Suspension M7 Under Strut System
Old May 9, 2006 | 01:17 PM
  #201
coolcab's Avatar
coolcab
Originally Posted by SRTech
My M7-USS clears the Milltek resonator by about 1/8" and doesn't contact it when hot. I have installed three M7-USSs and none have rattled.
Steve
I have the Miltek also - have the 1/8 clearance and zero rattles.
This system is awsome! Every Cabrio should have it. Peter and M7 have really turned aout a fantastic product. Tested out on the dragon. It is really worth the $$$$
Old May 21, 2006 | 02:51 PM
  #202
SCMCS's Avatar
SCMCS
Originally Posted by RED FURY
Sure did, my mechanic.... Chad .... did ...the main bar contacts the CAT at times
My USS rubbed a bit on the main bar with the stock cat as well. No issues with the Miltek resonator, has about 1/4“ clearance. To solve the rubbing on the cat I inserted a piece of 1/8” aluminum metal between the cars frame and the front piece of the USS where it bolts to the car in all 4 spots. You could also use some thick washers. It may take a couple of washers or spacers depending on how much contact is taking place, in my case it was very minimal.
My suspension setup now consists of the M7 USS, M7 Strut bar, Webb extreme sway bar, Koni yellows on H-Sport springs and Webb rear camber links. As good and tight as the car was in stock trim it has a entirely different feeling now. Just a flick of the steering wheel and the car responds instantly. I can’t say which part of the suspension made the car come alive as it is now because I did all of them at once but it is awesome now.
Thanks to M7, Webb Motorsports and BBM (they installed everything) for helping me take my MINI to the next level.
Old May 30, 2006 | 01:24 PM
  #203
MiniMargie's Avatar
MiniMargie
Originally Posted by maxmini
What exhaust systems are you using? So far we have not had ANY trouble with stock systems but we have seen issues with both Miltek and the Alta cat backs. We have simple fixes for both but you need to contact us.
Randy
M7 Tuning
we have a Milltek and it's tight. I'm still waiting for direction about how to mount the passenger's side insert, as the hole is too large (my fault) and the insert won't take.
We talked to you and Peter in person at MOTD, PM'ed, emailed, called...still have the same problem and no solution (except being told to buy a larger insert at a hardware store). Help please?
Old May 30, 2006 | 09:00 PM
  #204
M7's Avatar
M7
I am sorry for the perceived no solution, and I am a little confused about the
calls and emails with no answers as we did find an insert size that should solve the problem.
Peter
Team M7
562-608-8123
Size: 1/2"-13 nut insert.
www.mcmaster.com
Type > Thread Size > Compare Items
Nut Inserts, Rivet Nuts, and Rivet-Type Studs
This product matches all of your selections.
Part Number: 95105A169 $10.34 per Pack of 10
Material Type
Steel
Finish
Zinc-Plated
Steel Type
C1008-C1010 Steel
Type
Knurled Rivet Nuts
Thread Size
1/2"-13
For Material Thickness Range
.063"-.200"
Flange Diameter
.865"
Drill Size
11/16"
Body Diameter (A)
.685"
Dimension B
1.150"
Dimension C
.865"
Dimension D
.047"
Dimension E
.860"
Thread Fit
Class 2B
Old May 31, 2006 | 03:33 AM
  #205
MiniMargie's Avatar
MiniMargie
Shelly directed me to Home Depot or Lowes to find something (but didn't give me thread pitch, etc) - I asked for specs - she was supposed to email me, but did not. I did get your email Peter - thank you.
Old Jun 2, 2006 | 11:19 AM
  #206
ncdave's Avatar
ncdave
Finally, my USS has been installed so I'll offer these observations which may not have been covered here:
(1) In light of the problems experienced by others in trying to drill out and install the nut inserts without the benefit of a lift due to ground clearance issues, I wimped out and asked my dealer to do those (lending credence to my observation that they are mod-friendly). I'm happy to report that on January 2003 build Coopers, there were no problems with fit or the shared bolt-hole problem that has been reported as everything went together perfectly.
(2) My Cooper (a non-S) has the 16" wheels with run-flats but not the Sports Plus Suspension. Having driven base Coopers, Coopers with the + suspension as well as S's, the feel of the car is much tighter and I would say it very close to the plus option but not quite as the general compliance of the base Cooper is preserved. I've only taken it out on a few twisties and turn in seems better as the car feels like it's rotating around the driver rather than plowing ahead. Will need to give it a better workout later and report.
BTW, the tech's was seriously impressed with the fit as well as the build and finish quality of the USS as he hadn't seen one before. All-in-all, a worthwhile mod.
Old Jun 2, 2006 | 03:45 PM
  #207
haulinS's Avatar
haulinS
twisty approved!
just took my newly installed USS out to the twisties this afternoon and all I can say is................yyyyeeeeesssssssssssss! I'm all smiles. It compliments the rear H-Sport Comp bar very well.
Thanks to Peter and the M7 Team for putting out another quality product.
Old Jun 2, 2006 | 03:47 PM
  #208
MiniMargie's Avatar
MiniMargie
if anyone fu><ors the right hole for the insert, PM me. I'll have nine extra larger inserts soon (sold in packs of ten).
Old Jun 2, 2006 | 03:54 PM
  #209
SpiderX's Avatar
SpiderX
Originally Posted by SpiderX
in the "for what it's worth dept"..... I just emailed Peter to include this kit with my order for the DFIC and the strut bar .... now if it would stop raining/drizzling so I could go ride my bike (pedal)
An update....this is an excellent mod......car is very tight and the turn in is improved......it instills extra confidence ..... car feels very solid
Old Jun 3, 2006 | 03:30 AM
  #210
skuzy's Avatar
skuzy
jusust wondering.. does this increase/decrease understeer/oversteer or just reduces body roll overall...\
Old Jun 3, 2006 | 07:52 PM
  #211
ncdave's Avatar
ncdave
Understeer seems to have been greatly reduced although I haven't had the opportunity to try it out on a track yet.
