Suspension Installed H&R Coilovers
Old May 5, 2008 | 11:36 AM
  #26
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Originally Posted by Bhatch
I am considering getting the RSS club sport Coil overs from H&R. I am worried the street performance will be too slow and soft. I find the sports suspension a bit of a disappointment.
Were your Street Performance set a direct replacement? If you set the spring pearch to the upper limit is it higher then stock?
ALTA deal with those coilovers?
Do you think you could raise your car back up to stock hight with the spring pearch at max? the website gives a max and min..but my old ground controls setup for the E30 and my CIVC both could lift the cars like SUV's or slam them to the bumpstops.
Got em on my car. Got em in stock too!
The RSS is firmer and even more controlled than the improvement with the Street Performance Coilovers.
Maintaining oem ride height is going to be difficult with either choice. Let me know if I can help further!
Old May 7, 2008 | 12:40 PM
  #27
Astro S's Avatar
Astro S
Just got my H&R Coilovers installed yesterday. Figured I throw up a couple of pics that I took this morning.
I told the guys that did the install that I wanted it dropped about "2 fingers". Ended up being a little more then an inch.
Haven't got an alignment yet or put much miles on them, but so far so good. Definitely firmer, but not harsh or jarring over seams and expansion joints. There does seem to be a bit of a bounce or pulse, but I would assume and expect that to go away once they get used a bit.
There are more pics in my gallery including my theft deterent
Attached Thumbnails Installed H&R Coilovers-may06-2008-005.jpg   Installed H&R Coilovers-may06-2008-002.jpg   Installed H&R Coilovers-may06-2008-006.jpg
Old May 7, 2008 | 08:04 PM
  #28
wildfamily's Avatar
wildfamily
installed RSS Coilovers
I installed my H&R RSS ClubSport coilovers on Saturday. They dropped the car more than I expected, but looks really good. I took it out for a spirited drive on the back roads and was amazed at the agility and responsiveness. The faster I went the more impressed I was with the cornering ability. Driving around locally the car felt solid but without the harshness I would have expected out of a sport/track type suspension setup. I currently have the front struts adjusted to the top threads and still only have a tad over a finger width clearance between fender and tire..but no rubbing issues. I do have to be cautious with the underbody clearance though as I have the Alta cat-back exhaust and the clearance of the resonator in the midpipe is only about 3.5 inches...watch those speedbumps. The darn exhaust sits quite a bit lower than the stock exhaust...hope that doesn't create issues.
Adam, thanks for the install tips...went smooth..about 4hrs to install and the 2nd of each front/rear went much faster once I'd figured everything out. Any tips/advice regarding ground clearance with the Alta exhaust. I love the exhaust but am worried I'm going to rip the thing off on a speedbump or something. I have an 06 Cooper S with Alta 22MM rear bar, OZ 16 inchers with 205/50/16 Yoko E100s
Old May 7, 2008 | 08:36 PM
  #29
wildfamily's Avatar
wildfamily
H&R coilover install pictures BadSMini
Here are a few shots after the install...
https://www.northamericanmotoring.co...r_Web_copy.gif
https://www.northamericanmotoring.co...m/DSC05319.JPG
Old Aug 21, 2012 | 11:04 AM
  #30
DRT NaSTY's Avatar
DRT NaSTY
2011 Clubman S
H&R Street Performance Coilovers
amongst other performance mods.
Attached Thumbnails Installed H&R Coilovers-376909_10150997121949464_1397919494_n-1.jpg   Installed H&R Coilovers-295208_10150997124579464_1753205881_n-1.jpg
Old Aug 24, 2012 | 06:40 PM
  #31
Club77's Avatar
Club77
Hi guys I am planning to get an H&R Coilover, RSS vs Street coilover which one has more comfort? Do I need to get other stuff in order to instal the coilover etc spacer or bushing?
