Suspension OHLINS installed on the R56 !!
Old Sep 17, 2014 | 04:00 PM
  #101
nekky's Avatar
nekky
Originally Posted by ra2fanatic
When did you see my MINI???? Battle Tuning can probably take the order for you.
At LTMW back on January 27th, 2014 or so... I was checking out the shop while in LA visiting family. At least I think that's your car, right???
Originally Posted by squawSkiBum
Nekky - For the Ohlins definitely shop around, there is huge variation in pricing. I ordered through coilover-store.com, they don't list applications for the R56 on their website but when I inquired via email they responded quickly with a very attractive price. They direct shipped from Ohlins. Apparently I got the last set in the USA at the time, the next batch doesn't arrive until October.
Vorshlag camber plates are the same pricing everywhere, so pick your favorite vendor to order or go direct to Vorshlag. They get built to order and shipped direct from Vorshlag. I ordered through outmotoring.com, great customer service, 5% NAM discounts, and free shipping to lower 48 for orders over $195.
I also ordered new "hats" for the rear along with Powerflex shock mount bushings from ECS Tuning. That makes the install really easy as you can put together the whole assembly on the workbench and then just swap. No dealing with a spring compressor to re-use the mount and bushing.
Cool. I think I have a pretty good quote from Evasive already through a friend. Thanks for the info!
Can you point me to the bushings and hats for the rear? I too would like a swap in setup.
Old Sep 17, 2014 | 08:15 PM
  #102
squawSkiBum's Avatar
squawSkiBum
Moderator
For my 2012 R56:
Rear Shock Mount Left
  • Mfg Part# 33526754123
  • ECS Part# ES#58447
Rear Shock Mount Right
  • Mfg Part# 33526754124
  • ECS Part# ES#58448
Those come with the Mini top bushing, unfortunately you can't oder just the metal part though the Mini bushing is available separately. I replaced the bushings:
Powerflex Rear Shock Top Bushing Set
  • Mfg Part# PFR5-115X2
  • ECS Part# ES#2651636
I think they apply to all R56 years but don't take my word for it, check and make sure these are the correct parts for your year/model.
Old Sep 18, 2014 | 05:39 AM
  #103
For my 2012 R56:
Those come with the Mini top bushing, unfortunately you can't order just the metal part though the Mini bushing is available separately. I replaced the bushings:
Yep those are it for all years R56. I added the black linked to the rear polys as a option. Performance is softer then Race ( black series ), which most people prefer unless full out track only car.
Old Oct 30, 2014 | 05:02 AM
  #104
whrisk's Avatar
whrisk
i am finally getting my ohlins tomorrow, i cant wait. its been over 3 months since i ordered it.
Old Oct 30, 2014 | 06:41 AM
  #105
jkapinos's Avatar
jkapinos
You'll love them. Living in Fla you'll have lots of time to enjoy.
Old Oct 30, 2014 | 06:49 AM
  #106
whrisk's Avatar
whrisk
oh yeah for sure. installing them on saturday, then i have an autox on sunday to set them up. feels like Christmas tomorrow, lol
Old Nov 3, 2014 | 08:39 AM
  #107
whrisk's Avatar
whrisk
Had a fun weekend getting used to the Ohlins. Didn't get too much setup done, I didn't realize my race tires had been corded from the last event. Put the corded tires in the rear but I just could not get any grip from them. Rear of the car was all over the place. I can tell that the car is going to be awesome when i dial these things in. So much grip now, and i was surprised how smooth they are on the road when you soften them up. I would recommend these to anyone looking for a street and track compromise.
Attached Thumbnails OHLINS installed on the R56 !!-image-159858329.jpg   OHLINS installed on the R56 !!-image-2639999641.jpg   OHLINS installed on the R56 !!-image-2456240742.jpg
Old Nov 3, 2014 | 09:45 AM
  #108
ra2fanatic's Avatar
ra2fanatic
Ohlins are very soft and even with the 25mm swaybar you have, it still needs to get a bit stiffer to really keep it planted.
Old Nov 3, 2014 | 05:34 PM
  #109
whrisk's Avatar
whrisk
I am going to keep it the way it is for a bit. I am not looking to build another street able race car again, I already had one of those. I am going for a race able street car. I only do about 15 autocrosses per year, and maybe 2 track days when I get the car ready. I am competitive at local autocrosses so I am fine with that for now.
These coil overs seem to be a very good compromise out of the box. Maybe in a little while I will fool around with some different spring rates, but for now I do not want to sacrifice comfort. I think that was the idea behind the "Road & Track" kit. It's not a full out race suspension.
Old Nov 3, 2014 | 05:59 PM
  #110
ra2fanatic's Avatar
ra2fanatic
Correct, it is a compromise worth having it was only a note I figure to throw out there since there have been those that complain about how soft they are out of the box compared to other setups for similar pricing that are stiffer. I went with a slightly stiffer setup and it has been a better compromise.
Old Nov 4, 2014 | 05:14 AM
  #111
whrisk's Avatar
whrisk
how much stiffer did you go? how is it for daily driving?
