Flat tire indicator light flashing but no flat tire?
Old Jul 14, 2011 | 08:14 PM
mdbsat's Avatar
mdbsat
My flat tire indicator started flashing about an hour ago. I looked in the manual and it says if it is flashing to pull over right away and that if it is solid yellow there is just a malfunction. Well I just went and looked and checked tire pressures and they are all normal. This did happen right after I really gave it some gas from a stop light.
Just throwing that in, it may mena nothing.I also had my brake pads replaced last week.
Any thoughts? I am confused.
Thanks in advance.
Old Jul 14, 2011 | 08:19 PM
xsmini's Avatar
xsmini
Any other lights?
Sometimes if you get wheel spin the flat tire light and the DSC light may come on.
Nik
Old Jul 14, 2011 | 08:28 PM
mdbsat's Avatar
mdbsat
Just my check engine light that has been on for a year due to a code from my header or O2 sensor. Nothing else. I am going to go check again now and see if there is a flat tire.
EDIT: I am very familiar with the DSC light. This one is for sure the flat light indicator.
Old Jul 14, 2011 | 11:07 PM
Eric_Rowland's Avatar
Eric_Rowland
If you've checked the tires, just reset the TPMS and see if it recurs. In my experience, the light stays on - it doesn't flash. If the reset process (turn key on, hold TPMS button until the light goes out) doesn't work, you may have a wheel sensor issue.
Old Jul 15, 2011 | 03:56 AM
veggivet's Avatar
veggivet
Doublecheck your tire pressures. The sensor will activate if there is a pound or two difference in the psi of one tire compared to the others.
Old Jul 15, 2011 | 04:00 AM
yetti96's Avatar
yetti96
But on an '03 it is just based upon wheel speed comparison. I do agree though to recheck all pressures.
Old Jul 15, 2011 | 05:10 AM
BRGPA's Avatar
BRGPA
This has happened to me several times after a very quick turn, spinning tires on wet leaves, and other situations. When I reset, the light goes out and no more problems. It's never been a flat tire- Knock on wood!
Old Jul 16, 2011 | 10:12 AM
mdbsat's Avatar
mdbsat
Thanks for the reply guys. Eric I did what you said ( I didn't even know about the reset option) and all has been well for 2 days. It must have been something to do with the tire rotation.
All the tires are now at spec PSI. Thanks again all!
Old Jul 16, 2011 | 11:36 AM
Eric_Rowland
Good deal. I've had several false positives (and one real one ).
Powershift
Aug 16, 2015 05:14 PM
JamJam43087
Aug 16, 2015 02:02 PM
oldkid6
Aug 11, 2015 08:13 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
