Hesitation with 2013 "justa" mini cooper R56.
Old May 10, 2018 | 06:20 AM
sean_m's Avatar
sean_m
Hello,
I have a 2013 "justa" mini cooper R56 - automatic transmission - with 48,000 KM on it. Bought it used from Mini dealership last August. Love this car and the only thing that troubles me about it is a pronounced delay or hesitation when starting off from a stopped position. It can be a couple of seconds before I feel the power coming on and at times the acceleration is slow. It almost feels like it is trying to push to big of a gear. This is the only car I have ever owned where I regularly have the gas peddle pressed to the floor looking for some acceleration when I am merging. Once the car is up at speed it seems more responsive.
I have done a sea-foam treatment. Wondering what some other options might be. I searched this forum and found some folks replace plugs and coil packs for this type of issue. I guess I could try that as it seems like an easy project.
Thanks for your advice,
- Sean
Old May 10, 2018 | 10:47 AM
Shiner's Avatar
Shiner
I did the Seafoam treatment about a month ago and the effects were tremendous for about an hour. No starting issues but a lot of lurching at stop signs and red lights. I found a Gentleman in Melbourne Florida that I had him do the walnut blasting treatment. Huge difference. Huge amount of gunk removed from valves.
Old May 10, 2018 | 10:54 AM
MiniToBe's Avatar
MiniToBe
Justa = Non turbo. there isnt much stuck on the valve since gas is spied outside the cylinder.
This car without the turbo is like a honda civic. try the "sport mode" if you want a little more response from the car, otherwise get the turbo version
Old May 10, 2018 | 08:42 PM
kurtsunn's Avatar
kurtsunn
I have a 2009 Justa Auto as well and was having hesitation issues from starts as well. Replaced the plugs and coils and no more hesitations and smoother overall. Easy and quick to do. Parts are reasonable. Check ECS Tuning. I got the Bosch coils and plugs. The original Beru plugs I replaced looked like hell. See photos. I was at 92000kms.
Attached Thumbnails Hesitation with 2013 "justa" mini cooper R56.-a1fa28fb-1f12-4ac9-a94c-2ed9a3bc17c7.jpeg   Hesitation with 2013 "justa" mini cooper R56.-68f0c255-1232-4c73-b7a2-f4f65d54eb88.jpeg   Hesitation with 2013 "justa" mini cooper R56.-62a4f43b-1c3b-4cec-ba47-d7397a984c8d.jpeg   Hesitation with 2013 "justa" mini cooper R56.-2491c024-c763-4afe-8cf6-73f3bd221836.jpeg
Old May 10, 2018 | 08:50 PM
scottm2k's Avatar
scottm2k
Absolutely pure uneducated speculation but it sounds like a torque converter issue with your transmission.
I'd definitely put some good plugs and coils in first as Kurtsunn suggested but it might be something to investigate if simpler checks come up nil.
Old May 11, 2018 | 07:47 AM
kurtsunn's Avatar
kurtsunn
Try the plugs and coils - eliminate that first, then move on to more expensive possibilities:
https://www.ecstuning.com/Mini-2009-...gine/Ignition/
Old May 11, 2018 | 07:52 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Don't even have to spend any money on plugs first, just inspect them. If they look like kurtsunn plugs above then change them. Lots of online photo's of plugs and what good and bad ones look like.
First thing I do usually with a used car is check plugs unless they have been proven to be recently changed.
Old May 11, 2018 | 08:03 AM
kurtsunn's Avatar
kurtsunn
I certainly defer to more experienced advice. For me it's a fun hobby of "find the problem" and I've learned a lot doing work on this MINI that I will in turn use on a 328i that I also have. I just realized that i paid close to $600 to replace ONE coil and plugs on my 328i last year that I did on the MINI for about $80 in parts and an hour of my time.
Old Jul 9, 2018 | 04:51 AM
sean_m's Avatar
sean_m
Hello - Just to close the loop I have made several modifications of the past few moths and finally solved the issue.
First I put a K&N cold air intake on the car. I like the look of it in the engine bay and love the growl my little mini makes now. No appreciable performance improvement though.
I changed the plugs. For 50K they all looked pretty beat up. Cylinder 1 spark plug was more oil fouled and the spark plug tube had a bit of oil in it. After the new plugs the car did run better (smoother idle) but the hesitation and lack of low end power did not change much.
Finally I changed the ignition coils with the same model of Bosh coils. Wow! What a difference. When I used to go up a hill at low speed (45 KM/HR) the car had no power and would groan like it was going to die. Now it has loads of power at lower RPM and the responsiveness and acceleration are where I would expect them to be. You would not think a coil change at 50,000 KM would be necessary but for me this made a huge difference.
Thanks everyone for your advice.
- Sean
Old Jul 9, 2018 | 04:59 AM
MiniToBe's Avatar
MiniToBe
happy things worked out in you favor
Old Jul 9, 2018 | 05:36 AM
kurtsunn's Avatar
kurtsunn
- Sean
Glad everything worked out! I’ve been issue free for about two months now as well.
The final issue I had, an oil leak, was solved by replacing the vacuum pump. The only real issue I have now is some oil consumption which I am believe is quite normal.
Enjoy the car! Enjoy the summer!
MINI305
Sep 14, 2013 11:57 PM
1ncmini
Oct 6, 2011 03:42 AM
5zero4
Feb 20, 2011 05:25 PM
