Suspension M7 Under Strut System
Old Feb 20, 2006 | 07:34 AM
  #101
FlynHawaiian's Avatar
FlynHawaiian
After some sleep, I had a chance to re-evaluate my post. not sure I said enough about the uss....
The install was painless on the back two, the front was a little more challenging. I ended up opening up part of one of the holes with a dremel a bit. There are like 2 pieces of metal where the bolt insert goes in. I "flush" mounted the bolt insert, by simply taking off about a .25mm all around the holes until the insert fit perfect. Worked quite well.
After the install, I took the car out on the open road for about 250 miles before attempting to take it to the track to make sure there were no problems or issues.
Before I installed the uss, I was having a wierd problem where, when you gas the "hell" out of the car she was a bit "squirly"... Fixed that. The cornering ability of the car greatly improved quite a bit too. Was amazing to learn that the car sits and goes without any problems.
Over all, the "high speed" tracking and stability of the car have drastically improved about 10 folds. I'm really happy with the product.
Old Feb 20, 2006 | 07:40 AM
  #102
CARdiac's Avatar
CARdiac
Thanx FlynHawaiian. This was a definate for my wife's convertible and now I may get a second for mine....
Old Feb 20, 2006 | 07:46 AM
  #103
FlynHawaiian
wouldn't drive without it now
Old Feb 20, 2006 | 07:57 AM
  #104
///ACS330Ci's Avatar
///ACS330Ci
FlynHawaiian,
Did you take any pics of the install?
Did you enlarge the holes in the M7 USS or the car?
TIA
Old Feb 20, 2006 | 08:03 AM
  #105
FlynHawaiian
on the car, but I was having an issue with the passenger side insert holding. I had one fall out. Talked with some engineer profs and they gave me some good advice. I think my problem was I was over torquing the insert. I didn't take any pictures because it's pretty simple. If you look at the hole and hold up the insert to it, you would understand what I did. I didn't use the washer at all on the passenger side.
See if you look under there, it almost seems like there is an extra piece of metal, like a washer or something there from the factory. I almost think that they planned on using that for something simular at one time, but never did anything with it.
Again, the install is SO simple the pictures that are provided was all I needed. If I can do it anyone can O_o. With all the locktite I put on the bolt, I really don't wanna remove it to take a picture right now :D but if you get under your car and have questions just ask me
Old Feb 20, 2006 | 08:07 AM
  #106
///ACS330Ci
Cool, thanks
Old Feb 20, 2006 | 02:42 PM
  #107
meb's Avatar
meb
Do torques specs come with the instructions?
Old Feb 23, 2006 | 08:53 PM
  #108
///ACS330Ci
I decided to make a couple small modifications to my aluminum skid plate prior to installation of the M7 USS. Worked perfectly and total install took less than an hour including the installation of the skid plate.
I forgot to take pics while I had it on the lift, but I think this pic came out kinda cool
Immediate results were felt. Especially when driving over rough surfaces ... it really surprised me how much of a difference the M7 USS really made during normal driving. Hopefully I'll get a chance to push the car a bit this weekend and I'll post MHO early next week. I have a feeling it's gonna be great
Oh, install tip - have a tap handy to clean out the front two (four if you're installing a skid plate at the same time) theaded holes for the front brace. It'll make your life much easier
Old Feb 24, 2006 | 05:10 AM
  #109
ncdave's Avatar
ncdave
Your modification to the skid plate makes sense. Being a skid plate owner, I'll be taking that road once my USS arrives.
Old Feb 24, 2006 | 07:29 AM
  #110
yumhaggis's Avatar
yumhaggis
Okay people I didn't think I was going to be one of the folks to say "wow" what a big difference I noticed right away . WRONG within 6ft of moving my car under power I could feel the tightness of the chassis, I knew that the very first corner I came to I just had to hit it hot & heavy and all I kept saying over and over was OMG this is so neat what a big differnce, worth every dollar, if you can only afford one change to your handling this is the one to do out of 5
Old Feb 24, 2006 | 07:43 AM
  #111
FlynHawaiian
It's hard to believe that it makes such a drastic change. Many people don't think it would, I've never been happier with the car and it's ability to hold the road a bit better. My car is feeling a bit more manageable day by day
Old Feb 24, 2006 | 07:54 AM
  #112
yumhaggis's Avatar
yumhaggis
It do, it do,
Old Feb 24, 2006 | 09:28 AM
  #113
M7's Avatar
M7
Hehehehe....
