Wierd pump/motor/something sound when car is off
Old Mar 5, 2007 | 12:06 PM
chisss's Avatar
chisss
Have you noticed that? when you turn the car off there is a noise like a pump or a small electric motor reving up even if the car has been sitting there overnight it still does that, where if will dim the dome lights when it starts up?
:impatient
Old Mar 5, 2007 | 12:19 PM
SRICHS's Avatar
SRICHS
That sounds like the power steering pump is draining the battery down. The power steering pump has it's own brain inside the main pump under the vehicle, and your hearing the effects of the brain of the pump failing. Sound like you'll need to replace the power steering pump very soon... before the pump takes a toll on the battery... Prompting the replacement of the battery too.
Old Mar 5, 2007 | 01:15 PM
chisss's Avatar
chisss
ugh... well I got a appt at the dealer on Wednesday to check that out... it's like a vriim vriim vriiim sound... cuz it's not a vroom sound.. hehe
Old Mar 5, 2007 | 04:31 PM
Rawhyde's Avatar
Rawhyde
Mine did that and it was the power steering pump. I'm surprised it doesn't kill the battery in a matter of hours. A service tech told me that it is a BAD situation and that it generates a LOT of heat. Disconnect your battery when parking your car and get it to the shop ASAP!
There's a big thread on here about MINIs burning to the ground because of bad power steering pumps. Don't be a statistic!
Rawhyde
Old Mar 6, 2007 | 01:21 PM
okraD La's Avatar
okraD La
Chiss What year is the car?
Old Mar 6, 2007 | 01:37 PM
chisss's Avatar
chisss
02
Old Mar 6, 2007 | 01:43 PM
okraD La's Avatar
okraD La
Mine is an 2002 also, my steering pump is very loud compared to other MINI's, the only noise I hear after I shut the car is a fan like sound that stays on after I shut the car off..(usually happens when I have been parked or idle with the engine running) I usually have to turn the car off and on a couple of times, then it shuts off.
I fear mine will be taking a crap soon
I have a buddy with a 2002 MCS just like mine repair his....(I think it was about a $600 to $700 repair at an independant shop)
Old Mar 8, 2007 | 05:58 AM
chisss's Avatar
chisss
here is a pic of the reservoir that moves when that noise happens...
Is this the power steering fluid container?
Attached Thumbnails Wierd pump/motor/something sound when car is off-p3080256small.jpg
Old Mar 9, 2007 | 03:38 PM
sdv515's Avatar
sdv515
i think that is the one. is the power steering fan supposed to spin when the car is on because mine does not. it feels like it is catching on something when i try to spin it with my hand. i have a feeling its about to go. mine is an 02
Colt45Magnus
Aug 12, 2015 06:43 AM
pocketmaster
Aug 11, 2015 07:36 AM
ludedude
Aug 10, 2015 07:16 PM
CARdiac
Aug 8, 2015 03:30 PM
