Suspension Best shock/struts with JCW red springs
Hi all. I apologize if this has been covered but I did a search and couldn't find anything definitive. Just picked up a 2011 MCS with standard suspension, 17" R98 wheels and Dunlop run flats. I like the way the car handles, but I would like to squeeze a little more potential out of it.
My plans include a rear sway bar, but I was also considering upgrading the springs and dampers. A forum member is selling JCW red springs from his 2011 and from what I read they only provide about 10mm drop which is perfect as I am not looking to lower the car for appearance sake, just improved handling.
I have three main questions:
1 - I understand that these springs are VIN specific based on options so am I making too big a leap of faith in assuming that if his car is optioned out similarly to mine that they should work no problem?
2 - Are there folks out there running non OEM shocks/struts with these springs and if so which ones seemed to be best matched to the spring rates?
3 - Am I missing an aftermarket spring that will deliver similar performance and ride height difference?
Thanks in advance for the help!
I agree with andyroo. This is a great street setup. IMHO people sometimes get a little overzelous trying to make their ride a track setup and then drive it primarily on the street. Usually it doesn't do either very well.
The only thing I would add is some bolt on bracing besides wheels and tires.
Steve
Steve
Yup. The rear Konis have their own built in perches, just like stock. The fronts you have to hammer off the OEM strut with a rubberized mallet or something similar and you slide them onto the front Koni strut.
on
Going today to install Koni Yellows, the shaft on the Konis is bigger than the OEM and obviously the " bell shaped housing which sits atop the spring" has to be drilled out the mathch the Koni shaft.
Anyone done this and had any problems etc?
Will I have a similar problem installing the front shocks?
-Steven
on
I set mine a quarter turn past the middle setting, front and rear. I'm getting a pretty quick/abrupt return on decompression on the rear. I think go towards the softer side, especially since you are mainly a daily driver. Setting the fronts to a more firm setting is easy and the adjustments can really be felt. I'm really happy with these. I will pull the rears one more time and try a softer setting.
-Steven
on
07-16-2020 12:54 PM
08-12-2015 01:24 PM
