battery dimensions for the mcs
Old Jul 19, 2006 | 08:16 AM
edgab's Avatar
edgab
anybody knows the exact dimensions of the oem battery of the MCS?
thanks.
Old Jul 19, 2006 | 02:07 PM
qwertmonkey's Avatar
qwertmonkey
Bump.
I'm not with my MINI, but I am sure some MINI owner would go measure it for you.
Old Jul 20, 2006 | 07:58 AM
joedude99's Avatar
joedude99
Battery Compartment
The battery compartment will hold just about any battery from the looks of it. I just replaced my OEM battery with an Interstate Megatron 72 month battery. The tow operator say that he never sees that brand dead on the road, and I took his recommendation.
Old Jul 20, 2006 | 09:18 PM
edgab's Avatar
edgab
thanks.. but will this size fit or just the same as the oem battery? will the existing brackets, mounts fit?
length=235mm, width=171mm, height=175mm
OR
length=279mm, width=175mm, height-175mm
this is the sizes of alternate batteries that i may use with my MCS. i don't have my car with me and i don't have anyone back home who can measure it.. thanks...
Old Jul 20, 2006 | 09:58 PM
002's Avatar
002
I have a spare battery at the shop that I can neasyre for you. I'll post it tomarrow.
Old Jul 21, 2006 | 12:08 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
OR
My 2003 MCS stock battery is
length=242mm, width=179mm, height-190mm
Terminals face upward with positive to the right.
480 Cold cranking amps
So I'd pick the first one you listed based on size.
Old Jul 21, 2006 | 04:05 AM
edgab's Avatar
edgab
thanks!!!
the first battery is 55ah and 90rc
the second one is 68ah and 115rc
would the first one be okay? and will it fit?
Old Jul 21, 2006 | 05:09 AM
joedude99's Avatar
joedude99
Any battery will fit
Almost any battery will fit. Buy a better battery than the original.
Old Jul 21, 2006 | 11:06 AM
minihune's Avatar
minihune
thanks!!!
My stock battery is-
55ah and 90rc so that is same as original
The second battery has more reserve. Both should work ok.
You pay more for longer life warranty or for more cranking power.
Old Jul 21, 2006 | 02:09 PM
kapps's Avatar
kapps
What about the venting? I havent replaced my battery yet but I've heard it has a special vent to the exterior of the car. The only suitable replacement would be one that doesn't need venting (like a gel cell).
Old Jul 21, 2006 | 02:46 PM
peccavis's Avatar
peccavis
When my stock battery dies, I will replace it with an Interstate Megatron. Interstate makes great batteries!
Old Jul 21, 2006 | 06:24 PM
edgab's Avatar
edgab
i have to check if the new battery has vents on it...
thanks guys for the replies!!!
Old Jul 22, 2006 | 10:54 AM
kapps's Avatar
kapps
Just my luck...as soon as I post on this thread, my battery dies . The speedo needle has been buzzing every once in a while on startup for the past month so I knew it was about to die. Today, it made one crank and then nothing. I had to let it sit a few minutes to just get the doors to lock. I'm hoping that I can get the rear hatch open on Monday or I'll be having some fun getting it in
I'll be getting a MINI battery this time around to make it easy.
(edit): on second thought, does anyone know what Optima red top fits the MCS?
Old Jul 24, 2006 | 04:31 AM
joedude99's Avatar
joedude99
Just Replaced Battery
I just replaced my battery with an Interstate Megatron battery, and the mechanic had no issue replacing it. They did have to order the battery, but they had it in one day. It's cool because it's a 6-year battery.
Old Jul 24, 2006 | 07:15 AM
kapps's Avatar
kapps
Yeah, the MT-47 Interstate battery looks to be a direct replacement. Do you know if the stock vent tube fits the new battery? I know Interstate makes a BMW vent tube adapter but I assume the stock one will fit as well???
Old Jul 24, 2006 | 07:39 AM
joedude99's Avatar
joedude99
Interstate Battery
I opened up the hatch after the replacement was put in, and it looked neatly done, and I couldn't tell any difference in how it was hooked up. I could have saved $20 by putting it in myself, but then I would have the fun of trying to dispose of a toxic battery myself. My local auto shop is great, and I don't mind paying them reasonable amounts of money for service because I like maintaining a relationship with them. They were great about servicing my Acura Integra.
Old Jul 24, 2006 | 11:56 AM
kapps's Avatar
kapps
Well I went up to a local garage that had the MT-47 in stock and compared it to the stock battery. It did not have the vent hole. The guy even called his supplier to find out any info...they didn't know either. I ended up buying an Optima Red Top 35.
When I turned the car on, the SES light stayed on. I'm not sure if it was from a misfire from trying to crank it with the dead battery. I'll run it through a couple cycles and see if it goes out. Other than that, the Optima performs fine. I'll post some pics later.
stevepsd
35
Dec 6, 2022 03:22 PM
theateist
Aug 17, 2019 01:38 AM
eatsleepautox
Oct 30, 2015 06:46 AM
bansasn
15
Sep 4, 2015 01:24 PM
Getrieben
Aug 15, 2015 09:09 PM
