Suspension Coilover Rebound Adjuster from Inside Boot
Old 11-29-2012, 01:28 PM
countryboyshane's Avatar
countryboyshane
countryboyshane is offline
Has anyone seen some kind of tool (or made one) to permanently mount in the boot of their MINI to adjust rebound settings on their coilovers? I want to drill as small of a hole as possible to access the top of the damper but don’t necessarily want to reinvent the wheel. I’m not sure if a really long 2mm allen key will reach the top of the damper if I drill a hole. I know I’ve seen these at the track on some Mustangs and Vettes with these long springy adjusters that are elegantly positioned in the trunk. BTW, I have KW V2 coilovers.
Taking the damper out every time for adjustment is just silly when you can just open your boot and fiddle with a small adjuster on the inside.
Old 01-07-2013, 07:54 AM
xeducatorx's Avatar
xeducatorx
xeducatorx is offline
I have my adjusters in the trunk/boot. Megan Racing came stock with these lengthy adjusters. You may be able to find something that can attach to your KW's that does the same thing. I know they exist, just don't know who makes them and what brands they're compatible with.
Old 01-07-2013, 03:44 PM
mbwicz's Avatar
mbwicz
mbwicz is offline
I don't know how much torque it would take to adjust your shocks, but I would worry that a 6" or 9" wrench would torque too much to give you an accurate amount of adjustment. look at mcmaster.com, page 2842 for a heavier duty option.
I would think that you could find some plastic or rubber plugs to fill a larger hole, if you are worried about it. Maybe you could find some flat black plastic dots at a craft store to cover the hole.
I assume that you would drill the hole from underneath? After a hole from the bottom, a unibit would do a nice job of deburring the top of the hole, as well as making a round hole.
Good luck, and have fun.
Mike
Old 01-07-2013, 04:22 PM
Scooter09's Avatar
Scooter09
Scooter09 is offline
I am curious about this as well.
Old 01-08-2013, 04:29 AM
countryboyshane
I drilled some pilot holes when I had the rear coilovers out this winter. The distance between the top of the coilover adjuster and the interior sheet metal doesn't seem to be that far apart. Maybe an inch or two. Now for the hole saw...
Old 01-08-2013, 10:49 AM
mbwicz's Avatar
mbwicz
mbwicz is offline
I would start with an 1/8" drill, then you can pick and probe to see how close you are to the lower hole. Most hole saws use a 1/4" pilot. Are you planning on leaving the hole open, or plugging it? I would use a unibit, they cut round holes in sheet metal, and generally can cut through the vinyl or plastic without tearing it.
Good luck, let us know how it turns out.
Mike
Old 01-11-2013, 11:32 PM
Scooter09's Avatar
Scooter09
This is what I just did:
I used a 3/4 socket extension with some tape wrapped around it so it was tight when I fit it through the dampening pad.
I put a bit of red plasti-dip on the end and slid it through and made s mark on the underside.
Then I took a 2mm ball end Allen and swapped out the one in the dial that came with the KW kit.
I have a Coupe, so thus is how I can access it without being too intrusive. Just taken out the tabs and pulling the panel out, the grey box needs to come out on the passenger side too.
I also modified my jack holder to hold the KW Kit parts.
Attached Thumbnails Coilover Rebound Adjuster from Inside Boot-image-2944900444.jpg   Coilover Rebound Adjuster from Inside Boot-image-2554881909.jpg   Coilover Rebound Adjuster from Inside Boot-image-2694000807.jpg   Coilover Rebound Adjuster from Inside Boot-image-1853560702.jpg   Coilover Rebound Adjuster from Inside Boot-image-226088557.jpg
Coilover Rebound Adjuster from Inside Boot-image-852659065.jpg   Coilover Rebound Adjuster from Inside Boot-image-2240382433.jpg   Coilover Rebound Adjuster from Inside Boot-image-2409262172.jpg   Coilover Rebound Adjuster from Inside Boot-image-3060581225.jpg   Coilover Rebound Adjuster from Inside Boot-image-1770142531.jpg
Coilover Rebound Adjuster from Inside Boot-image-1958645442.jpg   Coilover Rebound Adjuster from Inside Boot-image-4229110583.jpg   Coilover Rebound Adjuster from Inside Boot-image-883941697.jpg   Coilover Rebound Adjuster from Inside Boot-image-2308406650.jpg
The following 2 users liked this post by Scooter09:
greystone (06-26-2021), jk6672 (01-03-2020)
Old 01-22-2013, 08:49 PM
zcast's Avatar
zcast
zcast is offline
That's a great idea Scooter. I have been in the hunt for coilovers for my R58 and I think the KW's are what I want to get. Did you get the V1 or V2..? How does the car sit and ride? I would love to see some photos.
-Z
Old 01-22-2013, 08:55 PM
Scooter09's Avatar
Scooter09
-Z
I got the V2 and they ride great. It's hard to explain, they're stiffer than stock, even on the softest setting, but the rebound is more smooth, so it feels better. It sits great.
This is the only picture I could get to post.
Attached Thumbnails Coilover Rebound Adjuster from Inside Boot-image-2223655663.jpg
Old 01-22-2013, 08:58 PM
zcast's Avatar
zcast
zcast is offline
Are you riding on the softest setting for your DD then? What about ride height? I hear at their highest it's about 2 fingers. Looks like you are lower than that. No issues running soft and low? I worry about my front lip on my JCW.
Old 01-22-2013, 09:03 PM
Scooter09's Avatar
Scooter09
I have it at the softest in the back with a stiffer rear sway bar and 5 turns from the softest (out of 20) in the front. I had some rubbing from the height in that picture, so I brought it up about 3/8". It's really bumpy in Hawaii, so I have it soft so I don't rattle my teeth out. I plan in stiffening it up and lowering it back down after I leave here.
Old 01-24-2013, 03:40 PM
TheSuspensionSource's Avatar
TheSuspensionSource
TheSuspensionSource is offline
Very smart idea Scooter09. I never thought of modifying the ****. I will make sure to pass this thread along to others!
67morris
12-01-2015 12:53 PM
Ryan Caballo
09-10-2015 10:10 AM
RIchard Nguyen
09-06-2015 07:21 PM
Sailorlite
09-04-2015 07:03 PM
Ryan Caballo
09-04-2015 12:20 PM
Quick Reply: Suspension Coilover Rebound Adjuster from Inside Boot
