View Poll Results: If you had mushrooming or a cracked strut mount please vote
mushrooming: stock suspension / 15" non-runflat tires
32
3.00%
mushrooming: stock suspension / 16" runflat tires
83
7.79%
mushrooming: stock suspension / 16" non-runflat tires
68
6.38%
mushrooming: stock suspension / 17" runflat tires
346
32.46%
mushrooming: stock suspension / 17" non-runflat tires
214
20.08%
mushrooming: stock suspension / 18" runflat tires
22
2.06%
mushrooming: stock suspension / 18" non-runflat tires
24
2.25%
mushrooming: lowering springs / 15" non-runflat tires
0.28%
mushrooming: lowering springs / 16" runflat tires
0.66%
mushrooming: lowering springs / 16" non-runflat tires
16
1.50%
mushrooming: lowering springs / 17" runflat tires
31
2.91%
mushrooming: lowering springs / 17" non-runflat tires
58
5.44%
mushrooming: lowering springs / 18" runflat tires
0.38%
mushrooming: lowering springs / 18" non-runflat tires
18
1.69%
cracked strut mount: stock suspension / 15" non-runflat tires
24
2.25%
cracked strut mount: stock suspension / 16" runflat tires
3.19%
cracked strut mount: stock suspension / 16" non-runflat tires
32
3.00%
cracked strut mount: stock suspension / 17" runflat tires
112
10.51%
cracked strut mount: stock suspension / 17" non-runflat tires
74
6.94%
cracked strut mount: stock suspension / 18" runflat tires
0.56%
cracked strut mount: stock suspension / 18" non-runflat tires
14
1.31%
cracked strut mount: lowering springs / 15" non-runflat tires
0.28%
cracked strut mount: lowering springs / 16" runflat tires
0.56%
cracked strut mount: lowering springs / 16" non-runflat tires
11
1.03%
cracked strut mount: lowering springs / 17" runflat tires
11
1.03%
cracked strut mount: lowering springs / 17" non-runflat tires
25
2.35%
cracked strut mount: lowering springs / 18" runflat tires
0.47%
cracked strut mount: lowering springs / 18" non-runflat tires
0.75%
Multiple Choice Poll. Voters: 1066. You may not vote on this poll
Poll: Mushrooming/strut mount failure data collection
That's it in a nutshell.
Randy
M7 Tuning
There's more to it than that...
Sidenote: Although MINI-Madness says they are for the S model, they installed perfectly on my 2006 non-S. I did e-mail MINI-Madness beforehand and they said the plates should work on a non-S. I suspect MM says they work for the S because that is the MINI they used to install the plates. Not having access to a non-S they played the safe route and advertised them for the S. In any event, I notified MM that they install fine on a non-S.
Matt
I dont understand.
When companies test fit stuff on cars, I have a hard time believing they only use one model and then only say it fits that one model because they were too lazy/cheap to test fit to another model that is virtually identical in the area for test.
Coopers and S's can be had with exactly the same wheel/tire combos, so if a product is listed to fit one model, regardless of wheel/tire combo, it should, logically, fit the other, unless it is stated that the product only fits cars with 'X' wheel and tire combo.
And what does it mean that Coopers dont get 'banged up as much?' Are they not in accidents as much as S's? Do they not hit as many potholes? Seriously, I am curious.
Not to muddy the waters, but I have a friend with a R50, stock suspenders & 15" tall tires. Her car is afflicted with mushrooms. The worst I have seen to date.
My R53 with 16" & stock suspenders & M7 plates has no mushrooms at 52,000.
There should be a place in that poll for folks with no mushrooms.
hey peeps, im new to minis and honestly have no idea what this problem is. Can anyone tell me exactly what it is? I looked at the pics of the mushrooming strut towers and I dont notice anything wrong. I popped my hood earlier and have no idea what I am looking for. I have an 06 MCS with s-lites and run flat tires.
Also, how serious is this problem?
Some people, probably with damage as extensive as yours, removed the entire front suspension and banged down the top of the tower. I was able to just bang it down w/o removing anything because my shrooming was only on one side and not that much. I was able to get a couple of threads on each nut/bolt started so I just tightened it down and everything is fine.
There are a bunch of discussions on this, most likely in this thread if you read the whole thing, but basically, it depends on how bad the mushrooming is.
i will try ot get some pics..
this is the strut i bought but one of the screw is not in alignment...how do i fix it? can it be fixed? what tool do i use?
Attachment 41211
Attachment 41209
Attachment 41210
Attachment 41211
Attachment 41209
Attachment 41210
It looks like the passenger side is more mushroomed than the driver's side.
People have used a block of wood placed on the strut mount then hit with a big hammer. Others have criticized this because the banging can cause more stress damage as compared to replacing the strut mounts and tightening down the nuts which cause the mount to flatten out slowly.
I will say, again, that if you can get each nut screwed onto a couple of threads on each bolt, just tighten them down, and no banging is necessary. Why? Because even if the top of the tower is not shroomed, and you put the plates on to prevent shrooming before it happens, the top of the tower is still gonna come up that fraction of an inch until it touches the bottom of the plate, anyway, through regular bumpy road usage.
Non-S cars have taller tires (usually) and don't get banged up quite as much, so there is much less of a need. The shape of the inner strut tower is exactly the same (in fact, it is the same).
Matt
Matt
In any event, you are right. I commented earlier last year that in my non-expert opinion that the shrooming appeared to be more prevalent on the S because those models came with the runflats and larger wheels. End result: a harder ride, but more significant, not the additional shock absorption that standard tires provide.
Note: Because of this issue, I am constantly aware of my tire pressure so that my stock tires, so to speak, provide proper cushioning.
Fortunate for me, I don't like the look of low profile tires anyway, so with the MINI that's a win win for me, albeit I am sure the S owners with runflats see me as Timmy Tourist putt putting down the road and roll their eyes.
But from what I have read, low profile tires and/or runflats have a price in addition to their initial expense, the price one pays for style and to feel cool.
Could someone look at this picture and tell me if it's mushrooming? If you can even tell from the picture, it's all the seller put up online. It's a 2006 Cooper S and it seems perfect, I've already taken it for a test drive and I'll probably get it this weekend. I hadn't heard anything about the mushrooming problem until I was browsing this forum last night in anticipation, and then I got terrified
http://img520.imageshack.us/img520/1496/376324.jpg
now what do i do when i need to take off the front struts?
And it could be the camera angle, but the right (left in the pic) looks perfect.
I suspect they are fine.
If you buy it, immediately put some MiniMadness steel plates ($100, see my post above). I really feel a lot better with those plates installed.
