Fuel gauge not working
Old Dec 11, 2017 | 08:10 PM
backsidedriver's Avatar
backsidedriver
Hello all,
I have a 2004 Mini Cooper (R50) where the fuel pump quit. I replaced the fuel pump today, and while I was under the seat i also replaced the fuel filter. Oddly enough, it was easier to replace the fuel pump than the filter. Regardless, my daughter's car now starts but now the fuel gauge reads empty even though i have a full tank. I have read that it will eventually start working. Anyone have any advice? Will it magically start working or is there a computer reset that needs to be done?
Old Dec 11, 2017 | 08:51 PM
gknorr's Avatar
gknorr
I've replaced both these parts and the fuel gauge was working fine afterwards. No computer reset is necessary. Are you sure all the electrical connections are good?
MINI parts or aftermarket?
Old Dec 11, 2017 | 09:14 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
If you reconnect all the electrical connections after the job, then it is possible the fuel level pickup was damaged from mishandling. It is a potentiometer and is quite delicate at the wiper. The wirings (blue) are also delicate.
Old Dec 12, 2017 | 04:58 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Ah, potentiometer, a term from my past life.
Moving this to the Stock Problems/Issues section.
Old Dec 12, 2017 | 09:29 AM
pnwR53S's Avatar
pnwR53S
Quiz of the day. Have you ever wonder why the electric fuel pump, made of DC motor with brushes does not turn your fuel tank into a readymade IED? If you ever play with these motors you know they create all sorts of sparks when energized. Sparks and petrol cannot be good.
I know, I am chicken Little.
Old Dec 12, 2017 | 09:57 AM
Whine not Walnuts
Would think that the part is either "vapor proof" or "explosion proof." The bigger issue would be how the amp draw that creates heat is addressed.
Old Dec 12, 2017 | 10:01 AM
pnwR53S's Avatar
pnwR53S
Nop! the brushes are right there submerged in the fuel, or fuel vapour when you are waiting for the pay-checque to buy more with an empty tank.
Old Dec 12, 2017 | 10:03 AM
pnwR53S's Avatar
pnwR53S
Tip: Think crash and burn movies produced by Hollywood.
Old Dec 12, 2017 | 01:06 PM
backsidedriver
It was an aftermarket fuel pump. I double checked and the sending unit appeared to make good contact with the float arm and all the connections are solid. Car starts better than it has in a while with the new pump. The only odd item is the fuel gauge will not work.
Old Dec 12, 2017 | 01:10 PM
backsidedriver
On a side note, I did not know there was a sending unit on the filter side. In fact i did not even see a sending unit. Do the 2004 Base Mini Coopers have a second sending unit. If so, I guess it is possible that i could have damaged it while replacing the fuel filter.
Old Dec 12, 2017 | 03:08 PM
AoxoMoxoA's Avatar
AoxoMoxoA
Yes, according to this photo of p/n 16146765122, the Fuel Filter & Level Assembly for your vehicle...
Old Dec 12, 2017 | 03:30 PM
FlyByMike's Avatar
FlyByMike
Back in ~ '76 when I was a Volvo mechanic, they told us the fuel pump sparking wouldn't start a fire or such because there was no oxygen available when in the liquid gasoline and the pumps themselves were "explosion proof" just in case. And they were cooled by the fuel itself.
A side note - don't welders say they's rather work on a full fuel tank than a partially full or empty tank because of the fumes ?
-Mike
Old Dec 12, 2017 | 05:52 PM
backsidedriver
i didn't pull it out far enough to see the extra items. I don't think i damaged the sender. Perhaps i have a defective new fuel pump. There are posts out there that stat it will come back to life after a few days of driving. Any truth to those comments?
Old Dec 13, 2017 | 05:45 AM
Lots of info here on the fuel filter cartridge side and the level sensor. Possible the other side float was bad. Its has two sensor. One on the fuel pump side and one on the filter side. But check that ar, if you bend it and it does not sense the arm, then that could be an issue. 16146765122/
https://www.northamericanmotoring.co...er-change.html
Old Dec 13, 2017 | 05:29 PM
backsidedriver
New symptoms with my fuel filter and fuel pump replacement. The gas gauge still does not work so either the fuel pump is defective or I unknowing damaged the sender on the fuel filter side. However, now there is a very strong gas smell on the outside of the car. Not the inside, but the outside. What would be causing this. Is the fuel pump sending too much fuel to the injectors? Again, the smell is only on the outside. No visible leaks in the engine compartment or inside the car. The smell is coming from the right (passenger side) rear.
Old Dec 16, 2017 | 08:24 AM
backsidedriver
Ok, so scratch the gas smell, this was my fault. I took the filter assembly out again and discovered that the rubber o-ring gasket was not seated properly. re-seated it and boom, no more smell. So, my only issue is still a gas gauge that does not work :-(
Old Dec 18, 2017 | 11:41 AM
Ok, well one thing fixed at least. My guess is the other side level sensor or the one you put in got bumped near the sensor. Do you have a scan tool, I would get this and select the fuel sensor and see if you can get it to read both sides. Or if you can get a code when you scan the system. It's on sale right now also.
https://www.northamericanmotoring.co...d-q-and-a.html
movieman
Jul 28, 2014 12:57 PM
jeff323
May 13, 2011 12:09 PM
JCR1960
Jun 12, 2008 06:06 PM
bmrking1
Classic Mini Talk
Mar 31, 2006 09:03 PM
