Oil leaking between my 2 piece block
Old May 12, 2022 | 05:20 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Looks like I may have a leak between the upper an lower block joint. Cannot figure out how it could happen.
Has anyone else had this issue.
My mini is A 04 R50.
Old May 12, 2022 | 07:10 PM
DFTR's Avatar
DFTR
The stuff of nightmares. I will pray tonight you find an accessory oil leak yet discovered. You poor somabich
Old May 12, 2022 | 08:45 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I know it not coming from the rear main seal or valve cover. I hate to think it coming from between the the 2 piece block.
Old May 15, 2022 | 06:30 PM
ssoliman's Avatar
ssoliman
Do a really good engine clean to confirm
Old May 15, 2022 | 09:13 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Yeah going to do that an add some dye in there an hit it with a UV light. I had the pan of a couple weeks ago an I noticed the leak near the trans before removal. So when I removed the pan. I looked at the clutch plate as it is partially exposed when pan is removed. There was zero sign of rear main seal failure. I did not double check the pan in that area before reinstalling. So I got another one just in case.
Old May 18, 2022 | 07:23 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Well looks like I found my leak. Rear main seal.
Old May 18, 2022 | 07:56 PM
dmath's Avatar
dmath
I guess this is one of the few instances in which that can be seen as good news. Congratulations.
Old May 18, 2022 | 08:48 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Rather win the boobie prize.
Pulling transmission next weekend.
Old May 19, 2022 | 11:46 AM
cooper48's Avatar
cooper48
Do yourself a favor and go grab a top-mount motor support from Harbor Freight. Makes the transmission removal much easier and you can always sell it afterward.
Old May 19, 2022 | 12:41 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
I have everything all ready. I have the support along with a transmission jack.
allgrainer
Jun 29, 2014 01:41 PM
Shoe Coupe
R60/R61 Stock Problems/Issues
Jan 21, 2013 11:47 PM
MINIxB
Classic Mini Talk
19
Mar 25, 2009 11:49 AM
22CooperS
Dec 26, 2007 07:29 AM
