Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs.
Thank you I will double check and use a car starter to give the battery extra power.
the car was parked during roughly 1 month since it has the overheating problem
Reason: more details
Take the battery to a auto parts store and have it tested. It may be bad or going bad. A battery can hold a charge but not a full charge and turn the engine over without starting.
You were right I putted my Hyundai Elantra battery on it the car is not starting but crank multiple times
i want to perform a compression test and I don’t know if this kit is compatible with my mini here is the spec
i tried all the brass but does not fit?
Reason: More details
Your battery is probably bad. Take it to a parts store and have it tested. Youre just spinning your wheels otherwise. You are getting no where by all this home diagnosis.
