R53...How do I change the Xenon bulb???
Old Jan 20, 2010 | 04:44 PM
svldvc's Avatar
svldvc
Hi.
I got R53 (2006 Cooper S) with HID projector headlights.
I looked up that the car takes D2R/D2S bulb.
I bought the bulb.
Tried to replace it and I found this Sh***T !!!!
What' the F** is that!!???
How the H*** do you take the bulb out of the igniter?
It seems that it's a one solid piece. I broke the damn thing trying to pull the bulb out of that.
Or better yet...how do you convert that thing to different bulb temperature (not stock)
I've attached the picture of what part Im talking about.
Please HELP.
THANKS guys.
Old Jan 20, 2010 | 08:10 PM
tazio's Avatar
tazio
Halogens FTW!
Old Jan 21, 2010 | 12:16 AM
Alpha Motoring's Avatar
Alpha Motoring
the mini xenon seems to be a loyal b*tch when i switched to philips ultinon 6k d2s a year ago i broke both ignitors ended up taking it to the dealer and bought new ignitors and had them do it
Old Jan 21, 2010 | 10:01 AM
svldvc's Avatar
svldvc
Wow...sucks bro. How much did Dealer rape you for it? I checked them out on Ebay and they are $100 a PIECE!! F***ing German Engineers!!!
Old Jan 21, 2010 | 10:10 AM
xsmini's Avatar
xsmini
Wow - they must have changed those in the newer years, my 03's were some of the easiest bulbs to change.
Good luck, sorry
Nik
Old Jan 21, 2010 | 09:14 PM
svldvc's Avatar
svldvc
bump...
Old Dec 13, 2011 | 04:41 PM
alx873's Avatar
alx873
how DO you change those things? i'm curious in replacing my D2S's on my 06 R53 projectors
Old Nov 7, 2015 | 01:35 PM
Mosman's Avatar
Mosman
Sorry for resurrecting this old thread. I found it as I was having the same problem. I've got an '06 R53 with HID's. What I've learned is that the bulb the OP shows a picture of is a D1S bulb, not a D2S bulb.
The R53 is supposed to use D2S bulbs, but some may use D1S bulbs. My passenger side headlight assembly is factory original, and uses a D2S bulb. My driver's side assembly was replaced in '10/'11 due to an accident, and it uses a D1S bulb. I'm not sure when or why it changed, but you may have 1 or the other. Check them before you fork out the cash for new bulbs.
Old Nov 11, 2015 | 11:41 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Some good info.
Also, there is a slight difference in the mounting of the bulb in cars from 07/2004 on, for anyone looking for how to replace the bulbs, we have a DIY here.
888.280.7799 | 6am - 5pm PST
Old Nov 11, 2015 | 12:07 PM
Mosman's Avatar
Mosman
To clarify:
A D2S bulb is just a bulb, and the igniter attaches to the back of it with a quarter-twist.
A D1S bulb looks like a D2S bulb, but the igniter is permanently attached to it and can't be removed.
Old Nov 11, 2015 | 01:31 PM
The 7/2004 there was a switch from the D2R to D2S . Both should pull out.
D2R
https://www.northamericanmotoring.co...-with-age.html
D2S 63217160806
https://www.ecstuning.com/Search/Sit...h/63217160806/
https://www.northamericanmotoring.co...t-working.html
minimofo
Nov 16, 2016 05:56 AM
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
