Suspension Bigger front sway bar on daily driver??
Old Jan 2, 2012 | 02:36 PM
IQRaceworks's Avatar
IQRaceworks
I'm getting ready to replace my LCA bushings soon....and while I'm at it I'm going to replace my front sway bar bushings. I'm wondering if it would be worth it to put a bigger aftermarket sway bar on the front since I will have it all apart.
For a daily driver car that will never see any track time....will I see any handling benifts front a bigger front sway bar.....or should I just replace the factory bushings with poly bushings and leave the stock front sway bar in there??
Thanks!
Old Jan 3, 2012 | 08:56 AM
bean's Avatar
bean
in a word, "no". it will only add to the factory established understeer. not much reason for any MINI to need a larger front anti-sway bar.
Old Jan 7, 2012 | 10:41 AM
UKSUV's Avatar
UKSUV
I have the H-Sport Comp sway at 27mm. Its my daily. Its disconnected right now. If it will never see track days...then just do the rear for a little added stiffy...
Old Jan 7, 2012 | 10:50 AM
ZippyNH's Avatar
ZippyNH
Nope...
Remember swaybars in some ways can help, but when you look at the hegatives they add to handleing, imo you can only justify a bigger rear one on a gen1 mini....and that is maybe mot needed if you get camber plates. Bigger rear bar is a cheap improvement for the street....
Old Jan 7, 2012 | 03:34 PM
UKSUV's Avatar
UKSUV
Originally Posted by ZippyNH
Nope...
Now wait...let me elaborate. He said on a DD. Mine is a DD but it was built for the track. I love the 27mm front sway I have. It took a lot to get used to on the way it handles and it was hard to dial in with the back but I really like it. The only reason why mine is disconnected is because I have snapped like 6 heim joints on my Alta end links. The small diameter heims they use cant withstand the heavy and larger sway and they bend and finally snap....
Old Jan 7, 2012 | 06:09 PM
ZippyNH's Avatar
ZippyNH
The nope was to the op's question...lol
Just was saying adding a biggee front bar on a dd is beyond overkill, and determental considering average road conditions...
A bigger rear swaybar for a dd is nearly a nobrainer...the front imo is just a waste of money, and might entail negatives!!
Old Jan 7, 2012 | 06:54 PM
ZippyNH's Avatar
ZippyNH
P.S.
I strongly suggest setting it to the loosest setting or waiting till spring...
then tightining it up, and fooling around....atlwast with the rear bar...
When slick, too much rear bar can make the car a handful until you get used to tge handling..
And think longterm on picking a bar....if you ever plan on getting camber plates, go smaller...if you don't bigger is likely ok.
Old Jan 10, 2012 | 03:04 PM
UKSUV's Avatar
UKSUV
Well...I got my bars new for $280 total shipped which was a helluva steal so THAT was a no brainer...lmao
P.S.
I have the biggest bars offered on the market and they are all set to stiff. They say big is better
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
W0TM8
Dec 19, 2019 07:50 AM
thebordella
Aug 31, 2015 01:37 PM
minipopkart
Aug 13, 2015 05:22 AM
