Passenger side won't unlock
Old Jul 2, 2004 | 06:01 AM
Mr.Sticky's Avatar
Mr.Sticky
The passenger side door no longer unlocks with the toggle switch or remote. It does lock using these methods however. To unlock it I have to pull the interior door handle. I'm thinking it's the door lock actuator, but why then can I lock it with the toggle switch? Any ideas?
Old Jul 2, 2004 | 08:39 PM
lotsie's Avatar
lotsie
Ok the first thing that comes to mind is ,,,Mr" Sticky",,, could be stuck
Sorry could not resist that just came out.Take it to the dealer,you are probably right,the accuator is not working
Old Jul 2, 2004 | 09:53 PM
Mr.Sticky's Avatar
Mr.Sticky
Now that the MINI is out of warrenty I'll be fixing this kind of stuff myself if possible. As far as i'm aware there's no shop manual available yet that might cover this kind of thing. Plus, I'm a total cheap *** so I'd rather not pay someone to fix the problem. Anyone else?
Old Jul 2, 2004 | 10:05 PM
Yfoiler's Avatar
Yfoiler
Try this...
I had a couple of weird electrical problems with lights AND doors, so....
Disconnect the battery (l left mine off over night).
Reconnect it and the CPU will reboot and reinitialize everything.
That cured my lighting and door problem.
At least it's worth a try.
Good luck,
Yfoiler
Old Jul 2, 2004 | 10:06 PM
lotsie's Avatar
lotsie
Sorry,Not looking forward to be out of warrenty myself
Old Jul 5, 2004 | 11:08 AM
GordonD's Avatar
GordonD
I have a 2002 MCS and am just starting to get some reluctance with the passenger side up thingy - unless i am really close to the car - I guess I'll get it into the dealer soon or try Viagra
Old Jul 6, 2004 | 09:39 AM
MINIKIM's Avatar
MINIKIM
I have a similar issue, mine will only unlock with thetoggle switch or remote on the drivers side. If I pull the handle nothing happens.
Old Jul 8, 2004 | 07:42 PM
JustGo4It_'s Avatar
JustGo4It_
If the doors are locked you need to pull the handle twice to open the door.
Old Jul 8, 2004 | 09:43 PM
Mr.Sticky's Avatar
Mr.Sticky
The door does unlock normally when the handle is pulled but it won't unlock when the toggle switch is pressed or the car is unlocked with the remote. No luck with unhooking the battery either. I guess i'm stuck installing a new door lock regulator. Any ideas on removal/install info?
Old Aug 11, 2004 | 09:33 AM
MINIKIM's Avatar
MINIKIM
thanks for that tip, I have only had the car for over a year. Now I can stop crawling over the passanger seat to get in and out.
The lock broke.
Old Aug 11, 2004 | 09:52 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
You got your MINI in May 03 and you have how many miles on it now?
Could a regular shop help you troubleshoot the problem then you order the part through Classic auto campus in Ohio at a discount?
Old Aug 11, 2004 | 10:02 AM
vladimir's Avatar
vladimir
Up to 50K it is a warranty issue, they should replace the lock actuator. This isn't all that unusual- mine left me with the gas cap unable to open as well as the other issues on this thread. Hope you are under 50K... ?
Old Aug 11, 2004 | 10:03 AM
CharlesWil's Avatar
CharlesWil
Bentley Service Publications will have a MINI Cooper Service Manual: 2002-2004 available September 1, 2004. Including MINI Cooper and MINI Cooper S.
Softcover, 8 3/8 in. x 11 in.
968 pages
1118 Black and White Photos and 445 Illustrations
Bentley Stock Number: MC04
ISBN: 0-8376-1068-0
Price: $99.99
Charles
Old Aug 11, 2004 | 01:42 PM
Mr.Sticky's Avatar
Mr.Sticky
Absolutely a regular shop could do it. But as I'm at 55,xxx miles, and a huge cheap-***, i'd rather pull the door handle twice to unlock until the shop manual comes out and I can fix the problem myself. In fact i've already pre-ordered the manual. Will september ever get here?
Old Aug 11, 2004 | 04:44 PM
JustGo4It_'s Avatar
JustGo4It_
968 pages
ISBN: 0-8376-1068-0
Price: $99.99
Charles
$67.97 at Amazon
http://www.amazon.com/exec/obidos/tg...DKIKX0DER&st=*
Old Aug 4, 2008 | 09:29 AM
beemer2002's Avatar
beemer2002
Passenger door lock won't unlock
Has anyone found a DIY for removal/installation of a new actuator? My passenger side lock locks with the remote, but does not unlock with the remote of switch, only by pulling the handle from inside? Any help??
boostedhaze
Jan 2, 2018 07:26 PM
sevin
Feb 1, 2016 11:30 AM
RACEnSK8
Aug 31, 2015 01:08 PM
Russter500
Aug 26, 2015 12:11 PM
polotska
Aug 23, 2015 03:03 PM
