Suspension Aftermarket rear swaybars
Old Aug 16, 2012 | 11:32 AM
Jollynut's Avatar
Jollynut
Hi MINIacs,
I had an aftermarket rear sway bar installed on my 05 MCS about 5 years ago. It now needs replacement bushings. At the time, it was 'THE' upgrade sway bar to use.
Can anyone give me some brands of aftermarket sway bar so that it might jolt a memory of which one I have, and therefore which replacement bushings to order?!
Thanks all, Happy Motoring.
Old Aug 16, 2012 | 11:40 AM
andyroo's Avatar
andyroo
it doesn't really matter...the bushings should be identical in shape for most brands, you just need the right size (probably 19mm diameter).
Old Aug 16, 2012 | 11:54 AM
Jollynut's Avatar
Jollynut
Thanks - I asked because the garage where they found that the bushings are worn told me that they didn't know where to find the correct replacements, so I figured that I would have to find out the correct brand and replacements.
Old Aug 16, 2012 | 11:58 AM
andyroo's Avatar
andyroo
Waymotorworks can source them for you. He'll probably try to sell you the very nice h-sport brackets with poly bushings that have a zerk fitting so you can grease them (though a properly installed bar with greased bushings and/or teflon tape won't need them, it's nice to have). You should measure your swaybar diameter just to be sure what you need. It's probably a 19mm.
- drew
Old Aug 16, 2012 | 01:55 PM
ZippyNH's Avatar
ZippyNH
Do you know the color?
Alta is red...
Ireland eng is blue..
Most others are black/dark grey...
H-SPORT,.
H&R
..TSW (texas speed works((now owned by waymotorworks))
Heck many others...diameter is important...18, 19, 20. Even 25 mm hollow bars are around...
Old Aug 16, 2012 | 06:35 PM
Jollynut's Avatar
Jollynut
Alta is red...
H-SPORT,.
H&R
H-Sport rings a bell - maybe that's it??!!
Are you the Zippy who used to have Zippity??
I'm the Jolly who still has ZipMore!!!
Thanks for the help guys, I really appreciate it.
Old Aug 16, 2012 | 07:02 PM
leaf_fan_1988's Avatar
leaf_fan_1988
Is a rear sway bar really a big improvement? Maybe I'm not driving it hard enough lol but I don't feel the need for an upgrade. What changes if I do go for it?
Old Aug 16, 2012 | 07:23 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If you post a pic of it I should be able to tell you what brand it is.
Old Aug 16, 2012 | 07:27 PM
Da_Ghost's Avatar
Da_Ghost
As a reference, this is my HSport, it comes with new bushings with ''grease nipples' on the brackets'. Don't know if they had those 5 years ago tho.
Honestly, I can say that a rear sway bar is the equivalent on handling of what the s/c pulley is for the engine. On some entrances, I lift one of the rear wheels since it's a lot stiffer. Swaybars like HSports have 3 holes for stiffness: kind of stock, better and holy ****! Just kidding, I'm on the second hole, didn't tried the last one as I'm pretty happy with how it handle.
Old Aug 16, 2012 | 07:40 PM
Jollynut's Avatar
Jollynut
Thanks very much - I will take a photo as best I can of the bar tomorrow.
Old Aug 17, 2012 | 11:13 AM
Jollynut's Avatar
Jollynut
With the car only on the ground, I can only get a shot of the end of the swaybar, but it's fairly clear.
I guess it uploaded as a thumbnail on my post, but if you click on it, you can see it bigger.
Could it be an H-Sport?
If so, which bushings should I order?
Thanks again for the help guys.
Old Aug 17, 2012 | 04:33 PM
Da_Ghost's Avatar
Da_Ghost
Looks like an H-Sport to me. Probably a 19mm, so you would need the bushings for that one (unless they are the same for the 22mm version).
Old Aug 17, 2012 | 06:31 PM
WayMotorWorks
Vendor
that is def an Hsport comp rear sway bar. Here are the bushings you need:
http://www.waymotorworks.com/swaybar-bushing-set.html
Select the 25.5mm set and you'll be good to go.
Old Aug 18, 2012 | 07:30 AM
Jollynut's Avatar
Jollynut
Thank you SO much.
Ordered!!
Old Aug 20, 2012 | 09:26 AM
WayMotorWorks
Vendor
Shipped them this morning.
woodstudio
Mar 15, 2020 08:28 AM
SunnySideUp
11
Aug 26, 2015 06:42 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
tag1260
Aug 5, 2015 04:27 AM
