Suspension Who had problem with Rubbing on H-Sport springs?
If you have problem with rubbing, what was the offset and size of your wheels? What tires were you using? How much trimming did you do?
I currently have 17x7 wheel with a +36mm offset on stock height and with 215/40/17s I have way too much space between the fender and the tire..
So I just order a set of H-sport springs and would like to know how serious the rubbing is going to be.
I think it will depend on what brand & type of tires you run but wheels with an offset of 36 is pushing it. From what I have read between 40 and 45 is best. But what do I know, my car isn't lowered, yet :smile:
With +36mm offset you will likely rub in the rear so trim the inside upper rear edges of the inner wheel well with a dremmel. Probably it will only be slight rubbing since you have 215/40-17 tires which are not as large as stock tires.
Just a little update to a thread I started.
Got H-Sport springs installed yesterday.
Rear looks like it is already settled and no rubbing so far.
How long for them to settle fully?
Currently the front still has the wheel gap, but the rear is gone
Wheels are 17x7 +36mm offset.
Tires are 215/40/17
Tires are 215/40/17
Originally Posted by kenchan
you won't rub on factory wheels unless you get some 225 width tires mounted or something.
I'm curious, why do some of you good kind folk run 215/45s? This is not a correct size for the Mini if you are following pure plus sizing. I could predict rubbing problems with this tire size when paired with a lowered car. This is a taller tire - hurts acceleration, it is potentially heavier, hurts acceleration and braking.
Again, just curious, not passing judgement.
Kumho (712), Yokohoma(ES100) and Michelin Pilot (Exalto) have Ultra Performance tires available in the size 205/45/17.
I've used all three, the latter is currently on the Mini. I've driven 230,000 miles on the first two - 100K +/- on each, and 1,000 miles on the Exalto. All three are perfect for daily driving and occasionaly DE events. These are not Max performance tires, nor are these snow worthy. The first two are extremely economical but become noisy and distorted after 30K miles or so becasue of their un-directional pattern; they can only be rotated front to back. I chose the Michelin hoping to avoid this problem. The Michelins are better in some areas and not so good in others...but I'll give these another 1,000 miles before making a black and white comparison.
Your car won't rub using a 205/45/17 unless you drop the ride height too far...duh!
meb- you forgot to list that they are too "meaty" looking. :smile:
205/45-17 is the OEM size but few tires are easy to get depending on where you live. In my area this size is not being stocked by any retail sources for non runflats. The dealership is willing and able to sell runflats at retail prices.
So we can then choose for 205/45-17 via mail order but still the selection is much more limited than if we use 215/40-17 or 215/45-17. Doesn't mean there are not some good tires in 205/45-17 but much less to choose from.
215/45-17 is slightly tall (more chance for rubbing if you lower your car) and 215/40-17 is slightly shorter than stock which means harder riding (40 series) and less load rating than stock.
Some lowered MINIs will not rub with 215/45-17 or at least minimally so. H-sport offer a 1" drop so there is risk for rubbing. More lowered and you'd get more chance for rubbing. With a coilover suspension you can adjust to just the right level to avoid rubbing.
Hopefully more and more tires will be available in 205/45-17. It's actually quite a good size for normal street use.
devicemanager
Jun 17, 2016 06:18 PM
melscoop
Mar 30, 2016 06:56 PM
. I got that extra set Randy had.