Old Aug 24, 2012 | 08:15 PM
  #32
DRT NaSTY's Avatar
DRT NaSTY
i would go with the Street Performance if you want comfort. they dont go as low as the RSS i dont think. i also hear the RSS are pretty stiff. i have the street performance coilovers on my clubman and i LOVE them. rides way better than stock in my opinion. if you check my earlier posts, i posted a few pics so you can see what they look like
Old Jan 21, 2013 | 04:34 PM
  #33
R53.0131's Avatar
R53.0131
can anyone CONFIRM that the RSS go lower than the Street's? ..side by side comparison would be awesome OR just pictures/testimonials.. tire rack says 1.5" for street as max and 2.0" max for RSS...is this accurate for the front?!
Old Jan 21, 2013 | 05:33 PM
  #34
countryboyshane's Avatar
countryboyshane
Looks like two fingers of gap still... just sayin
Old Jan 21, 2013 | 05:54 PM
  #35
R53.0131's Avatar
R53.0131
..any other adjustment that can be made? spring rate? sits perfect in rear just not in front and need more than .5 inch drop -like .7 or .8
Old Jan 22, 2013 | 12:44 PM
  #36
mbwicz's Avatar
mbwicz
You could always cut the coils in front to get them to sit lower. Start with 1/4 coil. That is what it took to get my car to sit level with my TSW's. Use an abrasive wheel.
Mike
Old Jan 22, 2013 | 07:24 PM
  #37
R53.0131's Avatar
R53.0131
yeah but how does it ride on cut springs? ..
Old Jan 23, 2013 | 12:55 PM
  #38
mbwicz's Avatar
mbwicz
I didn't notice a difference in ride, the change was minor. springs are hard steel, can't use a regular hack saw, an abrasive wheel is the best way to cut the spring.
mike
Old Mar 16, 2013 | 06:46 AM
  #39
00m.u037's Avatar
00m.u037
Anyone here using the rss coilover with vorschlag camber plates?
Did you have to measure the thread diameter, and the diameter of the other cylindrical parts before ordering them?
I ordered h-sport in January but they no longer make them for the r53 so I am going with vorschlag. My current kmac plates are failing. One of the bolt head is digging into the plate.
Old Mar 18, 2013 | 09:41 PM
  #40
DRT NaSTY's Avatar
DRT NaSTY
definitely NOT 2 fingers. i can barely fit one now that they've settled and my tires are pretty meaty....BUT the more time thats gone by, the slight wheel gap in the front has started to bother me more. so i think, come september, im taking the leap and going air ride the rear sits perfectly tho with the H&R street performance coils..
Old Mar 18, 2013 | 10:45 PM
  #41
mini-q0203's Avatar
mini-q0203
This phone app is not very user friendly . Was replying to the thread of how a spacer would look like with a 10 mm + spacers with the r105. I installed 20mm on mine and it looks rad as it totally flushed my r105 with the fender
Old Mar 19, 2013 | 02:16 PM
  #42
mbwicz's Avatar
mbwicz
It is advisable to start with the RSB on full soft (holes furthest away from the bar). Get used to the suspension with the changes that you have, then you can stiffen the bar to see how you like it.
Mike
Old Mar 31, 2013 | 03:54 PM
  #43
slitcher's Avatar
slitcher
I installed a brand new set of H&R street today. I'm very please with the comfort but I get a squeak coming from the driver's rear. I torqued everything to spec and can't figure out what went wrong ... I guess I'll drive it for the week and dismantle the shock assy next weekend if the noise persists.
Old Oct 31, 2013 | 11:41 AM
  #44
mini-q0203's Avatar
mini-q0203
Originally Posted by mini-q0203
hi. i just purchased (and waiting for) R56 MINI Sport Suspension Pack from alta. anyone have any experience or input about these parts. Which would be the recommended settin g for the rear sway bar? What is to lookout for to make sure my installer does not mess up or miss things? thanks. I will post pictures once the work is done - that is if I receive my parts before the weekend :-). Also have a an 18" jcw R105 which I am hoping to use a 5mm spacer. I want to go wider but not sure how a 10 -12 mm will look. Thanks for help and input in advance guys/gals.
I put a 20 mm spacer and it looks great with the r105.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
