R56 service / brake lights etc reset procedure
Old Apr 11, 2008 | 09:57 AM
TWISTER's Avatar
TWISTER
Posted by ONED on MINI2
OK Folks the info you have all been waiting for - sorry it took so long to compile - but have managed to get round all those R56 service light resets. The main one people are asking for is the Brake indicator reset after changing pads and fitting a new sensor, but the procedure is the same for all service indicator resets.
Please do not reset any of your service lights if you have TLC cover for this work.
I take no responsibility for how this info may be used!:rolleyes:
Anyway......
To enter the service Menu:
Insert Key
Do not press clutch / brake
Press Start button
Wait until the Car / revelant Service symbol disappears on the Rev counter display
Immediately after the symbol goes out - Press and hold Both buttons on the Rev Counter
Continue to hold - the system Will run a dash light check:rolleyes:
Continue to hold
Display will then show VIN / Menu, - continue to hold through this until the time Reappears on the display.
Now release Only the Right hand Button (trip reset) for about a second, and then press and hold again (whilst still holding the LH button)
After another second of 2 the display will show the Front Brake Symbol You Are Now in the Service Menu:D
Use the BC Button (on indicator stalk) to scroll through to the relevant symbol - eg Rear Brakes
To Reset the warning indicator light - Press & Hold the BC Button at the revelant symbol until RESET appears - then press and hold again until the process is complete.
Turn Off and On the Ignition again - Warning should now have gone!
Good Luck !
Mods can you please add a copy of this Info to the FAQ & DIY Section, and can you also Sticky this?
Old Apr 11, 2008 | 11:26 AM
djam43's Avatar
djam43
WOW,!!!!, That is fantastic info for us DIYs, Thanks. (I will recommend that it be made a STICKEY )
Old Apr 14, 2008 | 07:57 AM
miktvk's Avatar
miktvk
sorry, but what is 'TLC cover', do you mean the regular service plan?
Old Apr 15, 2008 | 11:37 AM
VelvetFoot's Avatar
VelvetFoot
Thanks!
Old May 5, 2008 | 09:03 AM
unclemeat's Avatar
unclemeat
I did this just to watch the guages swoop! Co0L!!
Old Dec 9, 2008 | 06:46 PM
daveK9's Avatar
daveK9
Good stuff.... !!
Old Jan 20, 2009 | 07:25 PM
1992's Avatar
1992
That rocks! This car is more and more like a video game every day. The above reminds me of entering the left-left-right-right-up-down-up-down-B-A-Start code on Contra/Life Force :D
Old Jan 25, 2009 | 05:54 PM
OkieSnake's Avatar
OkieSnake
Twister,
A BIG Thanks! You saved me half a day to take it into the dealership just to have them reset it (and possibly even charging me) after I had all ready done all the work. Great post!
Old Mar 18, 2009 | 06:19 AM
PaulCIssa's Avatar
PaulCIssa
Thanks Twister. Another happy customer!
Old Apr 7, 2009 | 03:28 PM
ewhite's Avatar
ewhite
Yes indeed, thank you VERY much Twister, another happy customer here as well! (who thinks of these silly code sequences??!)
now to go on a search to see how to reset the low washer fluid indicator
Old Apr 8, 2009 | 04:20 AM
corcoranwtnet's Avatar
corcoranwtnet
"now to go on a search to see how to reset the low washer fluid indicator "
This is one of the easiest resets around: take a quart of washer fluid and put it in the reservoir. Not only does this reset the light, it allows you to clean the glass without exiting the car.
(At least I assume it resets the light...I've never had mine go on, heh, heh).
Old Apr 8, 2009 | 07:07 AM
ewhite's Avatar
ewhite
Haa! You would think! But alas, the reservoir is full and yet the warning light remains :(
Old Apr 8, 2009 | 09:45 AM
corcoranwtnet
Yoiks!
A trip to the dealer when you need washer fluid? Yoiks!
Old Apr 20, 2009 | 08:10 AM
Argencooper's Avatar
Argencooper
I take some pictures to be more helpfull this DIY
Insert Key (Do not press clutch / brake)
Press Start button
Wait until the Car / revelant Service symbol disappears on the Rev counter displayImmediately after the symbol goes out - Press and hold Both buttons on the Rev Counter
Continue to hold - the system Will run a dash light check.
Continue to hold.
Continue to hold through this until the time Reappears on the display.Now release Only the Right hand Button (trip reset) for about a second, and then press and hold again (whilst still holding the LH button)
After another second of 2 the display will show the Front Brake Symbol You Are Now in the Service Menu.Use the BC Button (on indicator stalk) to scroll through to the relevant symbol - eg Rear BrakesTo Reset the warning indicator light - Press & Hold the BC Button at the revelant symbol until RESET appears - then press and hold again until the process is complete.Turn Off and On the Ignition again - Warning should now have gone!
Old Apr 20, 2009 | 08:20 AM
Argencooper
I have the Rear Brake Pad light on.
I tried to reset it with this DYI but I can't. I tryed to do it with the Front Brake and nothing. So I reset a simbol that looks like this: (O).
Front Brakes Reset Ok, but rear it is impossible....
Any suggestion????
Old May 15, 2009 | 03:08 PM
MiniPOLACK's Avatar
MiniPOLACK
ummm, i dont think it works on a 08 up mini, does it???? i just tried it and it goes through the gauges check and then it goes back into the normal exclamation mark ..no VIN nowhere :(
Old May 15, 2009 | 03:29 PM
Oxybluecoop's Avatar
Oxybluecoop
I tried to reset it with this DYI but I can't. I tried to do it with the front brake and nothing. So I reset a symbol that looks like this: (O).
Any suggestion????
So once you got to that symbol you held in the button?
Old May 15, 2009 | 03:30 PM
Oxybluecoop
It does work on all 2nd gens.Once the light check is done you immediately let go of the right button(don't let go of the left one) for about three seconds and press it again for another three or so seconds and then you should be there.
Old May 16, 2009 | 07:51 AM
MiniPOLACK's Avatar
MiniPOLACK
in the instruction it says to continue holding both buttons until VIN appears.
Old May 16, 2009 | 08:20 AM
Oxybluecoop
My mistake you are correct on waiting for the VIN to appear. I'm gonna make a video of the procedure since I just changed my coolant and rear brake pads so I need to to reset mine.
Old May 16, 2009 | 11:24 AM
MiniPOLACK's Avatar
MiniPOLACK
damn it.... still no luck ....wth is wrong with my car...funny thing is i tried the same thing on my friends 07 and other 08 models ( 3 cars total) and had no luck getting that VIN on...when i put the key into ignition and press start i have that huge exclamation mark on and it doesnt want to disappear , i waited the longest like 5mins
Old May 16, 2009 | 11:35 AM
Oxybluecoop
Try closing your door first!
Old May 16, 2009 | 11:44 AM
MiniPOLACK's Avatar
MiniPOLACK
LLOOOLLLLLL i just choked on my food........somebody edit the procedure please .....open door was the problem ...LOL
thank you a million Oxy..i hope God will reward you with plenty of children :P
Old May 16, 2009 | 11:52 AM
Oxybluecoop
Oh hell no!
Old May 16, 2009 | 08:52 PM
MiniPOLACK's Avatar
MiniPOLACK
hmmm... ok so i reseted everything possible, or so i thought...i still have that dreaded "service" light on every time i start the car, what gives?
