error code p0705
error code p0705
HI guys can someone help me out please iv got a 2003 mini one 1.6 cvt and its done 55k its now gone into limp mode and will not drive over 11mph iv got EP come up on the clock's. Iv read the fault code on my delphi obd scanner and got p0705 come up with gearbox position sensor(PRNDL)
malfunction,faulty signal,permanent.The help i need is were is the sensor i need to test or change can someone put up an img of the sensor and were its located thx in advance.
HI martin thanks for your reply iv been trying now for 2 days with out any luck im getting loads of images but for other cars not for the mini one :-(
Hi martin iv tryed on real oem and still can not see were the gearbox position sensor is on my mini i will just try from inside the car first and then check on the gearbox its self thanks anyway.
Looked up part # on realoem It is in section # 24 on r50 section under trans. # is24357518731 Start Inhibit switch. cost $ 160.67. Hope this helps. Go to Realoem click enter then scroll down BMW #s until you get to R50 then fill in sections for your car then go through index to section 24 Trans. will show you parts and #s.
If you get things to work please send me an email. Let me know what fix worked. loon@3rivers.net
UPDATE ok guys today i changed the gearbox position sensor but i did'nt get the bmw one as it was to much money so i got the mg rover one as its the same sensor http://www.rimmerbros.co.uk/Item--i-UHB100170I fitted it then deleted the error code with my delphi scanner and the EP mode went away and the gearbox now works just has is should :-) sothat was a cheap fix i hope this helps others with the same problems.
Part No.: UHB100170
Switch-inhibitor change selector - Genuine MG Rover
Rimmer Bros, For all of your Car Parts & Accessories. Switch-inhibitor change selector - Genuine MG Rover and more, fast delivery, worldwide.
Part No.: UHB100170
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
hamptup
R55 :: Clubman Talk (2008+)
18
Nov 29, 2016 05:04 PM
MasterShaftner
Sep 4, 2015 03:52 PM
