R56 Turbo wastegate
Old Jan 14, 2018 | 04:17 PM
Pramuk's Avatar
Pramuk
R56 Turbo wastegate
Yesterday I just realized my R56 lacking of turbo boost. I found out that turbo wastegate rattle and has some funny sounds from around turbo at idle.
Has anyone ever changed turbo wastegae before? Or need to replace the turbo.
Old Jan 14, 2018 | 04:27 PM
S-2013's Avatar
S-2013
Unfortunately, the wastegate on our cars wear out the surrounding compressor housing. This usually requirings a complete turbo replacement. I’ll be starting my turbo replacement Tuesday because the wastegate failed.
Old Jan 14, 2018 | 06:09 PM
Pramuk's Avatar
Pramuk
Thats sad... need to spend 1k for new turbo. What kind of turbo are you going to pit on?
Old Jan 14, 2018 | 07:58 PM
S-2013's Avatar
S-2013
Actually found a low mileage turbo in a local salvage yard. Removed with the exhaust manifold attached and luckily, no play from the wastegate.
Old Jan 14, 2018 | 09:28 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes worn out waste gates are a very common issue we replace turbo's for all the time. we just replace it with a stock turbo.
https://www.waymotorworks.com/stock-...8-r59-r60.html
Old Jan 17, 2018 | 12:22 AM
Scooter24's Avatar
Scooter24
What do you mean wear out the surrounding compressor housing? Do you have a pic of that? I never would have guessed a failed wastegate would mean a new turbo.
Old Jan 17, 2018 | 04:40 AM
S-2013's Avatar
S-2013
Correction; Exhaust housing wear. The wastegate shaft will wear or the surrounding "exhaust housing" will wear causing issues with wastegate operation. Typically you can't replace just the wastegate in these cars.
Old Jan 17, 2018 | 10:31 AM
dmyer's Avatar
dmyer
The wastegate shaft moves in mounting holes is housing.... the holes wear egg shaped causing the wastegate shaft to bind, to the point, no amount of vacuum will move it..... turbo is dead at that point.... don't ask how I know!!
Old Jan 17, 2018 | 10:33 AM
Scooter24's Avatar
Scooter24
ahhh I can picture the issue now. Crazy that the one part can ruin a whole turbo setup.
Old Jan 17, 2018 | 10:58 AM
dmyer's Avatar
dmyer
That is also why you do not want to buy a rebuilt.... as the wastgate is still old and may be on its last legs... again... don't ask how I know.
Old Jan 21, 2018 | 12:39 PM
jacknk's Avatar
jacknk
For $150 you can buy the wastegate exhaust housing which has the wastegate and linkage built in.
Old Jan 29, 2018 | 01:03 PM
S-2013's Avatar
S-2013
I posted this on YouTube today. This is your typical worn out wastegate on a Mini.
Old Feb 7, 2018 | 06:17 AM
bugeye1031's Avatar
bugeye1031
Moderator
the wastegate on my S went out at something like 120k. I had the turbo rebuilt and replaced the cracked exhaust housing. You might be able to just replace the housing.
http://jmtcperformance.com/jmtc-repl...haust-housing/
Old Feb 7, 2018 | 07:57 AM
jacknk's Avatar
jacknk
For $150 I have a new one. PM me if you want to buy.
Navlancer
Nov 19, 2024 08:20 AM
uber.bucket
Oct 27, 2017 08:34 AM
pfcmooney
Jan 8, 2016 10:14 AM
brandonwirtz
Aug 29, 2013 11:37 AM
zwitnee
Oct 31, 2007 10:40 AM
