passenger window problem
Old Dec 11, 2017 | 11:19 AM
Bayce3's Avatar
Bayce3
Hey guys.......I've just recently (last 3 days) started having this issue with my 02 Mini....I woke up to a few days ago after it had been raining really hard the night before and was about to leave for work....went outside and my passenger window was all the way down....put it back up and dried the water as best I could...yesterday....same thing happened....twice.....put the window up and in about a half hour or so checked it ....back down again!!! I finally pulled the fuse....anyone else have or have had this issue???
Old Dec 13, 2017 | 05:56 AM
Wonder is the footwell module is on its way out or you hit the open door button on your key fob in your pocket. To happen multiple times my guess is the module after that really hard rain, most people have a leak in the sunroof from the drian tubes being clogged and then the footwell module/BCM gets wet. 61356982114 Sometimes you can get lucky and dry them out. I would open them up and check for water damage.
https://www.northamericanmotoring.co...-footwell.html
https://www.northamericanmotoring.co...g-on-help.html
https://www.northamericanmotoring.co...le-issues.html
Old Dec 18, 2017 | 09:47 AM
Bayce3's Avatar
Bayce3
Thanks! The guy I bought the car from didn't have a fob....just the "valet" key so it couldn't have been that I'm sure.....I think I' going to put the fuse back in and see if it does it again.
Old Dec 18, 2017 | 10:49 AM
So you just have the normal key or a plastic key. The key if it has all the little buttons they should work unless it was a re-bladed key or something.
Tommy Kardinal
Aug 8, 2016 08:25 AM
wega85
Apr 24, 2013 07:42 PM
HighSchoolzMINI
15
Oct 21, 2006 10:47 AM
ayyado
Electrical
Jul 26, 2006 10:15 PM
andrew
Oct 7, 2002 06:29 PM
