Hot Ignition Key after Use?
Old Aug 25, 2006 | 01:43 PM
fishbulb's Avatar
fishbulb
My wife has mentioned a few times that the metal "blade" of her ignition key seems excessively hot after driving. 05 MCSa, about 7500 miles.
Typically happens in hot weather, with ot without the AC on. She has a short (10 minute) commute as well. I have not noticed this in my 06 MCS.
Any ideas on this? Anyone else with similar symptoms?
Thank you!
-jac
Old Aug 25, 2006 | 05:53 PM
Deviant's Avatar
Deviant
I've noticed my 06 key is warm too after use, I think it's because of the key-fob-batterey being recharged while it's in the ignition.
Old Aug 25, 2006 | 07:45 PM
caminifan's Avatar
caminifan
That is most likely the source of the warm key blade. Another thing to remember is to charge both keys. If one is not used, after about 6ish months, it will most likely be discharged and may need a replacement battery.
Old Aug 29, 2006 | 09:19 PM
El_Jefe's Avatar
El_Jefe
wow, no way?
such freak tips you get on this forum.
Old Aug 29, 2006 | 10:16 PM
gekko's Avatar
gekko
This actually came up on CAR TALK last week. Is the key really hot? I mean too hot to touch? Or just warm?
If it's warm, I would agree with Deviant's post.
If it's hot, it could be a short in the ignition collar, and worth getting checked out.
Hope it's just warm.
Old Aug 30, 2006 | 05:20 AM
fishbulb's Avatar
fishbulb
thanks for all the feedback - i'll have find out if it is just warm or more like hot.
Old Aug 30, 2006 | 08:54 AM
justintime's Avatar
justintime
mine does that too, except sometimes its too hot to touch
Old Aug 30, 2006 | 09:03 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Mine is hot too. But believe it to be a function of the latent heat built up in the car.
The ignition system where you insert the key is metal. So during the summer when it parked and just building heat up all day it's going to get pretty warm. So you go out and put your key in the car and start driving. The heat/energy from built up in the metal has a place to go through a highly heat conductive surface (your key).
Same sort thing happens with my Whalen shift ****. It sits in the car all day long absorbing heat energy. So when you touch it it's going to be hot. And before some people jump on me about covering up the shift **** so it's out of the sun, that doesn't make a difference. I had something I through on it for a month and the difference in the temperatures using the cover and not were negligible.
lweaver
Sep 17, 2024 08:22 AM
Sep 10, 2019 09:22 PM
Filmy
Jun 28, 2016 08:58 AM
MiniUnz
Sep 21, 2015 12:32 PM
MiniUnz
Sep 14, 2015 11:11 AM
