Suspension Anyone make camber/caster plates for the 07?
Old Oct 25, 2007 | 06:01 AM
a96bimmerm3's Avatar
a96bimmerm3
I was looking at IEs site and they have camber only. Anyone know of a camber/caster solution?
Old Oct 30, 2007 | 04:56 AM
a96bimmerm3
HEY HELIX, READ HERE
Hey Helix, Camber/Caster plates for the 07 S please?? PLEASEEEEE???
Old Oct 30, 2007 | 08:08 AM
snid's Avatar
snid
Or even just camber plates...
Old Oct 30, 2007 | 09:10 AM
Alex@Helix's Avatar
Alex@Helix
Its something we have begun working on. Once we are farther along in the development process, we will put up some more info.
Old Oct 31, 2007 | 12:11 PM
AndreaR56's Avatar
AndreaR56
I have already installed Ireland Engineering adjustable camber plates on my R56! Call Jef !!!
Now I run 2,5° negativi at the front and 2,0° negative at the rear. Perfect
Old Nov 2, 2007 | 12:16 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
How much range is there up front? Specifically without any modifications to the shock tower....
Did you notice a taller ride height with the camber plates installed?
Old Nov 3, 2007 | 02:57 AM
AndreaR56's Avatar
AndreaR56
No difference in heigt, the range is from -1° to -4°
Old Nov 3, 2007 | 05:46 AM
Rally@StanceDesign
Wow....crazy range. Thanks for the response Andrea
Old Nov 3, 2007 | 07:24 PM
snid's Avatar
snid
Did the spring diameter change for the R56? Or the design of the strut tower? On the pre-2007 cars, you can only get around -2.0° of camber before the springs hit the strut tower.
Many plates for the pre-2007 cars "theoritically" allow up to -4.0°, if you have really narrow springs or modify the strut tower. Stock, you're stuck at closer to -2.0°.
Old Nov 5, 2007 | 06:55 AM
AndreaR56's Avatar
AndreaR56
My car is july 2007 and allows -4.0° camber
Old Nov 5, 2007 | 07:48 AM
Bhatch's Avatar
Bhatch
Unless your going wheel2wheel in the rain you never need -4, you just loose too much contact patch.
Old Nov 5, 2007 | 07:52 AM
Rally@StanceDesign
Do you have coilovers? That may play a part in it
Old Nov 5, 2007 | 10:13 AM
AndreaR56's Avatar
AndreaR56
YES! I have H&R coilover kit and Toyo R888 tyres
Old Oct 27, 2008 | 03:08 PM
boratufan's Avatar
boratufan
ı have mini r56..ı buy ıe street/track camber plates..
but ı can not turn my steering wheel easilyyy..ıts not allowed caster settings ..:S
Old Oct 27, 2008 | 04:56 PM
FugitiveAI's Avatar
FugitiveAI
The R56 strut tower design has a bigger opening allowing for further camber adjustment, but -4.0 is pretty ludicrous!
Vorshlag (hope I spelled it right) is working on Camber plates for the R56. Irelands are the only choice on the market now.
Old Oct 27, 2008 | 05:27 PM
AutoXCooper.com's Avatar
AutoXCooper.com
The IE Camber Plate doesn't deal with caster. Who installed them? Did you get the fixed or adjustable plates? Did you mod any other part of the Front Suspension?
Old Oct 27, 2008 | 06:05 PM
morbius's Avatar
morbius
Dr. Morbius
I have the IE fixed plate installed on JCW R56 and have 1.2 camber setup with the ability to go almost 2.5. I am using the helix bars in the rear to control camber and toe. No change in height. Love it and works like a charm.
Old Oct 27, 2008 | 06:57 PM
Ryephile's Avatar
Ryephile
Not a single vendor has yet to make real camber/caster plates for the MINI like everyone and their mom makes in the muscle-car world. I'd love to be able to dial in the caster with the strut top.
Old Oct 28, 2008 | 01:22 AM
boratufan's Avatar
boratufan
ı bought it from jeff
ıts fixed street and track camber plates..ı can not turn easily my steering wheel..
ı get ın front -1.5 camber
-1 toe in
Old Oct 28, 2008 | 01:24 AM
boratufan's Avatar
boratufan
-1 toe in
and ı have getting lower my car..
Old Oct 28, 2008 | 02:50 AM
etalj's Avatar
etalj
Noltec made Camber/Caster plates for the R53. I have a second hand pair if you're interested?
Old Oct 28, 2008 | 05:38 AM
morbius's Avatar
morbius
Dr. Morbius
-1 toe in
I had the same issue on mine and found that between the spring top plate and the IE strut plate, a thicker washer is needed depending on how far the bearing is pressed in. The IE plate needs to spin freely once the whole strut is assembled before installing. Fixed mine up and wheels turn like stock again ..... Hope that helps.
Old Oct 28, 2008 | 05:41 AM
Revolution Mini Works's Avatar
Patience we are working on one
I need caster myself, this is why it will get built
Old Oct 29, 2008 | 03:44 AM
pw4's Avatar
pw4
Just fitted K-Mac camber/castor plates. Very happy with them - 2.5 degrees negative camber has balanced the handling much better. I think Mini Mania lists them, or go to http://www.k-mac.com.au. With the way the currency rates at the moment, should be pretty cheap in the US!
Old Apr 1, 2009 | 10:13 AM
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
check these bad boys out:
http://www.outmotoring.com/mini-coop...er_plates.html
