Suspension 06 suspension compatible on an 02?
Old Apr 28, 2008 | 09:54 AM
davisflyer's Avatar
davisflyer
Would shocks/struts and rear sway bar from an 06 fit and 02?
Old Apr 28, 2008 | 02:14 PM
kazlot's Avatar
kazlot
I can't answer that.
I checked "Real OEM" and the part numbers for the struts are different. I used 1/2002 and 1/2006 build dates for example when checking for part numbers. I know the internals are slightly different, changed in late '04 I believe, but I'm not sure on the externals.
Perhaps some one with more knowledge can let you know for sure. I'm guessing they'll be compatible.
In keeping with compatibility and why I think they'll fit, in another post but I'm not sure where, it was said that the JCW R56 rear bar will fit the R53. Go here for info: http://minspeed.net/JCWRSB.htm
Hope this helps...
Old Apr 28, 2008 | 06:52 PM
Ryephile's Avatar
Ryephile
Yuppers. As long as the '02 has a build date of March 2002 or newer they are 100% compatible. The dampers on the '06 are noticeably softer than the '02's, however most '02 dampers are getting close to being blown out by now.
Old Apr 28, 2008 | 08:37 PM
davisflyer's Avatar
davisflyer
Thanks!
Old Apr 29, 2008 | 07:53 AM
101101's Avatar
101101
Since it came up (and the OP question got answered), this reminds me:
Typically how long do the OEM struts last? Obviously this depends on roads / track usage / driving style, but is there a general consensus yet? (My last car was a Miata and I remember it was generally accepted that after 50k you needed new shocks; just wondering if it was similar with MINIs)
Old Apr 29, 2008 | 07:48 PM
etalj's Avatar
etalj
also depends on what springs you're running with the stock shocks. With stock springs, i reckon you should get more than 50k miles, but then again, as you said, it depends on the usage....
Old Jun 26, 2008 | 12:54 PM
mr. jim's Avatar
mr. jim
So, this bar is from an R56 JCW? I have a factory R53 JCW and was looking at the H-Sport 19mm bar, but then I came accross the above which is 18.5mm and figured that's what is on my car. I haven't measure it yet though.
So my question would be did the R53 JCW's have the bigger bar or the standard 17mm bar?
Mr. Jim
Old Jun 27, 2008 | 09:20 AM
kazlot's Avatar
kazlot
Mr Jim,
To answer your question, no. The R-53 JCW's have the 17mm rear bar.
The R-56 JCW bar is a nice touch for a factory JCW car especially if you want to keep it stock.
The decision between a 19mm adjustable bar and the JCW 18.5 bar is currently on my mind. I just have not decided which way to go.
Hope this helps...
02miniSguy
Nov 17, 2015 10:29 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
Oct 1, 2015 08:55 AM
Emnotek
Sep 29, 2015 07:37 AM
