Clubman S Transmission Problem 2008
Old Aug 20, 2008 | 01:30 PM
catguy's Avatar
catguy
08 clubman S,,,,,, 3200 miles totally great other then TODAY.... Started to day and put the in D and the torque converter does not allow the transmission to idle... Engine light came on and it is being picked up and transported 140 miles to the closest dealer... The idle seem way off also...I CALLED 3 DEALERS W NONE OF THEM EVER HAVING THIS ISSUE...... HUMMMMMMMMM.... i feel it is not the transmission rather it's the electronics...I will let you all know the outcome....
Old Aug 20, 2008 | 06:25 PM
JCR1960's Avatar
JCR1960
catguy that does sound strange but certainly keep us posted with what they found had caused the problem with your auto trans.
Old Aug 21, 2008 | 09:56 PM
Benibiker's Avatar
Benibiker
It does sound like a trans software issue... Keep us abreast and good luck!
Old Aug 25, 2008 | 04:20 PM
catguy's Avatar
catguy
2008 transmission clubman s problem up date
Talked to them today they have found that the engine is not firing on all cylinders correctly.. The have three techs on the Clubman Reprogramed the computer, changed the fuelpump, intake manifold, and two other parts...The have contacted the factory, local mini rep.. they are all over it as it is very new issue.....
Old Aug 25, 2008 | 04:23 PM
catguy's Avatar
catguy
the fuel curve is also way off.... I did notice the engine running very rich but the issue was the converter not releasing and the surging of the car.......
Old Aug 25, 2008 | 05:55 PM
JCR1960's Avatar
JCR1960
^^catguy that certainly does sound complicated with their findings just remember to keep track of the time at the dealership for the repairs should time run much longer.
Fingers crossed that they correct the problem and you will be back motoring in your Mini in no time.
Old Aug 26, 2008 | 03:39 PM
catguy's Avatar
catguy
This today's update... I am working with Northwest Mini in Tacoma WA.. Greg one if the service writers.The first way I deal with Any service shop or dealer is to make them fully aware of my background..I have been a drag racer for 20 years and totally understand that issues such as this issue are just the part of owning the beast.. Being new, used means nothing to me... All mechanical beasts have mechanical issues that is why warranties are written...
Old Aug 26, 2008 | 03:49 PM
catguy's Avatar
catguy
Now for the specific details and steps the dealer, factory rep, New Jersey entry shop for all Mini's,and finally the Factory engineers have taken to fix the mini clubman s... The engine is misfiring on all cylinders.. very rough... 1ST reprogramed the computer ( no fix), 2 nd, replace the complete computer ( no fix), 3nd brought in parked next to my clubman a NEW Clubman... replaced all sensors approx 5-7 that manage the engine.(no fix) 4th replaced the high pressure fuel pump ( no fix) 5th they are in the process of replacing the intake manifold (thinking there may be a crack.They will start it soon to see.. Now I asked them if they had done a compression test to see if Valves, rings, or piston damage? ( they have not do these steps)... They HAVE NEVER HAD this issue with any 08 mini's... This was the factory speaking to this dealership.. Oh well "THIS TO SHALL PASS".. I will keep you all posted.... 4 pm Pst
Old Aug 26, 2008 | 06:38 PM
JCR1960's Avatar
JCR1960
^^catguy thank you for today's update and yes we are all very curious as to what they find to have caused the actual problem.
We will be waiting for your next update when you can.
Old Aug 26, 2008 | 07:12 PM
Banjo's Avatar
Banjo
Hey Catguy. Not surprised as I am having a sort of similar problem with my cabrio with 1500 miles. When I put her in reverse, the engine light comes on and it goes into safety mode ie stays in 2nd gear. They fixed this once, happened again and now they are replacing the entire transmission. I have to wonder with all thats happening to your car when they throw their hands up and say you have a lemon and give u new car or refund.
Old Aug 26, 2008 | 08:28 PM
catguy's Avatar
catguy
the first issue was the motor was running very rough and when i put i drive the car surged like it was rocking forward like the converter would not idle.. then the engine light came on and It went on a truck to the dealer.. I explained the entire effort to make the car even run.. not fixed yet...
Old May 1, 2011 | 11:55 AM
catguy's Avatar
catguy
it has been totally great with my clubman s 34,000 miles now.. what are your feelings on transmission service now
Old May 1, 2011 | 12:02 PM
DneprDave's Avatar
DneprDave
So, what did they find and what did they do?
Dave
Old May 1, 2011 | 12:55 PM
catguy's Avatar
catguy
it took them 27 days to replace all necessary parts under the hood and no fix so they went into the dash and checked all grounds and FOUND a loose one.. all fixed and no problems... The main problem is the carbon build up on the intake valves due to the evac system sending oil vapor off the head into the intake maniflold.. This was done to clean up the enviroment.. oil mist coats the intake runners and also carbons the intake valves and the top of the piston..... Vw bmw also has the issue.. FIX... use only 91 octane gas and change your oil at every 6,000 miles forget about the free change find a shop that does mini work and have them do it.. 80 dollars... plus use bg44k treatment in your gas every 5 k miles which rides the carbon....
Old Jul 4, 2011 | 09:39 AM
tominizer's Avatar
tominizer
Wow...... interesting.
lalroma
20
Apr 2, 2022 06:19 PM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
kwijmbo
Aug 5, 2015 09:00 PM
