Need help from someone who has done KD Backtap or something similar...
Old Apr 7, 2008 | 11:47 AM
JCampos's Avatar
JCampos
So far, here is what I have done:
1. Taken off intercooler
2. Removed 1 bracket and loosened another to get access to all the bolts on the crankcase.
3. Disconnected all hoses and wires attached to crankcase
4. Removed crankcase cover.
Now I am stuck... do the long metal sleeves for the spark plugs come out with enough yanking or do I have to remove the f'ing crank
Thanks for the help.
Old Apr 7, 2008 | 12:54 PM
herbie hind's Avatar
herbie hind
you have stripped plug threads? do a search and contact some of the success stories via pm . fwiw no one has mentioned the need to pull the sleeves .
Old Apr 7, 2008 | 01:19 PM
JCampos's Avatar
JCampos
The reason I think those f'ers need to come out is cuz the backtap doesn't reach... It's impossible to tighten that thing with that POS sleeve in the way.
Old Apr 7, 2008 | 06:11 PM
Rich.Wolfson's Avatar
Rich.Wolfson
I don't remember taking the sleeve out and didn't have much trouble with it. I did use a long tap wrench.
I assume you looked at the video on http://www.back-tap.com/
It may be time to call them as when we did it, and it was a while ago, it was no problem. If I still had the Backtap here I would go down to look to refresh my memory but alas....
Sorry I can't be more help.
Rich
Old Apr 7, 2008 | 06:34 PM
JCampos's Avatar
JCampos
I have seen the video and understand how to use the tool, but I really don't get how you used a tap wrench with it :\
Old Apr 7, 2008 | 06:35 PM
JCampos's Avatar
JCampos
I assume you mean something like this:
http://longjersales.trustpass.alibab...h/showimg.html
Old Apr 7, 2008 | 07:45 PM
Rich.Wolfson
Exactly. Inserted the BackTap, tightened the nut and backed it out cleaning up the threads. We did not have to tighten the tap wrench as once the threads were engaged it was self lifting. What I don't remember is how we tightened the knurl but frankly it didn't seem to be an issue at the time.
Rich
Old Apr 7, 2008 | 09:53 PM
JCampos's Avatar
JCampos
Yea.. that is my problem... I cant tighten that damn thing
Old Apr 8, 2008 | 03:26 PM
JCampos's Avatar
JCampos
Welp, it doesnt seem like the backtap is working... I got it in there today and actually got it tightened, but the thing just isn't working So, I resorted to trying to take out that stupid spark plug tube to get a better look at what was down there...
key word... TRYING!! I have got hard to remove things out before, but this thing is damn near impossible. The tube is now all shredded up and still stuck in there and not budging. Looks like it's time to call in the pro's and get myself a helicoil
jamez
Apr 28, 2011 06:55 PM
Plaz
Dec 21, 2010 06:20 PM
BigglesTAP
Feb 15, 2010 08:16 AM
JCampos
Northern California
Mar 18, 2008 11:31 PM
fjork_duf
Mar 12, 2008 01:15 PM
