Catalytic Converter DOA @ 9800 miles
Old Jun 9, 2008 | 01:38 PM
MEEPY's Avatar
MEEPY
MEEPY just got home after having the catalytic converter replaced. I have less than 10k on her and I'm concerned I'll have another problem child like my dearly (and happily) departed Jetta.
Anyone else had any similar problems? The SA at Universal City MINI told me that he's only seen 4 replaced since 2005, but that could be a line, so I thought I'd check with you guys since I trust you more!!
Old Jun 9, 2008 | 02:18 PM
healey67's Avatar
healey67
What year is your MINI??
Old Jun 10, 2008 | 09:15 AM
MEEPY's Avatar
MEEPY
2007. Got it in November of 07. It could be that the SA was talking about his experience with R53. Has anyone else heard of any problems with R56's catalytic converter?
-dustin
Old Jun 10, 2008 | 09:32 AM
korby's Avatar
korby
How did you know it was bad ?
Old Jun 10, 2008 | 09:38 AM
misslindsey's Avatar
misslindsey
Bad cats happen, unfortunately - just like any part there are bad apples. Keep your eye on her, but a new cat may be the solution to your problem. If the dealer didn't uncover any codes other than catalyst, you're probably fine. If you had an underlying problem (misfire, running rich) that toasted a cat in less than 10k, you'd know and it'll happen again soon enough.
Old Jun 10, 2008 | 09:39 AM
misslindsey
CARB (and by adoption, EPA) requires that a bad catalyst set a check engine light.
Old Jun 13, 2008 | 02:23 PM
MEEPY's Avatar
MEEPY
yes, this. It came on once about 1000 miles ago but went off on it's own. i assumed i didn't set the gas cap properly and dismissed it.
The SA said that the honeycomb in the cat was shattered, but I can't remember hitting anything or hearing anything funny. I live in LA and potholes are the only bumpy obstacle. I don't know how that could have happened. Weird.
Old Jun 13, 2008 | 07:56 PM
misslindsey
It could have been dropped at the factory, or just been heat treated wrong from the get-go. As long as all the bits were contained in the cat (I've seen a Chrysler ingest a cat into the engine, but that's not really possible with a MINI) you should be good to go for a good long while (at least 120,000 miles) with a new one.
Old Jun 15, 2008 | 10:33 AM
MEEPY's Avatar
MEEPY
wonderful news, indeed. She's back to normal, so I don't see any reason to fret unless something else starts knocking around.
Old Jun 16, 2008 | 07:27 PM
checkercoop's Avatar
checkercoop
I think this could be what I could be running into...I have been throwing a cat code a few times...comes on, no change in engine/drive/etc, but throws code that eventually goes away...dealer read it and is investigating what needs to be done...Oct 07 build
Old Jun 25, 2008 | 02:42 PM
NY_R56's Avatar
NY_R56
Hmm, could be a epidemic. I also had a bad cat and had it replaced at 11k miles by my dealer, Sept 07 build date. Unlike checkercoop, My MINI had a bad case of low rpm spuddering and backfiring(kindof). My ScanGauge II gave me a weird code (U3FFF) when it went off.
Old Sep 11, 2008 | 05:51 PM
jjshoe's Avatar
jjshoe
its a known issue that bad cats were used in 07 and possibly 08
Old Sep 11, 2008 | 06:03 PM
rrcaniglia's Avatar
rrcaniglia
08 MC built in Jan or early Feb. No issues.
Old Sep 11, 2008 | 06:20 PM
Oxybluecoop's Avatar
Oxybluecoop
There are two cats which one went bad?
Old Sep 11, 2008 | 06:28 PM
Sin MINI's Avatar
Sin MINI
Everyone keep in mind that Cats are covered by warranty way out past the normal warranty. Required by law. SOmehting like 10 yrs/100K miles or something insane like that.
Won't apply to the 2nd gen crowd for a while, but useful to know
Old Sep 11, 2008 | 06:48 PM
Jenanhill's Avatar
Jenanhill
04 MC. My cat went out at about 10,000 miles, too. They told me at the time that they had never seen that problem.
Old Sep 11, 2008 | 08:24 PM
checkercoop
I forgot to post on here about it, but I had mine replaced about a month ago. It definitely fixed it because the code has not come back. i was in the first week of october 07 build.
OXYBLUECOOPER,
Mine was the first cat with the headers.
W0TM8
Dec 19, 2019 07:50 AM
SunnySideUp
11
Aug 26, 2015 06:42 AM
Zettinger
Aug 25, 2015 04:04 PM
Powershift
Aug 16, 2015 05:14 PM
massmini03
Aug 12, 2015 11:19 AM
