Need New Battery for My 2004 MC
The battery for my 2004 MC just died and needs replacement. What are the current replacement batteries that will provide an exact fit without any modifications. My research has come up with the NAPA 7547BAT (@$110), although I have read that some people have had a fit problem with this particular battery while others have not. The NAPA dealer tells me that his computer lists a different model: 7526R. The other battery that is supposed to be a perfect fit for my car is the AC Delco 47-6YR (@$121). Any replacement battery infomation would be greatly appreciated. Thanks.
Either would be more expensive than what you are looking at but well worth the price in my opinion.
Rich
Just an idea
I have an 04 MCS and I am due for a battery soon.
I noticed that Walmart has the group 47 battery for $75, but I am not sure if there are any mods needed.
You may want to check it out.....
Hope this helps.....
This thread may be helpful. Also add comments to the thread when you
find a battery that does or doesn't fit the MC.
https://www.northamericanmotoring.co...ns-for-mc.html
I put a group 34R Optima 800 cca in my MCS. It fit well, but I needed to put a spacer under the hold down bracket.
I just bought an '04 S. I've looked the battery over on all sides except the bottom. How do I tell how old the battery is? It is a "Mini" battery. Do I assume it is original after 6 years? Can't hardly belieive that. Do the numbers on top of the battery have any significance? Thanks for any help.
Bought my replacement battery for 04 MC at O'Reilly Auto Parts. Group 47, 72 months for $90.00. Added a 3/8" spacer in bottom of battery box but other than that is an exact fix for everything. Battery is made by East Penn (Deka).
Thanks for the help. That date on the neg terminal indicates 05/04. Hard to believe that the battery is going on years old. This car came from Utah and is now in Phoenix. Batts here usually last no more than 3 years, so I guess I better plan on replacing this one before summer. Thanks again.
wildwestrider
11
Jan 29, 2016 05:06 PM
jennster
Sep 28, 2015 06:19 PM
