MINI Cooper Ignition Maintenance and Upgrade Application Guide
Old Sep 11, 2015 | 09:26 AM
Mini Mania's Avatar
If your Mini is starting to run a little 'rough', approaching high mileage, or you noticed your gas mileage falling off - the ignition system is one of the three main areas (air, fuel, & ignition) that you need to inspect.
The kits listed below include a set of ignition coils and spark plugs.
MINI COOPER IGNITION MAINTENANCE AND UPGRADE GUIDE (Click on the following link for the Maintenance and Upgrade guide.) http://new.minimania.com/MINI_Cooper...lication_Guide
Old May 6, 2016 | 03:14 PM
Mini Mania's Avatar
MINI Ignition
Definitely worth checking out!
Old Sep 10, 2019 | 09:22 PM
thmpr464's Avatar
thmpr464
For the past month, been chasing a low mpg issue. Have a 06 R50 @ 150K Miles getting 24.5 MPG. After replacing coils, spark plug, spark plug wires, and air filter. No change. Replaced both 02 Sensors to Kwiksen brand to see its effect and MPG went up to 30 mpg. Plan to replace it to NTK in a few months once the MagnaFlow header comes in.
jamesart86
Dec 7, 2015 10:25 AM
Ghent
May 5, 2011 06:40 AM
thecanuck
Aug 11, 2010 08:30 AM
Reed
11
Mar 30, 2009 05:35 AM
CooperS04
Aug 19, 2007 05:50 PM
