Suspension To Lower or Not?
Old Feb 22, 2005 | 01:10 PM
lancelinks's Avatar
lancelinks
To Lower or Not?
Hey Team,
I gots the urge to mod and the spouse let a few bucks free. Already have ordered my cold air intake and I'm comin at you guys/gals on your thoughts/experiences on lowering the mini. I'm lookin at the Alto Sport Springs?
tanks
LL
Cooper/PS/B
Old Feb 22, 2005 | 01:13 PM
AliceInWonderland's Avatar
AliceInWonderland
Lowering?
I lost most of my clearance switching from run flats to low profile hi-performance. I guess you could lower it and put little rollers on the ground effects or just wait for the ground effects to wear off.
Old Feb 22, 2005 | 01:25 PM
Rick-Anderson's Avatar
Rick-Anderson
You might want to consider the M7 springs. They are awesome and the ride is MUCH better than stock!
Old Feb 22, 2005 | 02:51 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
And I have a spare set we decided not to use. ( NEW )
pm me if you are interested.
Old Feb 22, 2005 | 05:28 PM
lancelinks's Avatar
lancelinks
Detl,
Yes, I am interested. Are these the M7s? Price?
thanks
LL:smile:
Old Feb 22, 2005 | 07:55 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
Yep m7 springs, we bought them for our cooper and decided to leave the entire car stock ( other than wheels )
I will let them go for $180 + shipping. They are new and still wrapped in the plastic.
Old Feb 22, 2005 | 08:03 PM
wkndracr's Avatar
wkndracr
I had H-Sport springs on my '03, and I loved the look, but the ride did get a little more bouncy, with the stock struts. That said, I would probably do the same on my 05, but this one is staying in stock class for autocrossing.
Old Feb 22, 2005 | 08:34 PM
kenchan's Avatar
kenchan
My H-Sport springs and rear swaybar combination has kept bringing me smiles each time I take a fast corner (very fast).
Old Feb 22, 2005 | 08:58 PM
milehighMCS's Avatar
milehighMCS
I agree!
Put in the H-sports springs and sway myself. I think it really improves the ride and handling
Plus, as it was explaned to me, the stock springs are linear and the H-sports are progressive. I know, I know, a linear SPRING?! But I can tell the difference!
I have scraped the front end a couple of times. I need those skid pads that the sportbike racers use
Old Feb 23, 2005 | 05:10 AM
MarkS's Avatar
MarkS
More physics! A spring is linear if it always takes a given force to compress or stretch it a given distance, regardless of how much it's already compressed or stretched. Hooke's Law says that the force to compress a spring is equal to its spring constant times the amount of compression or stretch: f = -kx. The negative sign is there because the force is in the direction opposite the compression or extension. For example, if the spring constant is 100 lbs/in, it'll push back with a force of 100 lbs if you compress it an inch.
A progressive spring, like the H-Sport, has a spring "constant" that changes with compression and stretching. For example, it might take 100 lbs to compress it the first inch, but 120 lbs to compress it the second inch. (Not actual values for the H-Sport). The result is the spring is more cushy for small vertical motions but is stiffer for big ones, the idea being that it rides reasonably well but doesn't bottom-out on big bumps.
Since I'm getting the H-Sports soon, we'll see how it works in practice. Glad you like yours!
Mark
Old Feb 23, 2005 | 07:09 AM
Pat_Cooper's Avatar
Pat_Cooper
Wont using the M7 springs cause your shocks to wear out faster?
I want to lower the car aswell but I don't want to get a coilover setup.
Old Feb 23, 2005 | 07:14 AM
Brain1.0's Avatar
Brain1.0
Manufacturer
I cant answer for sure that they will wear out faster or not but I would say if they do it wont be by that much. Worst case is you could replace the stock shocks/struts later with an aftermarket shock/strut. You would never HAVE to switch to coil overs.
Old Feb 23, 2005 | 07:17 AM
Pat_Cooper's Avatar
Pat_Cooper
All my buddies are telling me I definately have to drop it once I get my rims (OZ SuperturismoGT's). I am going 17, but I had nightmares with my last car due to lower springs. The ride was AWFULL. This ride is ruff already. I enjoy a stiff suspension but not a sloppy ride. Oh the choices we have to make....
Old Feb 23, 2005 | 07:23 AM
DrkSilvrMini's Avatar
DrkSilvrMini
I have the ALta springs on my car . Ride is good and looks good too. Next step is the sway bar which will be soon. But in answer to you question......lower it .
Old Feb 23, 2005 | 07:43 AM
lancelinks's Avatar
lancelinks
Drkslver,
Thanks for that validation. I still think I'm going for the Altas.... I can get em for $150. Will I need the sway bar? I have a reg cooper with suspension +. Also, how are you managing the 1.5 inch drop in front? I hate to scrape!
LL
smdmini
Oct 7, 2019 06:05 AM
massmini03
Sep 18, 2015 05:40 PM
hydouken
Sep 15, 2015 05:49 AM
Accessory Products
Sep 9, 2015 10:29 AM
Sep 2, 2015 11:15 AM
