R50/53 2004 Door on a 2003?
Old Aug 11, 2015 | 08:38 AM
PrimePower's Avatar
PrimePower
Hey guys, new here and I just picked up a 2003 MCS. I have just noticed under the drivers door, it's rusted in the seam pretty bad. Couldn't notice it until under the door. Anyways, I found a 2004 MC door, same color for a good deal. Just wondering if the door will work on mine? My build date is 10/02. And I believe the new door is 06/04. I know there may be some inner parts that have changed, but I'm wondering mainly about the skin? Thanks guys
Old Aug 11, 2015 | 09:54 AM
I believe there was a crash standard update on the door also the dynomatt stuff. 7/2004+ it changed to the newer part number 41517202911 and 41517202912 are the R50 R52 R53 part number now.
https://www.northamericanmotoring.co...-no-bondo.html
Old Aug 11, 2015 | 10:03 AM
PrimePower's Avatar
PrimePower
I believe there was a crash standard update on the door also the dynomatt stuff. 7/2004+ it changed to the newer part number 41517202911 and 41517202912 are the R50 R52 R53 part number now. https://www.northamericanmotoring.co...-no-bondo.html
Thanks. I just got the vin from the newer door. The build date is 01.02.2004. So I'm assuming it should work?
Old Aug 11, 2015 | 10:04 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Welcome to NAM. I think you might be fine. Looking on RealOEM, the part numbers seem to be the same. Not 100% about the rest of the door components though.
The part number for the door on your 10/02 is 41517202911 according to RealOEM:
Part number for 06/04 is 41517202911 (same part number):
888.280.7799 | 6am - 5pm PST
Old Aug 11, 2015 | 10:12 AM
Yep,
When you hang it make sure it lines up , there are factory shims to line it up.
http://www.realoem.com/bmw/enUS/show...59#41517202912
41517202047 1mm
http://www.ecstuning.com/Search/SiteSearch/41517202047/
41518173321 0.5mm
http://www.ecstuning.com/Search/SiteSearch/41518173321/
Old Aug 11, 2015 | 11:13 AM
PrimePower's Avatar
PrimePower
Thanks guys!
Old Aug 11, 2015 | 11:17 AM
You are welcome. I have aligned the doors before. Tighten then loosen and adjust. Two pivot points hinges and the striker.
Old Aug 11, 2015 | 11:19 AM
PelicanParts.com
Vendor
Originally Posted by PrimePower
Thanks guys!
Anytime! Good luck and let us know how it goes!
Old Aug 11, 2015 | 11:21 AM
PrimePower's Avatar
PrimePower
Will do. Love this site. Used the instructions on here and changed the AC clutch coil. Nice cold AC now. Great tips.
Old Aug 11, 2015 | 11:26 AM
PelicanParts.com
Vendor
Glad it has been helpful to you! There are a lot of people on here with some great knowledge about these cars.
Old Aug 11, 2015 | 12:51 PM
JABowders's Avatar
JABowders
Veteran: Army
...and every time you get in and out it will be like time travel...
Motor on!
wildwestrider
Dec 27, 2015 08:20 PM
dscott90000
Sep 9, 2015 07:55 AM
Filmy
Sep 7, 2015 08:27 PM
