Question for the Chrono Pack (non-Nav) owners
Old Jun 11, 2008 | 10:18 AM
leslie's Avatar
leslie
Hi everyone,
I took my MINI in for service on Monday because I've had to fill the coolant reservoir twice within the past month. It turned out that I had a coolant leak so the coolant thermostat and housing was replaced. Before I brought my MINI in I noticed that the temperature gauge would read at 3/4.. approximately 195F.
Yesterday morning I went out and after about 5 miles of driving, the needle quickly climbed up to 3/4 again. So my question is.. is this normal? I mentioned it when I brought my car in on Monday but the SA either wasn't listening or didn't care. I don't have access to a ScanGauge so I can't check the temperature manually. Can anyone that has the Chrono Pack (w/o Nav obviously) let me know what position their temp needle is normally at?
I'm trying not to stress too much about this but it doesn't help that my current navigator keeps reminding me every 5 min. that the needle should be in the middle, and not at 3/4.
Last edited by leslie; Jun 11, 2008 at 10:25 AM. Reason: i didn't have my caffeine this morning and managed to screw up my numbers.
Old Jun 11, 2008 | 11:24 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Hmmm... Mine sits at about 50-55% most of the time... and I thought 50% (straight up) on the gauge was closer to 195F... 3/4 would be considerably higher than I've seen it.
Curious. When off, does the needle go all the way over to like the 5 o'clock position? If not, might just be a needle position/calibration issue. But otherwise, you shouldn't be running at 75%ish all the time... post in your local club forum and find someone with a scangauge to check your temp...
Old Jun 11, 2008 | 11:41 AM
leslie's Avatar
leslie
Based on the way the gauge is set up, I think 140F would be 50%.
When the MINI's off, he's at 30F (5 o'clock position). The gauge starts at 30F.. next number shows 140F.. the one after that is 250F. I'm right smack in between 140 and 250, which is 3/4 of the way, and at about 195F if I'm estimating it correctly.
I've "borrowed" and manipulated the attached photo from Lyle to show where my needle usually is (sorry for stealing, but it was the first chrono pack-related photo I found that wasn't super tiny).
Old Jun 11, 2008 | 11:50 AM
cadfael_tex's Avatar
cadfael_tex
Mine sits straight up without fail and has since new.
Old Jun 11, 2008 | 11:56 AM
BlimeyCabrio
Duh.... yeah.... not in my car and forgot how it looked (that's my gauge face in the pic, by the way )
So, yes... when "normal" and warmed up mine is vertical... which corresponds to 195F on my Scangauge... occasionally it gets as high as 205F and the needle moves a bit to the left accordingly.
Old Jun 11, 2008 | 11:58 AM
leslie's Avatar
leslie
So Geoffrey's normal then? I'm just freaked out cuz that's technically 3/4 of the way in...
Old Jun 11, 2008 | 12:29 PM
ScottRiqui's Avatar
ScottRiqui
Yes - that's normal. The choice of minimum and maximum temperatures to display on the gauge are pretty much arbitrary. MINI could have chosen to have the gauge read from 140F to 250F, then the "normal" reading would be at 50% of the gauge travel rather than 75%.
Unless something's wrong with your car, the normal coolant temperature is going to be within a few degrees of the thermostat temperature. If your needle settles much higher or lower than vertical on the gauge, there may be a problem, but otherwise, you're fine.
Old Jun 11, 2008 | 01:31 PM
BlimeyCabrio
... Looks better with the needle vertical. That's why they did it, I bet. Damn designers.
Old Jun 11, 2008 | 02:39 PM
eager2own's Avatar
eager2own
Thought they did it so that the needle would match the one on the speedo when I'm driving around town.
Old Jun 11, 2008 | 04:44 PM
BlimeyCabrio
Yeah, that's what I meant. Looks better.
Old Jun 11, 2008 | 04:56 PM
minianni's Avatar
minianni
Maybe they did it to be be like the race cars. Most race cars orient their gauges to read straight up... that way if there is something wrong it's easy to to see.
Old Jun 11, 2008 | 05:15 PM
Crashton's Avatar
Crashton
Do keep an eye on Geoffrey's coolant. It's not uncommon for the coolant to drop a bit after the system has been worked on. It's no big deal just add a bit if needed & motor on.
Old Jun 11, 2008 | 09:03 PM
leslie's Avatar
leslie
Thanks to everyone that responded!
Will do. Thanks.
2011cooperSconvertible
R57 :: Cabrio Talk (2009+)
Apr 1, 2019 06:03 AM
MoganDavid
Mar 14, 2016 10:44 AM
kyungmanpark
Aug 23, 2015 07:26 PM
missinmyjeep
Aug 22, 2015 07:13 PM
Powershift
Aug 16, 2015 05:14 PM
