Suspension Ireland Engineering Rear Sway Bar
Old May 6, 2008 | 06:47 PM
minimyke's Avatar
minimyke
Has anyone used this bar or heard about it..It seems like a really good deal if it works properly, but I havent heard about it or seen it so Im not sure..So if anyone has any experience with it please chime in with your opinion
http://autoxcooper.com/ie_suspension.html
Old May 6, 2008 | 07:31 PM
pyrrhusmj's Avatar
pyrrhusmj
It works well but is a bit annoying to install and makes a clanking noise when driving. I would buy it again, just wouldn't install it .
Old May 6, 2008 | 07:33 PM
minimyke's Avatar
minimyke
What was annoying about the install?
Old May 6, 2008 | 08:04 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
We actually prefer the Hotchkis rear swaybars. They are super hight quality, light weight, and have greasable mounts.
Just my 2 cents.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old May 7, 2008 | 03:16 AM
davavd's Avatar
davavd
Just my 2 cents.
I absolutely LOVE the H-sport 19mm he just put on my car.
Old May 7, 2008 | 07:13 AM
ScottinBend's Avatar
ScottinBend
I had the IE rear sway. Didn't have any problems with it, but it was noisier that stock because of the new endlinks.
It is equivalent to a 19mm solid bar. I changed mine out after a year to a 22mm with TSW endlinks.
Old May 7, 2008 | 07:29 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
H-sport you say? My Alta 22mm is rusting since all the paint is flaking off.
Old May 8, 2008 | 09:15 AM
Chase's Avatar
Chase
Im running the I.E. I absolutely love the bar. It makes alot of noise. Very noticable to most people. I dont mind, but thats just me.
Old May 8, 2008 | 06:09 PM
Fatherdeth's Avatar
Fatherdeth
Ireland has some of the best "bang for the bucks" parts, but as with all things that are cheaper, expect a little sacrafice.
Old May 9, 2008 | 06:07 AM
Mike87's Avatar
Mike87
I have the IE rear bar. It is the 19mm hollow bar that is equivalent to a 22mm solid bar. It made noise when I first installed it, but I fixed the noise issue with some fuel hose.
The install of the rear bar is fairly straightforward. It will take you about an hour if you are mechanially inclined, about double or triple that if not.
I have had it on my '03 for about 3 years and would not trade it for anything.
Good Luck,
Mike
Old May 9, 2008 | 07:06 AM
ScottinBend
Just to clarify.........the IE bar is a 22mm hollow equivilent to a solid 19mm.
Old Oct 4, 2009 | 01:58 AM
rlandrews3rd's Avatar
rlandrews3rd
OK, where did you use the fuel hose to quiet the noise? I think my end links are hitting the part of the subframe. I'm thinking about sliding them farther forward to see if that solves the problem.
Old Oct 4, 2009 | 08:36 AM
Chase's Avatar
Chase
I have the new rear end links for the I.E. bar and it makes almost no noise at all. THis is a great sway bar for a great price
Old Oct 4, 2009 | 09:24 AM
ranczar's Avatar
ranczar
"new rear end links"?? Is there a new, or changed design available? More info please!
Old Oct 4, 2009 | 08:59 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Just get an Hsport bar, you won't have to worry about noise. You only need adjustable rear endlinks if your going to corner weight the car.
Old Oct 5, 2009 | 09:27 AM
rlandrews3rd
OK, I moved the end links forward on the bar and made sure all was tightened to factory specs. I still have the same thumping noise I've had since I first installed the bar over a year ago. Any suggestions, other than buying a new bar? This is on my '02 Cooper with a July '02 build date.
Old Oct 5, 2009 | 11:28 AM
AutoXCooper.com's Avatar
AutoXCooper.com
The IE Sway bar is a great value, but it's got to be installed and adjusted just right to reduce the noise issues. I have a few Chicago customers running them without issue. Feel free to call me for tips, it's just easier then posting.
Old Oct 5, 2009 | 09:20 PM
Chase's Avatar
Chase
yeah they changed the design a lil while ago. I was running the same ones from 2006 that rattled like crazy. I emailed them and they said they had a newer version so i bought them and put them in the same spot that the old ones were in. I have only driven about 10 miles on them, so im not sure how long they will stay quiet
Old Oct 6, 2009 | 07:02 PM
ranczar's Avatar
ranczar
Here's what my endlinks look like. Can you tell if they're the old ones or the new ones? I bought my bar used and didn't ask the seller when he bought it.
Attached Thumbnails Ireland Engineering Rear Sway Bar-cimg2295.jpg   Ireland Engineering Rear Sway Bar-cimg2296.jpg   Ireland Engineering Rear Sway Bar-cimg2297.jpg
Old Oct 6, 2009 | 07:17 PM
Chase's Avatar
Chase
those are the old ones
the new ones are only like $50 or $60 bux
Old Oct 7, 2009 | 08:59 AM
ranczar's Avatar
ranczar
Thanks for that information, Chase. I'll be signing up for those soon.
Toolman
Jan 20, 2016 06:50 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
