manual shift boot and trim get warmer
Old Jan 18, 2018 | 06:48 PM
yyj3869's Avatar
yyj3869
today while i was driving and realized that shift boot and side trim was getting warm. it's not hot but warm. i think heats coming from bottom or transmission?
any guess or advises?
Old Jan 19, 2018 | 10:43 AM
sarom058's Avatar
sarom058
From: Portland, OR *currently in a temporary email address
The exhaust is below the boot. Transmission is mounted transversely in most front wheel drive cars!
Could be a bad heat shield, or insulating shifter housing pad, but I doubt it. It's probably just cold enough to notice it right now.
Old Jan 19, 2018 | 11:06 AM
yyj3869's Avatar
yyj3869
Is this a heat shield you are talking about? If so, My car doesn’t have it. Maybe that’s why?
Old Jan 19, 2018 | 11:22 AM
Whine not Walnuts's Avatar
Whine not Walnuts
The heat shield is like a heavy gauge aluminum foil that is somewhat flexible.
Old Jan 19, 2018 | 12:53 PM
nkfry's Avatar
nkfry
Does the car have a short shifter installed? You need to remove the bottom of the shift box to install a short shifter, so more heat felt in the shifter area is normal with a short shifter.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 19, 2018 | 01:06 PM
yyj3869's Avatar
yyj3869
It’s actually stock shifter.
Old Feb 13, 2018 | 08:12 PM
sarom058's Avatar
sarom058
Nope, this one! http://www.realoem.com/bmw/enUS/show...62#51487201454
Old Feb 19, 2018 | 02:36 PM
Make sure they did not remove the insulation like above, you should see it right above the center exhaust pipe.
https://www.ecstuning.com/Search/Sit...h/51487201454/
stripesace
R60/R61 Stock Problems/Issues
23
Aug 19, 2012 03:50 PM
jeffm5150
Classic Mini Talk
Nov 3, 2011 10:44 AM
cooper99
Jun 1, 2007 12:52 PM
rataha
11
Jan 22, 2003 08:01 AM
