Low Speed Fan Resistor - we need solution
Old Apr 7, 2014 | 11:46 PM
  #1076
chris.j.lamb's Avatar
chris.j.lamb
Fix still working..........
Old Apr 8, 2014 | 12:03 AM
  #1077
minsanity's Avatar
minsanity
Thanks for the discovery, Chris!
This mod has been such great help to the entire Gen1 population. It should be called the LAMB mod & you should be knighted!
Old Apr 8, 2014 | 12:22 AM
  #1078
chris.j.lamb
Knighted?
Well I am already a Freeman....
You are very welcome, glad to do my bit for the Gen 1 community.
Cheers
Old Apr 8, 2014 | 05:45 AM
  #1079
minsanity's Avatar
minsanity
Shared this mod w/ most of my Gen1 buddies!
Bless you, Sir Chris! We're all grateful!
Old Apr 8, 2014 | 07:34 AM
  #1080
tummi_gummi's Avatar
tummi_gummi
For those of your confused it's really rather simple and just made confusing by numerous posts. All you have to do to fix the low fan speed which comes on at 221 degrees and shuts off at 211 is jump the connections from the wire feeding from the harness at the capacitor over to the contact point at the outlet of the resistor so you are bypassing the capacitor and resistor. I jumped them both and cut them off entirely and my high speed comes on at 221 no problems. I really dont like 210 degrees + so to think high speed is 230+ is ridiculous to me. I think you will all be happy with this set up and it's free fix!
Old Apr 15, 2014 | 11:08 AM
  #1081
SmittyRN's Avatar
SmittyRN
This thread is great, I used it to do the resistor kit replacement. But I ordered extra stuff; specificaly a complete fan assembly at one point. If your 2002 or early 2003 needs fixing and you don't want to mess with any soldering, or if you suspect the fan itself has problems, you can just drop in a complete new fan assembly. Here's the link to the market thread. https://www.northamericanmotoring.co...-assembly.html
Old Apr 21, 2014 | 09:26 AM
  #1082
norm03s's Avatar
norm03s
Fix still working.
Old May 4, 2014 | 09:10 AM
  #1083
Mike1's Avatar
Mike1
Thanks for the pdf
And it takes for ever to get the old fan out & back in ....
whereas my fix can be done in the works car park during lunch times.....
and its £73 !!!!!!!!!!!!!! on amazon http://www.amazon.co.uk/Blue-Print-A.../dp/B00B8YUE6M
@ that price you might as well replace the whole fan assembly...........
Cheers
Chris
Has anyone got a summary of Chris' fix and the parts needed ( available in UK ) - I can see the posts on page 5/6 of the thread but there's so many posts it's confusing - what is the current resistor of choice and what gauge wire would I need ( electrical numpty although i can solder etc )?
Cheers
Old May 8, 2014 | 09:17 AM
  #1084
richas's Avatar
richas
Another successful fix. I mounted the resistor, with heat-sink compound, to my motor mount. (2005 R50)
Rich
Attached Thumbnails Low Speed Fan Resistor - we need solution-img_6887.jpg   Low Speed Fan Resistor - we need solution-img_6888.jpg   Low Speed Fan Resistor - we need solution-img_6889.jpg
Old May 8, 2014 | 11:00 AM
  #1085
drozd's Avatar
drozd
Did you use some heat sink paste?
Old May 8, 2014 | 04:54 PM
  #1086
richas's Avatar
richas
yes
Old May 21, 2014 | 10:57 PM
  #1087
JRoze's Avatar
JRoze
1yr in and still working (cross my fingers/knock on wood)
Old Jun 11, 2014 | 12:50 AM
  #1088
harty's Avatar
harty
http://www.ebay.com/itm/2003-2008-Mi...Model%3ACooper
I bought this for my 2003 Cooper S R53. The one in there already only has two red wires, the one I bought has three wires (2 red, 1 blue). I'm assuming this is because they have packaged the resistor to fit multiple models.
The resistor has fixed the low speed fan, as I can hear it when the AC is on.
I haven't heard the high speed turn on since. I'm hoping its just not hot enough for it.
Should I also replace the 'box' relay?
How can I test the high speed now its back together?
Old Jun 12, 2014 | 11:26 AM
  #1089
Manny_cooper's Avatar
Manny_cooper
Did this Mod and I have no regrets at all....plus it kinda looks cool in the engine bay area!
Old Jun 13, 2014 | 04:31 PM
  #1090
kmwoods's Avatar
kmwoods
No power for resistor fix.
What if there is no power in those wires at all? I have the car on, A/C on high, and tested with a voltmeter set to 10 VDC ranger. I would guess there should be power there right?
And thanks so much for this thread!
Rich
Old Jun 14, 2014 | 12:55 PM
  #1091
kmwoods's Avatar
kmwoods
Anyone else have this problem before?
Old Jun 16, 2014 | 05:45 PM
  #1092
kmwoods's Avatar
kmwoods
No power to fan?
I checked all of the fuses etc. Just not sure when there is supposed to be power on the wires. Anyone at all?
Old Jun 18, 2014 | 03:34 PM
  #1093
kmwoods's Avatar
kmwoods
Any ideas?
Any suggestions on this?
Old Jun 18, 2014 | 10:05 PM
  #1094
minibx's Avatar
minibx
Bump
Old Jun 21, 2014 | 11:51 AM
  #1095
elchilo4ever's Avatar
elchilo4ever
Knwoods.
Did You Check The Relays?
Old Jun 23, 2014 | 06:35 AM
  #1096
kmwoods's Avatar
kmwoods
I tested them with an ohm meter. But I may just go ahead and buy them. Do you know which one and what part? Also, if it is behaving normally, is there power on those wires all the time? Or just when a relay closes?
Thanks!
Originally Posted by elchilo4ever
Knwoods.
Old Jun 23, 2014 | 07:43 AM
  #1097
elchilo4ever
N' The Thick Wire ( Hi Speed ) Is Always Power.
N' The Relays Are Under The Hood.
R3 & R4.
But You Can Switch W/ The Others Relays
R1 & R2
The R2 is The Same At R4
N' The R1 Is The Same At R3
If You Want Just Do The Bypass
From The Hi Speed To The Low Speed.
I Hope That Help You.
Old Jun 26, 2014 | 10:42 AM
  #1098
kmwoods's Avatar
kmwoods
Yes! Great information. I have no power on those wires at all. All fuses are good. So relay is next option. I will swap relays first, then buy new ones just to see.
At first I added the resistor to the wires. When nothing happened, I checked power going to the wires....all dead. What is the bypass low-speed fix? I'll do a search for it too. VERY much appreciate the help.
R3 & R4.
R1 & R2
Old Jul 2, 2014 | 07:04 AM
  #1099
socalr53's Avatar
socalr53
Someone kind enough please post a summary on the first page
Mods- please make this thread a sticky
I am looking for the resistor and wiring diagram for an 05 r53. Thanks!
Old Jul 2, 2014 | 07:27 AM
  #1100
elchilo4ever
Hi!
Socalr53.
I Buy My Resistor From Mouser.
http://ph.mouser.com/Search/m_Produc...wszHYUMk2NYg==
Is Really Easy.
From The Plug Of The Fan Just Disconnect The Thinner Wire
( Low Speed Fan ) N' That Wire Connect
To The Resistor.
N' The Other Wire From The Resistor Connect To The Thick Wire
( High Speed )
But The Thick Wire Don't Disconnect From The Plug.
Attachment 95475
Attached Thumbnails Low Speed Fan Resistor - we need solution-forumrunner_20140702_072754.jpg
