Empy Gas Tank Makes MCS run better?
Old May 30, 2008 | 10:46 AM
SparklingMini's Avatar
SparklingMini
I noticed as recent as today that my MCS seems to have great throttle tip in and acceleration (non-sport mode) when my gas tank is almost empty. This is promising since I'm schedule to take the Mini in because I feel the acceleration has not been what it was since I puchased a month ago.
What are the benefits of burning the tank low?
Old May 30, 2008 | 10:47 AM
Guest's Avatar
Guest
Could I be getting air in my tank?
What are your thoughts?
Old May 30, 2008 | 10:54 AM
user 7082082's Avatar
user 7082082
Spending a great 300bux on a new fuel pump.
Old May 30, 2008 | 11:01 AM
SparklingMini
I burned the tank low to get some bad gas out of my tank. Then I filled up with Chevron Super and put a bottle of Techron in.
Old May 30, 2008 | 11:10 AM
ThumperMCS's Avatar
ThumperMCS
Maybe it feels better because its lighter that way .
Old May 30, 2008 | 11:12 AM
ahendy's Avatar
ahendy
That's exactly what I was about to say! My Outback is always zippier when the tank is low. It's not a good thing though!
Old May 30, 2008 | 11:22 AM
Mishka's Avatar
Mishka
Or maybe it's because it's in a hurry to get to the gas station.
Old May 30, 2008 | 11:29 AM
mellowmcs's Avatar
mellowmcs
Good to hear that your car feels stronger again
I don't know of any benefits of burning the tank low except less weight ~6lbs per gallon. However, as many others have said, you can burn out the fuel pump prematurely if you run it low on a regular basis.
Old May 30, 2008 | 11:32 AM
SparklingMini
I never go below 30 miles like the manuel suggest. I have 50 miles to go on this tank.
Also, thinking about the power issue. It's very HOT in Dallas, Texas. I heard that heat does effect the power and efficiency of turbocharged cars. Anyone heard that?
Old May 30, 2008 | 11:42 AM
sequence's Avatar
sequence
I cant believe I just read this thread. good grief
Old May 30, 2008 | 11:43 AM
mellowmcs's Avatar
mellowmcs
heat is the enemy of engine power regardless of if the engine is turbo or naturally aspirated. however turbo/super charged engines do suffer worse due to the nature of turbo/super chargers. since they are designed to pack in more air by compressing it, the hotter, less dense air will decrease power.
Old May 30, 2008 | 12:39 PM
miniclubman's Avatar
miniclubman
A 13 gallon tank will hold about 100 pounds of fuel, so a nearly empty tank would affect the vehicle acceleration. I don't think it would be that big a difference, but you may be able to notice.
iggi
18
Feb 9, 2026 01:00 AM
phrza81
Oct 10, 2015 11:37 PM
dchang0
Aug 10, 2015 03:37 PM
bc219
Aug 10, 2015 11:22 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
