Suspension H&R Springs
Old Aug 29, 2007 | 12:39 AM
sirr6's Avatar
sirr6
H&R Springs
Hey, if i was to get the H&R 1.4'' springs, would I need control arms? If yes, which is the best brand to get for the best buck!?!?
Old Aug 29, 2007 | 08:19 AM
a96bimmerm3's Avatar
a96bimmerm3
Don't think you need them, I got the Alta ones though.
Old Aug 29, 2007 | 10:23 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
You can get about .5 camber adjustment on the stock arms. You could try that first before buying new arms.
Old Aug 29, 2007 | 11:52 AM
sirr6's Avatar
sirr6
anyone that is from nor cal, know where there is a good shop that installs springs? Ive installed my own before on my honda's but I heard it was harder to do on Mini's any suggestions on doing it myself, or any shops that can do it for me that wont charge a gazillion dollars.
Old Aug 29, 2007 | 01:56 PM
scott48's Avatar
scott48
I work at a race shop in Antelope(Bill McAnally Racing), but half the shop is a NAPA Auto Care Center, and they'll install springs...they're installing my shocks, springs, sway bars on friday. Very Nice shop that does quality work.
Old Aug 29, 2007 | 03:58 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
if you did the ones on your Honda this car isn't that much more difficult.
the control arms are optional on the newer cars as the pen has now provided camber adjustment. BTW: you will love your car that much more once the springs are on. Enjoy!
Old Aug 29, 2007 | 04:18 PM
sirr6's Avatar
sirr6
I want to lower it, but dont want control arms, what height should i stay in w/o having to buy control arms? Sway bar is something i will be getting. I thought maybe the H&R 1.4 drop, any suggestions? Brand?
Old Aug 29, 2007 | 05:40 PM
ltjpunk7's Avatar
ltjpunk7
Well the H&R would most likely be fine with just the stock control arm adjustment, but it would likely still produce a camber slightly more negative than the Mach V springs http://www.fastmini.net/mavsp2.html, since they sit about 0.15" higher. Most likely negligable in both situations, but I think the Mach V would probably give you a little longer tire-tread life in the long run because of the slight difference.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
CooperSharp
Oct 12, 2015 09:21 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
nshannon29
Sep 30, 2015 05:21 PM
