Clubman S oil leak @ 1800 miles!
Old Apr 7, 2008 | 06:16 PM
jameszimo's Avatar
jameszimo
After noticing an oil spot in the garage, I have found a leak in what I believe is the engine seal between the transmission and engine. I also think that there might be a missing fastener between the two (see the third picture). Maybe this is causing the leak?
After taking the first two pictures, I wiped the area clean. The rag definitely smelled of engine oil and was dark brown. After 24 hours, there was already a new drop forming (3rd picture).
Can someone confirm or deny my suspicions? I'm a total rookie when it comes to this stuff and before I head to the dealer I'd like to hear what others think.
Thanks.
Attached Thumbnails Clubman S oil leak @ 1800 miles!-oil_1.jpg   Clubman S oil leak @ 1800 miles!-oil_2.jpg   Clubman S oil leak @ 1800 miles!-oil_3.jpg
Old Apr 7, 2008 | 06:38 PM
korby's Avatar
korby
Ok I tried to get under to see if a bolt goes there , but I'm to old ! But it should not be leaking bring it in .
Old Apr 7, 2008 | 09:12 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
I had the EXACT same issue with my 2007 MCS! From day one it leaked. I just thought it was Cosmiline melting off the engine. It kept doing it for weeks so I took it in. Turned out it was the rear main seal that was leaking.
the "missing bolt", according to my MA, isn't actually missing. there isn't supposed to be one there for whatever reason.
Old Apr 8, 2008 | 05:39 AM
STLMINI's Avatar
STLMINI
warranty happens.
Old Apr 8, 2008 | 05:06 PM
ClubmanS's Avatar
ClubmanS
What is your build date? Damn I have to check mine..
Old Apr 8, 2008 | 06:22 PM
jameszimo's Avatar
jameszimo
Build date was in the last week of January.
I dropped the MINI off at the dealer this morning and the last I heard they were doing the dye/UV test to figure out where the leak was coming from.
Old Apr 8, 2008 | 06:43 PM
ClubmanS's Avatar
ClubmanS
Mine was 3rd week of January.
Please keep us posted.
Old Apr 8, 2008 | 09:51 PM
Benibiker's Avatar
Benibiker
Oil leaks in new cars **** me off!
Old Apr 8, 2008 | 10:00 PM
tazio's Avatar
tazio
British cars are neat. So much character.
Old Apr 8, 2008 | 10:42 PM
surfblue's Avatar
surfblue
Family tradition
Thanks.
Surfblue says: Your car is simply carrying on an old British tradition. My 62 Cooper did it, my 70 Norton Commando did it, my 07 S hasn't done it YET.
Old May 9, 2008 | 05:31 AM
aem421's Avatar
aem421
I, too, am having the same issue. I have monitored it for a few weeks now by taping a white piece of paper to the garage floor. My suspicions are correct. I have the exact same leak. Made an appointment with the dealer. Car is going in on Monday
Old May 9, 2008 | 06:53 AM
Donna/Mike's Avatar
Donna/Mike
Sand Dollar Collector
Rut Row....this is not good.... Please keep us posted on the outcome...
Donna
Old May 9, 2008 | 08:01 AM
eron's Avatar
eron
There is an old joke: Why don’t the British make refrigerators? They can’t figure out how to make them leak oil.
Old May 9, 2008 | 09:49 AM
aem421's Avatar
aem421
I will. It's really got me a little p'd off though. I've been driving for almost 30 years and this is the first car I have ever had to have the transmission fixed because of a leak.
Donna
Old May 9, 2008 | 10:20 AM
djam43's Avatar
djam43
Come on Guys, be reasonable.!! ONE LEAKY GASKET or seal in thousands of cars. whats the panic.
Old May 9, 2008 | 10:24 AM
Guest's Avatar
Guest
Thanks.
Definitely looks like the rear main seal is leaking. Not good .
Old May 9, 2008 | 12:15 PM
jameszimo's Avatar
jameszimo
It was the rear main seal. Plus, the dealer replaced the input shaft seal while they were at it.
Old May 9, 2008 | 12:34 PM
Guest's Avatar
Guest
Hope that solved your problems, good luck!
Old May 9, 2008 | 02:55 PM
taskmaxter's Avatar
taskmaxter
Glad to hear your back on the road. How long did the dealer have the car for?
Old May 9, 2008 | 03:30 PM
jameszimo's Avatar
jameszimo
They had it for 6 days! I guess the mechanic who worked on it had to take a day or two off...
They gave me an 07 MC auto as a loaner for the week and it was a blast to drive! (A little more of a hassle to get the kid in the carseat, however.)
Old May 11, 2008 | 07:19 AM
fastfritz's Avatar
fastfritz
Welcome to the world of british auto. Our MG T series clubs news letter was called Perpetually Dripping. One of the mesteries was the cotter key
in the bell housing that was put in at the factory from the inside out. Finally
our tech editor, who worked at the factory, revealed its purpose. It was the
factory fix for the leaky rear main seal. It kept the oil from building up in the bell housing and oiling the clutch disc by letting the oil drain out the bottom of the bellhousing. Nice fix
Old May 11, 2008 | 07:39 AM
ClubmanS's Avatar
ClubmanS
I have owned 4 MINIs, including a Clubman S like the one owned by the OT, and never have experienced any oil leaks, so pls don't generalize.
Old May 15, 2008 | 04:34 AM
aem421's Avatar
aem421
UPDATE: I took the car in on Monday. It was a leaking from the valve cover, not the transmission. They replaced the whole thing. I guess it ran down the side of the block to where the transmission sits. I picked it up on Tuesday afternoon. Great customer service at Mini of Towson . No problems so far . I'll keep checking it every chance I get, just to make sure.
Old May 16, 2008 | 10:19 PM
Donna/Mike's Avatar
Donna/Mike
Good to hear that all is better now....
Donna
Etrain
16
Aug 5, 2024 04:37 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
elightbo
Aug 17, 2015 01:50 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