Old Jun 3, 2006 | 08:06 PM
  #212
FranticFreddy's Avatar
FranticFreddy
Installed the other week. Have had it out for a couple of rides around the back roads. Oh Yes!!
Did have a little trouble with the inserts, Got two from a friend and cameup with a modification of the tool to install them with. Tightened everything up and away we go.
Old Jun 4, 2006 | 09:22 AM
  #213
rrdusek's Avatar
rrdusek
when i first installed mine, i thought i felt a tiny bit of oversteer. after living with it awhile, it's probably just the much quicker turn-in. i'm amazed at how tight and responsive the chassis is now-total control!
Old Jun 5, 2006 | 04:55 AM
  #214
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
Just out of cutiosity, how much oversteer are we talking? I autocross my Mini in street modified with the mods listed below. As it sits now I got probably too much oversteer. I'm seriously thinking about putting the stock rear bar back in. The USS sounds intriguing, but I don't want to totally goof things up.
Old Jun 5, 2006 | 06:00 AM
  #215
onasled's Avatar
onasled
with all your`suspension upgrades that you have you should be very much able to tune out any oversteer without going back to the stock rear bar.
What are your camber settings, front and rear?
Old Jun 5, 2006 | 06:13 AM
  #216
meb's Avatar
meb
...H-Sport springs are like the Megans, heavier rates out back. This is the correct way to tune a set-up for the track, but I get enough rotation with my stock bar. My Webb bar is not installed yet, but it can bet set softer than stock...
Old Jun 5, 2006 | 06:17 AM
  #217
Veni_Vidi_Vici
I'm running -2.2 front -1.5 rear with 1/8" toe out front, no toe rear. Hsport bars=full stiff front, full soft rear. Koni's= 3/4 firm front, 1/4 firm rear. Interestingly, the major oversteer started when I went from 205 to 225 r-comps. The oversteer is worst under braking. Trail braking=spin.
On the good side, I've developed the perfect Mini drift setup.
Old Jun 5, 2006 | 06:23 AM
  #218
meb's Avatar
meb
...worse under braking...I would tell you to add in some bound if the Konis are double adjustable. This will stabilize threshold braking.
Old Jun 5, 2006 | 06:25 AM
  #219
ingsoc's Avatar
ingsoc
  #220
Veni_Vidi_Vici
Alas, single adjustment only, and even that is a pita on the rears.
Old Jun 5, 2006 | 07:07 AM
  #221
onasled's Avatar
onasled
I would say that 1.5 in the rear is too little with 2.2 in the front with how you have evrything set up. Try and add about .2 -.3 negative in the rear. This should nutralize the oversteer a good amount.
Old Jun 5, 2006 | 07:11 AM
  #222
Veni_Vidi_Vici
I'll give it a try, thanks.
Old Jul 3, 2006 | 05:10 PM
  #223
QED's Avatar
QED
Nice job M7, and install tips....
I've had my USS on for 24 hours and, like the others, I'm glad I spent the money. The car tracks more accurately than before. You need less little corrections on the steering wheel when taking a bumpy corner. It makes the MINI feel more solid, like a more expensive car. I am looking forward to my next track event.
The installation was easy, just follow the instructions, and read the other posts on this thread. Don't be afraid to try this one yourself. The hardest part was getting the car up high enough on jackstands and ramps for clearance to drill the nut-sert holes. In hindsight I wish I would have paid the guy at the muffler shop $20 cash to put the car up on the lift and drill the two holes, and install the nut-serts. In my experience muffler shops like to do this sort of thing if they aren't busy, if it won't take too long, and if you pay them cash. I landed up paying $15 to rent a drill anyway because the bit supplied was 1/2" and my drill is only 3/8".
One more tip: If you have never used the nut-serts before you should know that they need a nice tight hole. The serrations in the net-sert need to dig into the hole you drilled. That's why M7 supplies the right size of drill bit. The first hole I drilled was slightly sloppy (maybe I held the drill at a bit of an angle). I was able to correct this by holding the nut-sert at a slight angle to start it (so it didn't spin) and then straighten out the nutsert as it tightened.
All in all it is a good product - beautifully made, easy install, works as advertized.
Old Jul 3, 2006 | 06:29 PM
  #224
maxmini's Avatar
maxmini
I am glad it worked out for you and thanks for the detailed post. I do want to mention that because you really need to run that drill bit thru one time and as straight as possible you did incur the usual problem with trying to do it on jack stands. As you said the $20 would have been well spent atthe muffler shop. Our local instal center charges $ 60 for the whole project so it is really not a big deal. Very creative way to make up for the " sloppy " hole. Perhaps that will help others as well. Thanks again and wait till you get it on the track
Randy
M7 Tuning
Old Nov 16, 2006 | 07:43 AM
  #225
Ranzo's Avatar
Ranzo
So this is what I need to do if it keeps coming loose?
Front Brace left outside corner...
Peter
Team M7
562-608-8123
www.mcmaster.com
Material Type
Steel
Finish
Zinc-Plated
Steel Type
C1008-C1010 Steel
Type
Knurled Rivet Nuts
Thread Size
1/2"-13
.063"-.200"
Flange Diameter
.865"
Drill Size
11/16"
Body Diameter (A)
.685"
Dimension B
1.150"
Dimension C
.865"
Dimension D
.047"
Dimension E
.860"
Thread Fit
Class 2B
