Using Lots of Oil
Old Jun 1, 2019 | 06:48 PM
jjcsnlynn's Avatar
jjcsnlynn
Using Lots of Oil
I got this mini non-running. Vacuum Pump ceased up and took out some valves. My son and I did the head rebuild. He is a trained mechanic and I'm shade tree. While the head was off, I looked over the cylinder walls and they looked good. I pulled the pan and cleaned everything out. I also changed the oil filter housing and cooler gaskets while the head was off.
So I have about 1000 miles or less on it and I've used 2 1/2 quarts of oil! Today did a 200 mile cruise and used a quart! My son says I have a small seep from the front main (yes I changed it) and some seepage from the rear main. I did have a very bad leaking valve cover but I changed that and stopped the top lead.
I can still smell burning oil from above the engine but I NEVER see any oil on the driveway. During the cruise today, my friends wife was following me and said a few times it smoked pretty good but she couldn't tell from where. At one point we were doing about 90 and a black truck was on my tail. I could see some black smoke coming up between us when I really got on it.
I am going to make an appointment to get it looked at but what are some of the things that could cause this excessive oil consumption.
Old Jun 1, 2019 | 07:27 PM
oldbrokenwind's Avatar
oldbrokenwind
Compression / leak-down check? Hopefully you replaced the valve stem seals, they're a good source for oil leaks. Bad PCV can cause crankcase positive pressure, forcing oil thru turbo seals and into the turbo compressed air output. Your oil burning quantities will cause oil to collect in the FMIC if it's going thru the turbo.
Old Jun 1, 2019 | 07:34 PM
jjcsnlynn's Avatar
jjcsnlynn
Good questions. We did not do a compression or leakdown check once we found bad valves. I did install new valve seals and my son said the valve guides were good.
I have blocked off the back PCV port on the valve cover and installed an OCC on the turbo side.
I should probably look at the FMIC.
Old Jun 1, 2019 | 08:03 PM
oldbrokenwind
Blocking the rear PCV port will cause positive crankcase pressure. I strongly suggest an OCC there.
Old Jun 1, 2019 | 08:32 PM
jjcsnlynn's Avatar
jjcsnlynn
Wait. I thought the rear was only used during idle and the side during above idle.
Old Jun 1, 2019 | 08:43 PM
oldbrokenwind
Rear PCV port is active when manifold pressure is at or near zero --- vacuum. PCV activity switches to the side port during boost, which is the least often during normal daily driving conditions. You'll find the OCC needs to be drained a lot more often when connected to the rear port. Dual OCC's are common on the N14.
Old Jun 1, 2019 | 08:50 PM
jjcsnlynn's Avatar
jjcsnlynn
Thanks. I am leaving for Minis at the Glen in two weeks. If I can’t get an OCC on by then should I reinstall the tube to the i take?
Old Jun 2, 2019 | 11:03 AM
oldbrokenwind
Definitely, maybe even sooner, while waiting for an OCC, to see if it affects the oil consumption. Consider a dual OCC, to save space?
Or re-configure your existing setup and put the side port back to OEM? The side port normally discharges very little.
Old Jun 2, 2019 | 02:01 PM
jjcsnlynn's Avatar
jjcsnlynn
I reinstalled the tube from the valve cover to the intake. I also checked the FMIC...no oil.
I will drive it and see if anything changes.
ODog
Jun 8, 2016 08:53 AM
SharpByCoop
Sep 17, 2014 02:19 AM
ClubmanS
R55 :: Clubman Talk (2008+)
18
Apr 1, 2008 09:23 AM
hornguys
Aug 6, 2007 11:32 AM
Boludo
11
Sep 25, 2005 10:27 PM
