An oil leak you've never seen before
Old Jun 9, 2019 | 05:59 AM
Ludopo's Avatar
Ludopo
Can somebody help about this one ?
Old Jun 9, 2019 | 11:27 AM
oldbrokenwind's Avatar
oldbrokenwind
Most likely the oil seal. The vibration damper can be removed (and will NOT affect timing) for a better look at it, without loosening the main crank bolt (which WILL affect timing).
Old Jun 9, 2019 | 11:30 AM
Ludopo's Avatar
Ludopo
You are talking about the crankshaft seal ??
this is not the issue, it’s dripping from right above
Old Jun 9, 2019 | 12:14 PM
oldbrokenwind
Take a look at items 13 and 15 in the attached chart, one may have worked loose. Then there's the valve cover gasket. Might have to support the engine and remove the engine mount to find the leak.
Old Jun 9, 2019 | 04:16 PM
Ludopo's Avatar
Ludopo
I checked but none of these bolt are leaking it really comes from the small pastils between them
Old Jun 9, 2019 | 06:25 PM
oldbrokenwind
If your "small pastils" is the freeze plug looking thing, it should be replaceable. Pretty sure I've seen threads here that described oil leaks from that plug --- bad seal, not perforated. Might be able to get at it by just pulling the vibration damper. Be sure to get a replacement before punching out the old one.
Old Jun 9, 2019 | 06:53 PM
Ludopo's Avatar
Ludopo
There is no way to find it
don’t even know if it exist as spare part...
i’m thinking About welding it
Old Jul 7, 2021 | 03:30 PM
peteyypab's Avatar
peteyypab
I have this same leak!!
did you find this plug?
Old Aug 1, 2021 | 03:55 PM
Ljlake's Avatar
Ljlake
I found the one just need to find out how to remove it (11117540058 Cover lid)
Old Aug 3, 2021 | 07:24 AM
thefarside's Avatar
thefarside
It is glued in with same sealant used on the oil pan (Loctite 5970)
Old Aug 3, 2021 | 07:31 AM
peteyypab's Avatar
peteyypab
A swift punch in the middle should deform the plug such that it should fall right out.
clean up the block really good, apply the loctite to the new plug and install and let the loctite set.
I have all the parts on my bench, just need the time.
Old Mar 21, 2023 | 06:20 PM
keduMINI's Avatar
keduMINI
Yeah, this was difficult to isolate and identify. The leak persisted after replacing O-rings for timing chain track bolts. A remedy for me was to remove the paint and apply JB Weld Extreme Heat over the entire faces of both detent plugs. I don't ever imagine needing to access anything behind these ports.
Difficult camera angle and focus, but one of the 2 caps is shown covered with JB Weld
HighSchoolzMINI
Nov 17, 2014 08:00 AM
usafdrew
Apr 14, 2013 11:30 AM
CravenSpeed
Aug 8, 2006 10:52 AM
The MINITOR
May 20, 2006 02:38 PM
wendy
Jun 28, 2004 08:16 PM
