anyone have a pic of the rear tpms receiver?
Old May 2, 2018 | 01:54 PM
TRAVR6's Avatar
TRAVR6
I bought a used car and the guy said he broke off the right rear receiver for the tpms.
Not the part in the wheel but the part that reads it.
I was wanting to order the part now but i cant seem to find a picture of it.
I won't be able to work on the car for 2 weeks.
Would be nice to order the part now and have it ready.
Anyone know what this is? part number?
Can't find it anywhere on a microfiche either.
Old May 2, 2018 | 02:05 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Did you look on realoem.com ?
Old May 2, 2018 | 06:05 PM
TRAVR6's Avatar
TRAVR6
No. i have never heard of that site
Old May 2, 2018 | 08:33 PM
RB-MINI's Avatar
RB-MINI
The 1st gens didn’t have an actual TPMS system. Unless the previous owner added an aftermarket one, 1st gens check “tire pressure” by using the wheel speed sensors. If a tire is low, the diameter is smaller and rotates at a different speed triggering the low pressure light without specifying pressure or which tire is low.
What year is your car? Other than the previous owner telling you something is missing, are you seeing any error codes or lights?
Old May 3, 2018 | 06:47 AM
Capt_bj's Avatar
Capt_bj
corrrect
if you have correctly placed your question in GEN1 section, there is no such TPMS receiver
so one wonders WHAT WAS broken off??????
Old May 3, 2018 | 03:02 PM
TRAVR6's Avatar
TRAVR6
2006 S hatch manual.
He told me he had a flat on the right rear. He said he broke the tpms sensor. Not the sensor in the wheel but whatever is located on the car that reads the wheel.
I will be doing the hubs soon and wanted to fix this also but i have no idea what he broke.
Old May 3, 2018 | 03:03 PM
TRAVR6's Avatar
TRAVR6
Oh yeah, the low tire warning light is on all the time.
Old May 3, 2018 | 04:17 PM
TRAVR6's Avatar
TRAVR6
I wonder if this is it?
Or is this for the anti lock brakes?
https://youtu.be/oamKqVA8Wxs
Old May 3, 2018 | 05:54 PM
RB-MINI's Avatar
RB-MINI
An '06 doesn't use TPMS sensors in the wheels to detect low tires so the previous owner broke something else unknown, if anything at all. It uses the sensor in the video you posted, but if that sensor is broken you should have other issues like ABS or traction/stability lights, not just a pressure warning light.
In theory all of the tires should be inflated to the proper, or at least equal, pressure. Then the button on the center console near the handbrake is used to reset the system. If any of the tires goes low the warning light should come on, but not tell you what tire is low. If for some reason all of the tires go low at the same time the system shouldn't trip a tire warning light because all of the way it calculates "low pressure".
If this was on the driver's side and you had xenon lights, I would suspect the leveling module, but I don't know of any modules he could break on the passenger side.
What I would do if only the tire warning light is on, and you know you don't have a big leak, is inflate all of the tires to the recommended pressures on the label in the door jamb, reset the tire warning system, then drive the car and see if the tire pressure light comes back on.
Old May 3, 2018 | 06:12 PM
iwashmycar's Avatar
iwashmycar
Passenger rear might have brake pad sensors....but then youd certainly have that light (if first gens even had those??)
Old May 4, 2018 | 06:19 AM
TRAVR6's Avatar
TRAVR6
I have already aired the tires up and tried to reset the light.
It's possible one of the sensors is bad and he broke something else.
But no other dash lights are on except for the airbag which i believe is an issue with the clock spring.
Old May 4, 2018 | 08:40 AM
iwashmycar's Avatar
iwashmycar
edit: nevermind, wrong year
are all the tires the same size?? Is the repaired tire brand new compared to others??
Old May 4, 2018 | 10:28 AM
RB-MINI's Avatar
RB-MINI
Heres a page from the manual on how the pressure monitor works and how to reset it:
It doesn't say how the light on the dash will respond if it's already on, but I would start the car, hold the button for about 10-15 seconds, then drive off so it can compete the reset procedure.
On another thread it said a bad steering angle sensor would set off the TPMS light and traction control lights, but since you only have the one light it probably isn't the problem.
For your airbag light, has your MINI had the passenger weight sensor replaced under recall?
Old May 6, 2018 | 06:06 AM
TRAVR6's Avatar
TRAVR6
I already tried to reset the TPMS and it did not fix it.
Got my new rear hubs in the mail so I will just tear into it and try to figure it out.
As for the airbag light.....
My airbag light is on, cigarette lighter doesn't work, and the horn doesn't work. All fuses are good.
I think it's the clock spring.
When I press on the rear seat the passenger airbag light comes on so that weight works.
Not sure about the driver's I don't think it has a weight. Wouldn't make any sense for the driver's seat to ever turn off.
Old May 8, 2018 | 10:20 AM
TRAVR6's Avatar
TRAVR6
Clock spring fixed the horn and airbag light.
Cigarette lighter still doesn't work and the TPMS button light never lights up. Low tire light is still on.
Old May 8, 2018 | 11:19 AM
RB-MINI's Avatar
RB-MINI
I wonder if the TPMS switch is bad or disconnected? Since your cigarette lighter also doesn't work, maybe the previous owner removed the center console and those items weren't reconnected?
Old May 13, 2018 | 04:01 PM
TRAVR6's Avatar
TRAVR6
Possibly. But the TPMS button is by the ebrake and the cigarette lighter is under the radio.
Old May 13, 2018 | 04:28 PM
Whine not Walnuts's Avatar
Whine not Walnuts
I am pretty sure they both utilize the same harness.
10Zero
Tires, Wheels, & Brakes
Jun 14, 2022 01:23 PM
CMongoose
R60/R61 Stock Problems/Issues
May 2, 2018 01:55 PM
R56typeS
Sep 22, 2014 07:26 PM
Mr Battle
14
Jun 3, 2003 10:35 AM
