HELP! 2005 R50 A/T slow acceleration from stop
Old May 31, 2016 | 07:29 PM
audex1's Avatar
audex1
My Mini runs great especially after installing a Sprint booster, my problem is and has always been accelerating from a complete stop. If I floor the pedal it is slow to get up and go, once I get the rpm's up she moves pretty darn good. It feels like it is starving for air or perhaps the electronic throttle plate opens very slowly.
I have owned the car or about five years and do keep the car tuned up and have had the injectors cleaned. I did install a cold air intake and do keep the filter clean. New tires are properly inflated, trans seems to shift properly especially with the sprint booster. I have not replaced the timing chain yet.
I am the second owner, the previous owner had all her work done by the dealer. It has just over 100,00 miles on it, I replaced the fuel filter this weekend but it did not do much in the way of performance.
I do not believe this is how it performed when it was new, it is a safety concern of mine. I always fear that I could be hit from behind after making a right turn with traffic.
HELP HELP HELP!
Old Jun 1, 2016 | 06:05 AM
Hello,
Have you cleaned the throttle body ? I would do that first, it might be sticking. Have you have EP error come up on the transmission display ?
Old Jun 1, 2016 | 06:19 AM
audex1's Avatar
audex1
I did when I first got the car, since I have put about 25K miles on it but do keep up with injector cleaning and fuel additives. I did not notice a difference when I first cleaned the throttle body but I can try it again. I don't drive it much but did this morning, It feels like perhaps the timing chain is either off a tooth or just a bit worn not giving me the throttle response I believe it should have. The correct mileage is 113,450, again to my knowledge the timing chain has never been serviced.
No transmission code either.
Old Jun 1, 2016 | 06:23 AM
The timing chains are not the issue on Gen 1 MINIs for that ( you would here the timing chain slap or chatter), nor skip , if it did you would have major issues. Most of the time its the throttle body, pedal unit ( which throws a code) or the CVT has a issue and slipping. Do the throttle body first and see what the response is.
Old Jun 1, 2016 | 06:52 AM
audex1's Avatar
audex1
10 4 thanks, keep you posted.
Old Jun 1, 2016 | 07:19 AM
ZippyNH's Avatar
ZippyNH
Timing chains are not an issue on the gen1 cars....they are pretty much a lifetime (till rebuilding the motor) item....
If you hear a timing chain diesel type noise...then the tensioner for it, a 15 minute job, needs to be done before damage occurs.
The elephant in the room for non-supercharged gen1 auto cars is the CVT transmission....
Treated nice, with regular fluid changes some last a bit....but 75,000 miles seems to be their typical life....the metal chain in them wears....and gets the car stuck in a set "gear" or ratio, or fails entirely with chain parts filling the pan....so.etimes the cones that controls the chains wears....
I hope it not a CVT issue....
Does you have "EP" displayed on the odometer or any check engine lights?
Old Jun 1, 2016 | 06:57 PM
audex1's Avatar
audex1
No codes, the transmission seems to be shifting fine.
Old Jun 2, 2016 | 11:50 AM
nkfry's Avatar
nkfry
Poor acceleration is a trait of the CVT transmission, your car is running fine.
But a CVT replacement will always be looming on the horizon.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
MidwayMountaineer
Jun 27, 2022 07:39 AM
quickcoop
Dec 4, 2020 09:05 AM
MINIMIKO
Mar 21, 2016 11:01 AM
dn09MCS
Mar 14, 2016 08:50 AM
