AC compressor fuse where?
Old Jul 2, 2006 | 09:20 AM
kenchan's Avatar
kenchan
AC died...compressor fuse where?
My air conditioner compressor stopped working. The other day it
was working fine. it just blows hot air.
Where is the compressor fuse or the fuse that runs the compressor
circuit?
thanks!
Old Jul 2, 2006 | 09:27 AM
chows4us's Avatar
chows4us
from bentley
F07 30 amps A/C compressor
Panel 3 next to left strut tower
It will be on the right bank
left means drivers side
Old Jul 2, 2006 | 09:28 AM
kenchan's Avatar
kenchan
Thanks chows! im gonna go look at it now.
Old Jul 2, 2006 | 10:02 AM
kenchan's Avatar
kenchan
errr, the fuses are all okay, also checked at the one inside the
cabin too.
I can hear the relay clicking, but the compressor doesn't run.
any other suggestions?
Old Jul 2, 2006 | 11:06 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Are you still covered by the warranty?
If yes, get it to the dealer and let them fix that for you.
If not, then I'd suggest you bring it to a A/C specialist shop. They can test your system and tell you what is going on, for a fraction of dealer's price.
Old Jul 2, 2006 | 11:09 AM
kenchan's Avatar
kenchan
^^ that's great, but was wondering if anyone has actually
worked on these cars that might know more than the obvious
answer to take it to the dealer.
Old Jul 2, 2006 | 11:53 AM
namwob's Avatar
namwob
You mean the compressor is not running. If you have a leak, once the refrigerant only has X amount of static pressure the low pressure switch will keep the compressor from running. It may be a bad switch, but I would suspect a leak. Possibly a 100+ mph rock put a hole in your condenser. Look for dent/ oily dirt. R-134a is cheap compared to freon.Anyway, so adding some to the system will/may make it come back to life. Do that & it may last a year, maybe 1 day. The entire system uses less than a Lb. of r-134a Once you have no pressure or depressurize & replace components or seals you will also need to replace the reciever/dryer that keeps moisture out of the system.(long dessicant filled cylinder attached to the passenger side of condenser) Expansion valves and its 4 seals are prone to leak (behind plastic nxt to gas pedal
Old Jul 2, 2006 | 12:20 PM
kenchan's Avatar
kenchan
^^ thanks, yah, i meant to type compressor...
the car hasn't hit anything that could cause a leak since the last time
i used it (was garaged) but where exactly should i be checking?
Old Jul 2, 2006 | 01:21 PM
namwob's Avatar
namwob
Usually is a slow leak, Maybe its at the compressor, condenser, expansion valve, evaporater, receiver/dryer, hoses, o-ring connectors or pressure switches. You check everywhere. As I said before have someone add refrigerant using gages as to not overfill (hey now it works, but for how long?) Check for leaks now or wait & see how long it works. Your choice. Not a free 10 min. at home project, sorry. But not necessarily an expensive fix either.
Old Jul 2, 2006 | 01:56 PM
COR BLMY's Avatar
COR BLMY
Mine has been DEAD twice in about 2 years.
Be VERY sure that you are letting the system check itself when you start up.
Put the key in turn to "ON" NOT start, wait ... the lowest indicator on the fuel gauge will change from red to orange ... THEN start
Once I had to do a battery disconnect reset.
Each time the AC has then worked again
This start up (wait) procidure is very important...
My SA says that if there is a problem it moves to the end of the que to be auto fixed
I have heard this shutting off windows, sunroof, radio and AC
It is worth a try
Old Jul 2, 2006 | 02:19 PM
namwob's Avatar
namwob
Definitely worth a try!
Old Jul 2, 2006 | 04:09 PM
kenchan's Avatar
kenchan
thanks, I will give this a try right now.
It is worth a try
Old Jul 2, 2006 | 04:52 PM
kenchan's Avatar
kenchan
didn't work. tried the re-set (unplugged battery too).
when i press the a/c mark (the snowflake), i hear a small noise from
the bonnet as it tries to turn over the compressor, but i don't hear the
hissing noise which we usually hear after it clicking on where we start
to get the cold air.
i monitor the voltage and there is no drop either.
wat the heck happend to my a/c?
Old Jul 3, 2006 | 11:10 AM
kenchan's Avatar
kenchan
Just got back from Patrick MINI. they found a slow leak and had to order
parts. They were very cool to charge it up so that at least i got cool
air until my parts come in/or until it all leaks out again.
Hope to get it fixed and done with by Friday of this week so that i
can enjoy motoring in comfort.
Old Jul 6, 2006 | 05:31 PM
kenchan's Avatar
kenchan
parts are in (as they said) and made an appointment for tomorrow.
wish me luck!
Old Jul 7, 2006 | 09:58 AM
kenchan's Avatar
kenchan
woohoo~! fixed.
Old Sep 7, 2006 | 09:14 PM
kenchan's Avatar
kenchan
Originally Posted by kenchan
woohoo~! fixed.
so i thought...
2months later, blowing hot air again...
Old Sep 8, 2006 | 06:06 AM
kenchan's Avatar
kenchan
Patrick was cool to check it in this morning. Right now running a dye and trying to determine where the leak is.
Unlike last time though, I can hear it hissing. I hope they don't need to order more parts...
Old Sep 8, 2006 | 08:34 AM
kenchan's Avatar
kenchan
2 hrs later, no update yet.
Old Sep 8, 2006 | 10:35 AM
kenchan's Avatar
kenchan
called 4 hrs later, still no updates yet.
Old Sep 8, 2006 | 02:43 PM
kenchan's Avatar
kenchan
8hrs later, still no updates...
Old Sep 8, 2006 | 04:14 PM
kenchan's Avatar
kenchan
Got my car back for now... they recharged the system with a dye and
will need to bring it back in a few weeks. could not find where the slow
leak is. but at least it's blowing cold air for now.
hummm...
PsychoRallye
21
Feb 17, 2019 06:08 AM
mni928
Nov 9, 2015 07:38 PM
Brochacho
Sep 29, 2015 10:24 AM
Nicefeet
Sep 27, 2015 11:14 AM
dragonby
Sep 25, 2015 08:10 PM
