Drivers door latch dead
Old Jul 11, 2008 | 06:27 AM
TMMini's Avatar
TMMini
Does anyone have a clue how to open the door ? Latch will not release from either inside or outside. Cable to inside handle came loose at the latch mechanism. Repaired that and all was well for a day. Now it won't open from either inside or outside. Can hear mechanism trying to work but the rotary latch thingie does not release. Need to remove door panel for access which doesn't appear to probable without using a sawzall with the door stuck shut. Anyone have any suggestions? Reviewed the threads and all seem to relate to freezing which doesn't seem likely as it's 80+ here in Ohio.
Old Aug 25, 2008 | 03:00 PM
minikikas
stuck door
Did ya fix da door
Old Aug 29, 2008 | 02:37 AM
TMMini's Avatar
TMMini
Yup! Works now but had to take it to a dealer. Put a new latch assembly in. Not sure how they did it without using a can opener. Embarrassed couldn't figure it out but they did it under warranty. No complaints here
Old Sep 2, 2008 | 08:56 AM
BEAVR's Avatar
BEAVR
my 1 year old son pulled my latch out, took a #25 torx and a $7 pry tool. lock popped back in pretty easily. its held in the plastic slot pretty flimsily I think, so I can see it popping out if banged real hard.
Old Sep 4, 2008 | 05:56 AM
TMMini's Avatar
TMMini
Previously had the problem with the inside handle/cable operating system. Fixed that. You're right, a little flimsy(?). This was with the actual latch/lock assembly in the back of the door. Inside and outside handle and mechanical linkages were working properly, just wouldn't open the door. MidWest Mini got it open somehow and replaced the assembly in the door. Don't have to practice yoga to get in and out now.
Old Sep 4, 2008 | 06:22 AM
Partsman's Avatar
Partsman
Legion_of_Doom
The outer belt molding on the door just pulls up, exposing a gap big enough to get a tool in there to release the latch.
Old Sep 7, 2008 | 07:20 AM
TMMini's Avatar
TMMini
AH HA! Thanks, will be ready if it does a repeat performance.
Old Oct 12, 2008 | 01:48 PM
Sweethouse1's Avatar
Sweethouse1
I have just had this same thing happen on my 04. It is the passenger side though. How much did the dealer charge for the fix?
Old Oct 12, 2008 | 02:21 PM
TMMini's Avatar
TMMini
My fix was a freebe just barely under warranty. Think it's about a 2.5 hr fix and that latch assembly is like $105 on internet, undoubtedly more at dealer.
spackletooms
Sep 1, 2015 10:12 PM
Knuckle14
Aug 26, 2015 08:10 PM
SheldonCooperS
Aug 25, 2015 11:57 AM
PrimePower
Aug 11, 2015 12:51 PM
