Suspension creeking after lowering
Old Mar 19, 2010 | 01:36 PM
wellzy's Avatar
wellzy
so i finaly did it got the stuff to lower my r56. i went with h&r springs, koni sport struts, control arms, and camber plate (fix). before you say i spent to much and should of gone with coilovers i got this stuff really cheep. so this leads me to my question now that the work has been done including an alinement i have a creeking sound. it is not the end links or the saw bar it sound as if it is coming from the joint of the trailing arm. any thoughs on how to fix?
Old Mar 19, 2010 | 02:07 PM
JamesHunt's Avatar
JamesHunt
new bushings
Old Mar 19, 2010 | 02:10 PM
It Works's Avatar
It Works
Mine does the same on my JCW...I have Bilstein pss9"s and new Powerflex Bushings. It's kinda a creeky, groany sound. My GP is getting Powerflex bushings on it as I type... guess I'll ask them about the JCW when I go pick up the GP.
Old Mar 19, 2010 | 02:38 PM
wellzy's Avatar
wellzy
the bushing in the control arms and thouse in the struts are new and were grease when installed. on a side note it rides better then it did stock and handles way better aswell.
Old Mar 20, 2010 | 12:28 AM
slinger688's Avatar
slinger688
Grease might help, but you might have to take it apart to make sure it gets into the right spots.
Old Apr 26, 2010 | 06:45 PM
It Works's Avatar
It Works
Found out what the groaning was...I needed new strut mounts. All is well now.
Old Apr 29, 2010 | 12:44 PM
TerryD's Avatar
TerryD
Old May 1, 2010 | 03:54 AM
tvrgeek's Avatar
tvrgeek
Wellzy
I am flip-flopping between FSD, yellows, and Bilsteins. Leaning Bilsteins.
How did the yellows come out with respect of not hopping over bumps in corners? "better" does not help me know what aspect is better. Are the H&R's progressive? Any idea on their rates? How far was the total drop and what travel did that leave in the front?
smdmini
Oct 7, 2019 06:05 AM
massmini03
Sep 18, 2015 05:40 PM
hydouken
Sep 15, 2015 05:49 AM
Accessory Products
Sep 9, 2015 10:29 AM
Sep 2, 2015 11:15 AM
