Suspension OHLINS installed on the R56 !!
Old Feb 15, 2016 | 06:57 PM
  #201
JPMM's Avatar
JPMM
I have 235's on 7.5's with swift springs and only rub in a very once in a while
Old Feb 15, 2016 | 09:40 PM
  #202
edwkmho's Avatar
edwkmho
Appreciate your help, squawSkiBum & Eddie07S.
I will have a go raising the height this weekend.
Many thanks.
Old Feb 15, 2016 | 09:41 PM
  #203
edwkmho's Avatar
edwkmho
what profile of tire are you using JPMM? i guess must be 40.
Old Feb 16, 2016 | 06:33 AM
  #204
JPMM's Avatar
JPMM
235/40/17 with swift springs
https://www.northamericanmotoring.co...r-dsc01326.jpg
Old Feb 16, 2016 | 06:44 AM
  #205
edwkmho's Avatar
edwkmho
JPMM, what is your ride height ? it seems very close to my set up
Old Feb 16, 2016 | 06:50 AM
  #206
JPMM's Avatar
JPMM
I forgot how much the swift springs lowered the car, I probably read it here or the info is out there somewhere. I'm guessing an inch? Anyways I will hopefully raise the car up a little with the Ohlins to stop the car from rubbing( just a little, never saw any damage) with it loaded up with a passenger and stuff over bad bumps.
Old Feb 16, 2016 | 06:21 PM
  #207
edwkmho's Avatar
edwkmho
My setup was about 1 inch from tire to wheel arch (plastic) for front and rear. When i am with one passenger everything okay but full load (3 passengers) rear will rub over bad bumps.
I will try to raise another 0.5 inch to be safe, what do you think?
Old Feb 20, 2016 | 09:21 PM
  #208
edwkmho's Avatar
edwkmho
hey Guys,
Thanks for the advise on how to raise the ride hight. Managed to get it done today. I have setup to the standard preload from Ohlins and the measurement from right to left a few mm different, what is the best way to tackle this minor issue. Or is it okay to left?
Below is the measurement on my ride now?
Front Right - 635mm
Front Left - 640mm
Rear Right - 655mm
Rear Left - 650mm
Thanks.
Old Feb 21, 2016 | 06:47 AM
  #209
Eddie07S's Avatar
Eddie07S
Quite the meatballs on that car
What wheels and offset? (sorry if I missed it)
From my experience your setup would not work with the optional MINI sports springs and shocks. The 225/45/17 R888s rub on the inside of the wheel well arch with 7" wide rims and 45mm ET. I know, this a OHLINS thread, but I toss this out there for consideration as rubbing is probably as much a function of spring and shock stiffness, as it is tire width, rim width and offset. The sports suspension is probably softer than yours, hence the rubbing issue I have.
Old Feb 21, 2016 | 08:32 AM
  #210
JPMM's Avatar
JPMM
the wheels are forged Rays 7.5" not sure of the offset.
Attached Thumbnails OHLINS installed on the R56 !!-rays-wheels-img_20111001_132839.jpg   OHLINS installed on the R56 !!-rays-wheels-2.jpg
Old Feb 21, 2016 | 09:53 AM
  #211
Eddie07S's Avatar
Eddie07S
Very sharp looking wheels
The tag says "OF +40"...seem that might be the offset?
Old Feb 21, 2016 | 10:13 AM
  #212
JPMM's Avatar
JPMM
yes I believe so
Old Feb 26, 2016 | 07:05 AM
  #213
edwkmho's Avatar
edwkmho
Hey Guys, urgent help needed.
I have reset my Ohlins coil-over to the factory default ride height, where the front with 10mm and the rear 26 mm. Unfortunately this had result inconsistent ride height on my left and right. Has anyone experience this? is this a problem with the coil-over?
Old Feb 26, 2016 | 07:20 AM
  #214
JPMM's Avatar
JPMM
Yikes, maybe I should send my Ohlins back to Sweden
Old Feb 26, 2016 | 08:23 AM
  #215
Systemlord's Avatar
Systemlord
You must measure the springs from spring perch to spring perch to get the preload correct, I never heard of a bad Ohlins shock as the quality of these shocks is unmatched, NASA couldn't do better! I have however heard of user error.
Are you using the proper torque and strut nut sockets on the front shocks? If you're not then your shaft is spinning when you're torquring down you shock nuts.
Old Feb 27, 2016 | 02:23 AM
  #216
edwkmho's Avatar
edwkmho
i am terribly sorry for my stupidity. The ground in front of my house wasn't even. there is a slight slope and gradient. When i drove my car to a flat ground and re-measure it came out all good with the right and left matching each other. Thanks for the advice.
I do agreed that the coil-over is top notch and it does produce the consistent result. Thanks for all the help guys.
Old Feb 27, 2016 | 05:38 AM
  #217
JPMM's Avatar
JPMM
got mine yesterday!
Attached Thumbnails OHLINS installed on the R56 !!-dsc04545.jpg   OHLINS installed on the R56 !!-dsc04567.jpg   OHLINS installed on the R56 !!-dsc04557.jpg   OHLINS installed on the R56 !!-dsc04548.jpg   OHLINS installed on the R56 !!-dsc04561.jpg
Old Mar 8, 2016 | 04:05 AM
  #218
edwkmho's Avatar
edwkmho
Great, JPMM
You have the same set of wheels i am usingbut a different color. I love those wheels.
Old Mar 8, 2016 | 06:20 AM
  #219
JPMM's Avatar
JPMM
Great, JPMM
they were a bucketlist item for sure
Old May 6, 2016 | 11:11 AM
  #220
loifs8's Avatar
loifs8
Anyone know if these Ohlins will fit an R60?
Old May 6, 2016 | 01:06 PM
  #221
squawSkiBum's Avatar
squawSkiBum
Moderator
Since the R60 is significantly heavier and has different suspension geometry I doubt it. You'd need different springs for sure. www.ohlinsusa.com only shows R50, R53, and R56 applications.
Old May 6, 2016 | 01:17 PM
  #222
loifs8's Avatar
loifs8
These spring rates (70 and 50 N/MM, F and R respectively) seems to match pretty well with some other coil overs for the R60 though. So i guess like you said its all about suspension geometry. But if the attachments are the same I would think it would be doable.
Old May 7, 2016 | 06:21 PM
  #223
squawSkiBum
Moderator
Out of curiosity I looked at realoem.com to see if there were any common parts. The top mounts front and back are common to the R56 and R60, but you'd have to check if the strut length and diameter are the same, and what effect lowering the car would have.
Old May 27, 2016 | 03:26 PM
  #224
JPMM's Avatar
JPMM
Need Ohlins setup help
Got the Ohlins setup installed , I was hoping to reduce the harshness of uneven payment at speed in the Midwest. They seem to be better than what I had but there is still a pretty good jolt sometimes. Is there any recommended settings to help reduce the sharpness? It seems suspension settings can be counter intuitive.
Old May 28, 2016 | 11:19 AM
  #225
Systemlord's Avatar
Systemlord
It's difficult to remove all harshness because the Ohlins coilover system will not have any compression on light bumps as the shaft will not have any movement whatsoever unless you hit a moderate bump or imperfection on the road.
I have found that lowering my tire pressure from 38 to 34 psi makes all the difference in the world with regard to ride comfort!
