2006 | 04:03 PM
  #195
maxmini's Avatar
maxmini
There are a couple of fixes but we found the easiest was to " ovalize " the two bolt holes in the triangular black stamped plates which are bolted to the car . If you enlongate them about 1/8 th to 1/4 of a inch forward you can slide the cross bar forward just enough to clear the resonator on the Miltek. As some have noted many do not touch at all but for those that do about 5 min grinding will solve the issue entirely. Of course if you would like to call me before or during the install if you have any questions feel free. Call between 9 am and 11 pm PST if possible
Randy
M7 Tuning
818 497 4341
Old Apr 26, 2006 | 11:30 AM
  #196
62Lincoln's Avatar
62Lincoln
I must say that the difference to me was very noticable... Turn in response feels quicker too...another keeper mod
This sums it up for me, too. Had my USS installed today, and the difference is noticeable immediately. As others have noted, the car seems to ride more smoothly, as though the suspension is now able to more effectively do its job. The car also seems quieter and more stable over bumps. Very impressed.
Peter, you ought to offer the USS with your lowering springs as a package deal, with some sort of package savings. Since I also have your springs, I can testify that the two go together like peanut butter and jelly.
Great job!
Old May 5, 2006 | 07:20 AM
  #197
fafnir's Avatar
fafnir
so does this kit rattle on a stock mini non-s 2006?
and the only tools i need to install this are hand tools and a jack system right?
e.g. i can do this at home right?
thanks
_
Old May 5, 2006 | 08:43 AM
  #198
meb's Avatar
meb
...well, I almost had mine installed; two of those fancy fasteners expanded below the actual hole - in that recess area. The other side worked just fine. When I torqued the allen screw, it popped out...Randy, maybe you should include a couple dozen extra Soooo, gotta wait for some new parts.
Old May 7, 2006 | 08:21 PM
  #199
Gr8Force's Avatar
Gr8Force
Had the USS installed at the Dragon. Simply amazing! Any cabrios that don't get this mod are doing themselves the disfavor of not being able to enjoy their MINI beyond belief. In otherwords, if you doubt the performance of this mod then drive someone's who has it. Then you'll believe.
Old May 9, 2006 | 08:37 AM
  #200
SOCRATES's Avatar
SOCRATES
Ordered mine today along with the Webb Extreme rear sway - can't wait!