I am delighted to hear all the positive responses from you guys....Thank you.
peter
Team M7
562-608-8123
Old Feb 24, 2006 | 06:43 PM
  #114
ncdave's Avatar
ncdave
OK Peter, now I'm getting impatient. When's the next batch shipping?
Old Feb 24, 2006 | 07:27 PM
  #115
M7's Avatar
M7
Oh yeaah.... The next batch
It should be here in less then 10 days give or take a couple of days due to
customs. As the amount of orders have been staggering this shippment is
air shipped and only a limited amouts of units will be available untill April.
And we have a surprise......Black M7 Strut Tower Braces (anodized)
will come in on the same shippment First come, first serve on these
babies.......
We do have a small amount of Ti colored STB's left, but thats it for now.
M7 STB-B Price: $199.00
peter
Team M7
562-608-8123
Old Feb 24, 2006 | 07:32 PM
  #116
///ACS330Ci
babies.......
peter
Team M7
562-608-8123
Peter,
Put me down for one of these too
Steve
Old Feb 24, 2006 | 08:01 PM
  #117
M7's Avatar
M7
Originally Posted by ///ACS330Ci
Peter,
Steve
Call me anytime...
peter
Old Feb 24, 2006 | 09:06 PM
  #118
Rally@StanceDesign's Avatar
Rally@StanceDesign
well.....so much for the "the mini chassis is perfectly stiff the way it is, how could it need braces" theory
sounds like a job well done M7.
Old Feb 24, 2006 | 11:01 PM
  #119
MINIotaple's Avatar
MINIotaple
Better than a Rear Sway Bar?
Old Feb 25, 2006 | 06:27 AM
  #120
ncdave's Avatar
ncdave
Thanks Peter! Looking forward to a birthday project.
Old Feb 25, 2006 | 08:34 AM
  #121
yumhaggis's Avatar
yumhaggis
Good question since I'm running a Mini Madness 22mm bar in the second hole out back and stock up front, Koni sports, set at 80% & BFG/Gforce KDW II's, I don't know. I still think if you had limited funds & could only do one thing to improve handling I'd do the USS it just seems to tie the whole car together. I look at it like putting subframe connectors on the old fox bodied mustangs it just hooks the car up & makes it one piece.
Old Feb 27, 2006 | 10:32 PM
  #122
latte hiatus's Avatar
latte hiatus
Received the last of the first USS batch from World One Performance today (thanks, Jonathan!). I must admit, just like most of the others here, I'm already initially impressed by the aesthetics and quality of the USS.
Hopefully I'll have time this weekend to put it in. Quick question for the M7 guys (or anyone else who cares to chime in) - I would rather use blue Loctite as opposed to red, in the event I need to remove the USS and skid plate to service anything (ie. exhaust). Are there any adverse effects that you can think of, not limited to the potential for the blue Loctite to loosen up over time as opposed to the red?
Old Feb 27, 2006 | 10:44 PM
  #123
maxmini's Avatar
maxmini
There would be no problem going " blue " . You will be the second convertable install and we are looking forward to your review. We think this is going to become a " manditory " item for those topless owners that like to drive with " vigor "
Randy
M7 Tuning
Old Feb 27, 2006 | 11:04 PM
  #124
latte hiatus
Randy
M7 Tuning
Thanks for the quick response! I'm looking forward to installing the USS as well and providing feedback to the community. Beefing up the convertible's chassis and suspension was one of my first priorities, since the SS+ setup is a factory option available only for hardtops.
I'm a little disappointed, though, that most convertible owners are more interested in discussing how often they have the top down than performance mods.
The USS is more of a safety mod than a performance one - the way I see it, I won't stop driving with "vigor," so the USS is a preventative measure against accidents. Knowing myself (and most members of this board), however, it's probably more likely we'll just push the car harder.
Old Feb 27, 2006 | 11:30 PM
  #125
maxmini's Avatar
maxmini
We are all about " quick response " I just checked out your mod list and you have done a nice job there. I have the same tires and you are certainly going to give them more of a workout with the USS . I hope you have a good road nearby that you know well. I think it is going to be a very interesting experience the first time you go back. If at anytime you have a question during the install feel free to call .
Randy
M7 Tuning