Old Nov 5, 2014 | 12:04 AM
  #112
Systemlord's Avatar
Systemlord
When you say there soft do you mean the springs? Could it be softer than compared to the stock suspension?
Thanks ra2fanatic!
Old Nov 6, 2014 | 03:17 PM
  #113
ra2fanatic's Avatar
ra2fanatic
When you say there soft do you mean the springs? How would you rate the stock suspension on the R56 MCS? Could it be softer than compared to the stock suspension?
Also have another question, how often does one need to have these shock rebuilt?
Thanks ra2fanatic!
Yes, the springs. How would I rate the stock MCS suspension....?....horrible. Stock Ohlins are what the MINI should have come with. Rebuild...idk, I've put over 30k and feels fine to me still. I might get them rebuilt next year when I have some time, but for now, they don't seem to feel any different from when I put them on.
Old Nov 6, 2014 | 03:19 PM
  #114
ra2fanatic's Avatar
ra2fanatic
Feels fine. You can't slam the Ohlins because then you'll hit the internal bumpstop, so my ride height is as low as you can go in the Ohlins.
Old Nov 6, 2014 | 08:06 PM
  #115
Systemlord's Avatar
Systemlord
A few more questions before I make the final decision, do you guys find your MCS leaning in the direction towards the outside of a turn when performing lightening quick lanes changes to the left or right? I know buy the Ohlins already you'll love them, I just want to have an idea of what to expect from the Ohlins Road & Track coilovers. I already have the Hotchkis 25.5mm RSB.
I'm also trying to find a review of the Ohlins Road & Track review I read in a magazine, it featured a BMW for the testing/review.
Thanks.
Old Jan 31, 2015 | 10:30 PM
  #116
Systemlord's Avatar
Systemlord
Can anyone confirm if there are still noises (posted in previous post) with those that have driven with the Öhlins Road & Track Coil-over System?
I'm also trying to find out how much softer the Öhlins yellow springs are when compared to the stock suspension (Not stock sport suspension) on an 07 MCS?
Are the R&T kit easy to assemble?
Regards,
Systemlord.
Old Jan 31, 2015 | 11:13 PM
  #117
jkapinos's Avatar
jkapinos
I've had mine for 15,000 miles and no noise at all. The suspension is not soft when setup, it's just much better.
Old Feb 1, 2015 | 09:15 PM
  #118
squawSkiBum
Moderator
I have 4 or 5K on my Ohlins, along with Vorschlag camber plates and Helix rear lower control arms. No suspension noise.
I don't find the Ohlins soft at all, the digressive valving really does its job keeping the ride firm while soaking up the sharp bumps. There's an expansion joint in the middle of a freeway interchange ramp that used to make the front end slam and jump a foot to the right. Now it is just a muffled thump.
When I first put them on, the firmer ride was instantly apparent. I have been experimenting with different settings, I started out at -7, then -10, down to -15 and -18, then back up to -12 which I am happy with. I'm looking forward to getting some track time.
Old Feb 2, 2015 | 08:46 AM
  #119
whrisk's Avatar
whrisk
they are not soft compared to the stock suspension, they are stiffer but also give you a much smoother ride because of their design. however, for autox and track purposes they are softer then most setups. thats the point everyone is making.
Old Feb 3, 2015 | 03:49 PM
  #120
Systemlord's Avatar
Systemlord
Oh I purchased my Öhlins Coil-overs today!
$2120 after shipping and taxes. Consider the fact that they used to go for $3000, I can't wait to get these Öhlins coil-overs to replace my horrible stock suspension.
How many of you have bought new pillow ball mounts excluding those who have aftermarket camber plates? I haven't hit 60,000 miles yet.
Old Feb 3, 2015 | 04:29 PM
  #121
jkapinos's Avatar
jkapinos
Have Vorshlag. Don't know if the camber plates are better then the coilovers or visa versa.
Old Feb 3, 2015 | 04:36 PM
  #122
whrisk's Avatar
whrisk
I have vorschlags also. Highly recommend.
Old Feb 7, 2015 | 12:59 AM
  #123
Systemlord's Avatar
Systemlord
When I receive my Ohlins R&T coil-over setup I plan on setting my ride height a 1/2" inch lower than stock, when should I be concerned about needing a re-alignment with regards to ride height with the Ohlins coil-over setup? Also at what point in ride height adjustments do I need lower adjustable control arms?
Old Feb 7, 2015 | 03:02 AM
  #124
deovolens's Avatar
deovolens
I have mostly installed ohlins on my cars and motorbikes.They are comfy and the roadholding improves a lot.I did it immediately when I bought them because they can do a lot of miles. So I got some money back from the dealer for the original ones because he could sell them as almost new.
Old Feb 7, 2015 | 03:26 AM
  #125
jkapinos's Avatar
jkapinos
I'm not sure you can go that high but maybe you can, I've never tried. I have rear adjustable arms and installed them at the stock length. I'm dropped pretty low and can still just get my aliagnment.
