Any easy way to split the engine case?
Old Mar 6, 2018 | 11:19 AM
RUPNOK's Avatar
RUPNOK
Motor is out and everything is off. Having been using a dead blow hammer to separate the case, have a very small gap at the crank pulley side. Any suggestions? Thanks.
Old Mar 6, 2018 | 11:52 AM
MiniToBe's Avatar
MiniToBe
did you take the two bolts at the end of the bell housing? they are covered by metal caps.
send pix
Old Mar 6, 2018 | 12:16 PM
RUPNOK's Avatar
RUPNOK
send pix
Do you mean these? I was wondering what they were. How do you get them off? Doesn't look like there is a gap so that you can insinuate a tool to pry it off.
Old Mar 6, 2018 | 12:21 PM
MiniToBe's Avatar
MiniToBe
lol...yes these are the ones...you can use a flat head to hammer them from the side. these are not reusable. you have to order new ones...they're cheap
Old Mar 6, 2018 | 12:56 PM
RUPNOK's Avatar
RUPNOK
Now I know why they are capped, because they leak oil. What do you use to put the cases back together, black rtv or something special? None of this is covered in the Bentley manual and this is the first engine I've ever had apart.
Old Mar 6, 2018 | 01:01 PM
MiniToBe's Avatar
MiniToBe
Yes black rtv silicone is fine. Use new caps.
Old Mar 6, 2018 | 06:24 PM
RUPNOK's Avatar
RUPNOK
Last question, are the M8 outer case bolts and the M16 inner case bolts torque to yield or can I reuse them? I know the bolts holding the con rods cap bolts are one time use as are the head bolts.
Old Mar 6, 2018 | 06:29 PM
MiniToBe's Avatar
MiniToBe
The outer ones can be reused. The inner ones are one time use. I think they were $2 a bolt back when i did the work.
MiniJinx
R55 :: Clubman Talk (2008+)
Jul 9, 2018 03:41 PM
thulewx
Mar 4, 2009 04:22 PM
bentyyc
Tires, Wheels, & Brakes
May 28, 2008 01:49 PM
Arly
Apr 26, 2007 11:18 AM
